387|0
【Follow me第二季第4期】-任务3:学习PDM麦克风技术知识,调试PDM麦克风,通过串... [复制链接]
本次任务为学习PDM麦克风,并打印麦克风采集到的数据。
1、麦克风不需要安装单独的库,在板载资源里有“PDM.h”;
2、初始化串口,启动PDM,选择通道及设置采样频率;如果启动失败,则打印启动PDM失败;
static const char channels = 1;
static const int frequncy  = 24000;
short sampleBuffer[512];
volatile int samplesRead;
void setup() {
  // put your setup code here, to run once:
  Serial.begin(115200);
  PDM.onReceive(onPDMdata);
  if(!PDM.begin(channels,frequncy))
    Serial.println("Failed to start PDM!!!");
    while(1);
3、循环执行声音采样,并打印采样值;
void loop() {
  // put your main code here, to run repeatedly:
  if(samplesRead)
    for(int i = 0; i < samplesRead; i++)
      Serial.println(sampleBuffer[i]);
    samplesRead=0;
  delay(1);
4、用串口查看数据;可选择数据才看,也可选择波形查看;波形查看更直观。
总体代码如下:
#include "PDM.h"
void setup() {
    while(1);
void loop() {
  if(samplesRead)
    samplesRead=0;
  delay(1);
void onPDMdata(){
  int bytesAvailable = PDM.available();
  PDM.read(sampleBuffer,bytesAvailable);
  samplesRead = bytesAvailable / 2;
