76|0
427
【FRDM-MCXN947】 P3T1755温度传感器测试 [复制链接]
读取P3T1755温度传感器的值,通过串口打印输出。
一、硬件部分
P3T1755电路图部分
二、接口和时钟配置
2.1、配置I3C接口
2.2、配置I3C时钟
也可以在程序中配置,配置代码
/* Attach PLL0 clock to I3C, 150MHz / 6 = 25MHz. */
CLOCK_SetClkDiv(kCLOCK_DivI3c1FClk, 6U);
CLOCK_AttachClk(kPLL0_to_I3C1FCLK);
三、程序部分
3.1、fsl_p3t1755.c
 * Copyright 2022, 2024 NXP
 * SPDX-License-Identifier: BSD-3-Clause
#include "fsl_p3t1755.h"
 * Definitions
 * Prototypes
 * Variables
 * Code
status_t P3T1755_WriteReg(p3t1755_handle_t *handle, uint32_t regAddress, uint8_t *regData, size_t dataSize)
    status_t result;
    result = handle->writeTransfer(handle->sensorAddress, regAddress, regData, dataSize);
    return (result == kStatus_Success) ? result : kStatus_Fail;
status_t P3T1755_ReadReg(p3t1755_handle_t *handle, uint32_t regAddress, uint8_t *regData, size_t dataSize)
    status_t result;
    result = handle->readTransfer(handle->sensorAddress, regAddress, regData, dataSize);
status_t P3T1755_Init(p3t1755_handle_t *handle, p3t1755_config_t *config)
    assert(handle != NULL);
    assert(config != NULL);
    assert(config->writeTransfer != NULL);
    assert(config->readTransfer != NULL);
    handle->writeTransfer = config->writeTransfer;
    handle->readTransfer  = config->readTransfer;
    handle->sensorAddress = config->sensorAddress;
    return kStatus_Success;
status_t P3T1755_ReadTemperature(p3t1755_handle_t *handle, double *temperature)
    status_t result = kStatus_Success;
    uint8_t data[2];
    uint16_t temp;
    result = P3T1755_ReadReg(handle, P3T1755_TEMPERATURE_REG, &data[0], 2);
    if (result == kStatus_Success)
        temp = (((uint16_t)data[0] << 8U) | (uint16_t)data[1]) >> 4U;
        *temperature = (double)temp * 0.0625;
    return result;
3.2、fsl_p3t1755.h
 * Copyright 2022 NXP
#ifndef _FSL_P3T1755_H_
#define _FSL_P3T1755_H_
#include "fsl_common.h"
/* Registers. */
#define P3T1755_TEMPERATURE_REG (0x00U)
#define P3T1755_CONFIG_REG      (0x01U)
/*! [url=home.php?mod=space&uid=159083]@brief[/url] Define sensor access function. */
typedef status_t (*sensor_write_transfer_func_t)(uint8_t deviceAddress,
                                                 uint8_t *regData,
                                                 size_t dataSize);
typedef status_t (*sensor_read_transfer_func_t)(uint8_t deviceAddress,
                                                uint8_t *regData,
                                                size_t dataSize);
typedef struct _p3t1755_handle
    sensor_write_transfer_func_t writeTransfer;
    sensor_read_transfer_func_t readTransfer;
    uint8_t sensorAddress;
} p3t1755_handle_t;
typedef struct _p3t1755_config
} p3t1755_config_t;
#if defined(__cplusplus)
extern "C" {
#endif
 * @brief Create handle for P3T1755, reset the sensor per user configuration.
 * @param p3t1755_handle The pointer to #p3t1755_handle_t.
 * [url=home.php?mod=space&uid=784970]@return[/url] kStatus_Success if success or kStatus_Fail if error.
status_t P3T1755_Init(p3t1755_handle_t *handle, p3t1755_config_t *config);
 * @brief Write Register with register data buffer.
 * @param handle The pointer to #p3t1755_handle_t.
 * @param regAddress register address to write.
 * @param regData The pointer to data buffer to be write to the reg.
 * @param dataSize Size of the regData.
