126|0
131
【MCXN947开发板测评】 MT35XL512读写功能测试 [复制链接]
在MCXN947开发板上,除了有QSPI型存储器W25Q64,还有另一种存储器MT35XL512,其电路如图1所示。
图1 存储器电路
该存储器的测试主程序为:
int main(void)
    uint32_t i = 0;
    status_t status;
    uint8_t vendorID = 0;
    CLOCK_SetClkDiv(kCLOCK_DivFlexcom4Clk, 1u);
    CLOCK_AttachClk(BOARD_DEBUG_UART_CLK_ATTACH);
    BOARD_InitPins();
    BOARD_InitBootClocks();
    BOARD_InitDebugConsole();
    CLOCK_SetClkDiv(kCLOCK_DivFlexspiClk, 2U);
    CLOCK_AttachClk(kPLL0_to_FLEXSPI);
    flexspi_nor_flash_init(EXAMPLE_FLEXSPI);
    PRINTF("\r\nFLEXSPI example started!\r\n");
#if defined(FLASH_ADESTO) && FLASH_ADESTO
    status = flexspi_nor_get_vendor_id(EXAMPLE_FLEXSPI, &vendorID);
    if (status != kStatus_Success)
        return status;
    PRINTF("Vendor ID: 0x%x\r\n", vendorID);
#endif
#if defined(FLASH_ENABLE_OCTAL_CMD)
    status = flexspi_nor_enable_octal_mode(EXAMPLE_FLEXSPI);
        return status;
#endif
#if !(defined(FLASH_ADESTO) && FLASH_ADESTO)
        return status;
#endif
    PRINTF("Erasing Serial NOR over FlexSPI...\r\n");
    status = flexspi_nor_flash_erase_sector(EXAMPLE_FLEXSPI, EXAMPLE_SECTOR * SECTOR_SIZE);
        PRINTF("Erase sector failure !\r\n");
        return -1;
#if defined(CACHE_MAINTAIN) && CACHE_MAINTAIN
    DCACHE_InvalidateByRange(EXAMPLE_FLEXSPI_AMBA_BASE + EXAMPLE_SECTOR * SECTOR_SIZE, FLASH_PAGE_SIZE);
#endif
    memset(s_nor_program_buffer, 0xFFU, sizeof(s_nor_program_buffer));
    memcpy(s_nor_read_buffer, (void *)(EXAMPLE_FLEXSPI_AMBA_BASE + EXAMPLE_SECTOR * SECTOR_SIZE),
           sizeof(s_nor_read_buffer));
    if (memcmp(s_nor_program_buffer, s_nor_read_buffer, sizeof(s_nor_program_buffer)))
        PRINTF("Erase data -  read out data value incorrect !\r\n ");
        return -1;
    else
        PRINTF("Erase data - successfully. \r\n");
    for (i = 0; i < 0xFFU; i++)
        s_nor_program_buffer[i] = i;
    status =
        flexspi_nor_flash_page_program(EXAMPLE_FLEXSPI, EXAMPLE_SECTOR * SECTOR_SIZE, (void *)s_nor_program_buffer);
        PRINTF("Page program failure !\r\n");
        return -1;
#endif
    if (memcmp(s_nor_read_buffer, s_nor_program_buffer, sizeof(s_nor_program_buffer)) != 0)
        PRINTF("Program data -  read out data value incorrect !\r\n ");
        return -1;
    else
        PRINTF("Program data - successfully. \r\n");
    while (1)
经程序的编译和下载,其显示效果如图2所示。说明该存储器的芯片ID为0XEF,经测试读写正常。
图2 测试结果
此帖出自NXP MCU论坛
