进程的创新主要有fork、clone等的系统调用来完成。通过函数_do_fork实现。
_do_fork主要完成以下工作:
1、调用copy_process函数
2、调用wake_up_new_task函数唤醒新进程
* Ok, this is the main fork-routine.
* It copies the process, and if successful kick-starts
* it and waits for it to finish using the VM if required.
long do_fork(unsigned long clone_flags,
unsigned long stack_start,
struct pt_regs *regs,
unsigned long stack_size,
int __user *parent_tidptr,
int __user *child_tidptr)
struct task_struct *p;
int trace = 0;
long pid;
if (unlikely(current->ptrace)) {
trace = fork_traceflag (clone_flags);
if (trace)
clone_flags |= CLONE_PTRACE;
p = copy_process(clone_flags, stack_start, regs, stack_size, parent_tidptr, child_tidptr);
* Do this prior waking up the new thread - the thread pointer
* might get invalid after that point, if the thread exits quickly.
pid = IS_ERR(p) ? PTR_ERR(p) : p->pid;
if (!IS_ERR(p)) {
struct completion vfork;
if (clone_flags & CLONE_VFORK) {
p->vfork_done = &vfork;
init_completion(&vfork);
if ((p->ptrace & PT_PTRACED) || (clone_flags & CLONE_STOPPED)) {
* We'll start up with an immediate SIGSTOP.
sigaddset(&p->pending.signal, SIGSTOP);
set_tsk_thread_flag(p, TIF_SIGPENDING);
p->state = TASK_STOPPED;
if (!(clone_flags & CLONE_STOPPED))
wake_up_forked_process(p); /* do this last */
++total_forks;
if (unlikely (trace)) {
current->ptrace_message = pid;
ptrace_notify ((trace << 8) | SIGTRAP);
wait_for_completion(&vfork);
if (unlikely (current->ptrace & PT_TRACE_VFORK_DONE))
ptrace_notify ((PTRACE_EVENT_VFORK_DONE << 8) | SIGTRAP);
} else
* Let the child process run first, to avoid most of the
* COW overhead when the child exec()s afterwards.
set_need_resched();
return pid;
copy_process函数的主要工作:
- 通过dup_task_struct函数为进程分配内存空间。
- 通过sched_fork函数为进程设置调度器
- 通过copy_semundo、copy_files、copy_fs、copy_sighand、copy_signal、copy_mm、copy_namespaces、copy_io、copy_thread_tls函数复制共享资源。
wake_up_new_task函数的主要工作:
- 将新进程的状态切换到TASK_RUNNING
- 将新进程加入到运行队列