 * @return kStatus_Success if success or kStatus_Fail if error.
status_t P3T1755_WriteReg(p3t1755_handle_t *handle, uint32_t regAddress, uint8_t *regData, size_t dataSize);
 * @brief Read Register to speficied data buffer.
 * @param regAddress register address to read.
 * @param regData The pointer to data buffer to store the read out data.
 * @param dataSize Size of the regData to be read.
status_t P3T1755_ReadReg(p3t1755_handle_t *handle, uint32_t regAddress, uint8_t *regData, size_t dataSize);
 * @brief Read temperature data.
 * @param temperature The pointer to temperature data.
status_t P3T1755_ReadTemperature(p3t1755_handle_t *handle, double *temperature);
#endif /* __cplusplus */
#endif /* _FSL_P3T1755_H_ */
3.3、p3t1755.c
#include "main.h"
 * Prototypes
static void i3c_master_callback(I3C_Type *base, i3c_master_handle_t *handle, status_t status, void *userData);
 * Variables
volatile status_t g_completionStatus;
volatile bool g_masterCompletionFlag;
i3c_master_handle_t g_i3c_m_handle;
p3t1755_handle_t p3t1755Handle;
const i3c_master_transfer_callback_t masterCallback = {
    .slave2Master = NULL, .ibiCallback = NULL, .transferComplete = i3c_master_callback};
 * Code
    if (status == kStatus_Success)
        g_masterCompletionFlag = true;
    g_completionStatus = status;
status_t I3C_WriteSensor(uint8_t deviceAddress, uint32_t regAddress, uint8_t *regData, size_t dataSize)
    i3c_master_transfer_t masterXfer = {0};
    uint32_t timeout                 = 0U;
    masterXfer.slaveAddress   = deviceAddress;
    masterXfer.direction      = kI3C_Write;
    masterXfer.busType        = kI3C_TypeI3CSdr;
    masterXfer.subaddress     = regAddress;
    masterXfer.subaddressSize = 1;
    masterXfer.data           = regData;
    masterXfer.dataSize       = dataSize;
    masterXfer.flags          = kI3C_TransferDefaultFlag;
    g_masterCompletionFlag = false;
    g_completionStatus     = kStatus_Success;
    result                 = I3C_MasterTransferNonBlocking(EXAMPLE_MASTER, &g_i3c_m_handle, &masterXfer);
    if (kStatus_Success != result)
        return result;
    while (!g_masterCompletionFlag)
        timeout++;
        if ((g_completionStatus != kStatus_Success) || (timeout > I3C_TIME_OUT_INDEX))
            break;
    if (timeout == I3C_TIME_OUT_INDEX)
        result = kStatus_Timeout;
    result = g_completionStatus;
    return result;
status_t I3C_ReadSensor(uint8_t deviceAddress, uint32_t regAddress, uint8_t *regData, size_t dataSize)
    masterXfer.direction      = kI3C_Read;
        return result;
        timeout++;
            break;
    return result;
status_t p3t1755_set_dynamic_address(void)
    uint8_t g_master_txBuff[1];
    /* Reset dynamic address. */
    g_master_txBuff[0]      = CCC_RSTDAA;
    masterXfer.slaveAddress = 0x7E;
    masterXfer.data         = g_master_txBuff;
    masterXfer.dataSize     = 1;
    result                  = I3C_MasterTransferBlocking(EXAMPLE_MASTER, &masterXfer);
    if (result != kStatus_Success)
        return result;
    /* Assign dynmic address. */
    memset(&masterXfer, 0, sizeof(masterXfer));
