1:TCL1543驱动子程序
#define CLOCK P1_3
#define D_IN P1_4
#define D_OUT P1_5
#define _CS P1_6
uint read1543(uchar port) //从TLC1543读取采样值,形参port是采样的通道号
uint data ad;uint data i;
uchar data al=0,ah=0;
CLOCK=0;
_CS=0;
port<<=4;
for (i=0;i<4;i++) //把通道号打入1543
D_IN=(bit)(port&0x80);CLOCK=1;CLOCK=0;
port<<=1;
for (i=0;i<6;i++) //填充6个CLOCK
CLOCK=1;CLOCK=0;
_CS=1;_nop_();_nop_();_CS=0; //等待AD转换
for (i=0;i<2;i++) //取D9,D8
D_OUT=1;
CLOCK=1;
ah<<=1;
if (D_OUT) ah|=0x01;
CLOCK=0;
for (i=0;i<8;i++) //取D7--D0
D_OUT=1;
CLOCK=1;
al<<=1;
if (D_OUT) al|=0x01;
CLOCK=0;
_CS=1;
ad=(uint)ah;ad<<=8;ad|=al; //得到AD值
return (ad);
2:数码管显示程序
#include
#include
unsigned char data dis_digit;
unsigned char code dis_code[11]={0xc0,0xf9,0xa4,0xb0, // 0, 1, 2, 3
0x99,0x92,0x82,0xf8,0x80,0x90, 0xff};// 4, 5, 6, 7, 8, 9, off
unsigned char data dis_buf[8];
unsigned char data dis_index;
void main()
P0 = 0xff;
P2 = 0xff;
TMOD = 0x01;
TH0 = 0xFC;
TL0 = 0x17;
IE = 0x82;
dis_buf[0] = dis_code[0x1];
dis_buf[1] = dis_code[0x2];
dis_buf[2] = dis_code[0x3];
dis_buf[3] = dis_code[0x4];
dis_buf[4] = dis_code[0x5];
dis_buf[5] = dis_code[0x6];
dis_buf[6] = dis_code[0x7];
dis_buf[7] = dis_code[0x8];
dis_digit = 0xfe;
dis_index = 0;
TR0 = 1;
while(1);
void timer0() interrupt 1
// dis_index --- 显示索引, 用于标识当前显示的数码管和缓冲区的偏移量
// dis_digit --- 位选通值, 传送到P2口用于选通当前数码管的数值, 如等于0xfe时,
// 选通P2.0口数码管
// dis_buf --- 显于缓冲区基地址
TH0 = 0xFC;
TL0 = 0x17;
P2 = 0xff; // 先关闭所有数码管
P0 = dis_buf[dis_index]; // 显示代码传送到P0口
P2 = dis_digit; //
dis_digit = _crol_(dis_digit,1); // 位选通值左移, 下次中断时选通下一位数码管
dis_index++; //
dis_index &= 0x07; // 8个数码管全部扫描完一遍之后,再回到第一个开始下一次扫描
帮个朋友、寻网络上的朋友给点指点!!!