    g_master_txBuff[0]      = CCC_SETDASA;
    masterXfer.flags        = kI3C_TransferNoStopFlag;
        return result;
    g_master_txBuff[0]      = SENSOR_ADDR << 1;
    masterXfer.slaveAddress = SENSOR_SLAVE_ADDR;
    return I3C_MasterTransferBlocking(EXAMPLE_MASTER, &masterXfer);
void init_p3t1755(void)
	i3c_master_config_t masterConfig;
	p3t1755_config_t p3t1755Config;
//	/* Attach PLL0 clock to I3C, 150MHz / 6 = 25MHz. */
//	CLOCK_SetClkDiv(kCLOCK_DivI3c1FClk, 6U);
//	CLOCK_AttachClk(kPLL0_to_I3C1FCLK);
	init_p3t1755_pins();
	PRINTF("\r\nI3C master read sensor data example.\r\n");
	I3C_MasterGetDefaultConfig(&masterConfig);
	masterConfig.baudRate_Hz.i2cBaud          = EXAMPLE_I2C_BAUDRATE;
	masterConfig.baudRate_Hz.i3cPushPullBaud  = EXAMPLE_I3C_PP_BAUDRATE;
	masterConfig.baudRate_Hz.i3cOpenDrainBaud = EXAMPLE_I3C_OD_BAUDRATE;
	masterConfig.enableOpenDrainStop          = false;
	masterConfig.disableTimeout               = true;
	I3C_MasterInit(EXAMPLE_MASTER, &masterConfig, I3C_MASTER_CLOCK_FREQUENCY);
	/* Create I3C handle. */
	I3C_MasterTransferCreateHandle(EXAMPLE_MASTER, &g_i3c_m_handle, &masterCallback, NULL);
	result = p3t1755_set_dynamic_address();
			PRINTF("\r\nP3T1755 set dynamic address failed.\r\n");
	p3t1755Config.writeTransfer = I3C_WriteSensor;
	p3t1755Config.readTransfer  = I3C_ReadSensor;
	p3t1755Config.sensorAddress = SENSOR_ADDR;
	P3T1755_Init(&p3t1755Handle, &p3t1755Config);
void p3t1755_test(void)
	double temperature;
	while(1)
		result = P3T1755_ReadTemperature(&p3t1755Handle, &temperature);
				PRINTF("\r\nP3T1755 read temperature failed.\r\n");
		else
				PRINTF("Temperature:%0.1f \r\n", temperature);
		SysTick_Delay_ms(500);
3.4、p3t1755.h
#ifndef __P3T1755_H
#define __P3T1755_H
#define EXAMPLE_MASTER             I3C1
#define I3C_MASTER_CLOCK_FREQUENCY CLOCK_GetI3cClkFreq(1)
#define SENSOR_SLAVE_ADDR          0x48U
#define I3C_TIME_OUT_INDEX 100000000U
#define SENSOR_ADDR 0x08U
#define CCC_RSTDAA  0x06U
#define CCC_SETDASA 0x87
#ifndef EXAMPLE_I2C_BAUDRATE
#define EXAMPLE_I2C_BAUDRATE 400000
#endif
#ifndef EXAMPLE_I3C_OD_BAUDRATE
#define EXAMPLE_I3C_OD_BAUDRATE 1500000
#endif
#ifndef EXAMPLE_I3C_PP_BAUDRATE
#define EXAMPLE_I3C_PP_BAUDRATE 4000000
#endif
void init_p3t1755(void);
void p3t1755_test(void);
#endif
3.5、main.c
#include "main.h"
int main(void)
	uint8_t i;
  CLOCK_EnableClock(kCLOCK_Gpio0);
	BOARD_InitDEBUG_UARTPins();
	BOARD_PowerMode_OD();
	BOARD_InitBootClocks();
	BOARD_InitDebugConsole();
	init_utick();
	SysTick_Init();
	init_p3t1755();
	init_led();
	init_key();
	p3t1755_test();
	while (1)
		led_red_tog();
3.6、main.h
#ifndef _MAIN_H_
#define _MAIN_H_
#include "pin_mux.h"
#include "clock_config.h"
#include "board.h"
#include "fsl_debug_console.h"
#include "fsl_gpio.h"
#include "fsl_port.h"
#include "fsl_lpi2c.h"
#include "fsl_lpspi.h"
#include "fsl_lpspi_edma.h"
#include "fsl_utick.h"
#include "led/led.h"
#include "systick/systick.h"
#include "key/key.h"
#include "fsl_i3c.h"
#include "p3t1755/p3t1755.h"
#include "utick/utick.h"
#endif
四、运行结果
程序下载后,串口输出温度值
此帖出自NXP MCU论坛
