397|0
1249
67
【Follow me第二季第1期】补充:AD5270数字电位器的驱动应用 [复制链接]
AD5270是1024位、变阻器模式下的温度系数5 ppm/°C、1%电阻容差误差、SPI接口和50-TP存储器数字变阻器,性能十分优秀。
它集业界领先的可变电阻性能与非易失性存储器(NVM)于一体,并提供50次可编程(50-TP)存储器。将电阻值编程写入50-TP存储器之前,可进行无限次调整。这些器件不需要任何外部电压源来帮助熔断熔丝,并提供50次永久编程的机会。在50-TP激活期间,一个永久熔断熔丝指令会将游标位置固定。SPI接口控制时序如下:
使用开发板的SPI接口(任意IO软件模拟SPI)可以完成驱动控制,测试代码如下:
  • // AD5270 commands - new digital potentiometer
  • #define CMD_WR_RDAC 0x01
  • #define CMD_RD_RDAC 0x02
  • #define CMD_ST_RDAC 0x03
  • #define CMD_RST 0x04
  • #define CMD_RD_MEM 0x05
  • #define CMD_RD_ADDR 0x06
  • #define CMD_WR_CTRL 0x07
  • #define CMD_RD_CTRL 0x08
  • #define CMD_SHTDN 0x09
  • void vspi_write_word(const int chip_select, uint16_t data_to_send, const uint8_t bit_order, const uint8_t mode) {
  • vspi->beginTransaction(SPISettings(SPI_FREQ_FAST, bit_order, mode));
  • digitalWrite(chip_select, LOW); //pull SS slow to prep other end for transfer
  • vspi->transfer16(data_to_send);
  • digitalWrite(chip_select, HIGH); //pull ss high to signify end of data transfer
  • vspi->endTransaction();
  • /* Write a 4-bit command and a 10-bit data word */
  • void AD5270_Write(const int chip_select, uint8_t cmd, uint16_t data){
  • uint16_t data_word = ((cmd & 0x0F) << 10) | (data & 0x03FF);
  • vspi_write_word(chip_select, data_word, MSBFIRST, SPI_MODE1);
  • /* Enable/disable rheostat value changes */
  • void AD5270_LockUnlock(const int chip_select, uint8_t lock){
  • AD5270_Write(chip_select, CMD_WR_CTRL, lock ? 0 : 0x002);
  • /* Enable/disable hardware shutdown */
  • void AD5270_Shutdown(const int chip_select, uint8_t shutdown){
  • AD5270_Write(chip_select, CMD_SHTDN, shutdown ? 1 : 0);
  • /* Set the value of the digital rheostat - range is 0-0x3FF (0-100kOhm) */
  • void AD5270_Set(const int chip_select, uint16_t val)
  • AD5270_Write(chip_select, CMD_WR_RDAC, val);
  • #define CHIP_SEL_MEAS 10 // Chip select pin for measuring digital rheostat potentiometer
  • void setup() {
  • // put your setup code here, to run once:
  • // Set voltage measurement gain to 1 (maximum current (5V pk-pk) must be within ADC range)
  • AD5270_Shutdown(CHIP_SEL_MEAS, 1);
  • AD5270_Set(CHIP_SEL_MEAS, 100);
  • void loop() {
  • // put your main code here, to run repeatedly:
测试接线和效果:
推荐帖子
震荡电路详解
震荡电路详解
毕设很重要,但找工作的规则更重要(1)
现在正是年后,各种招聘会招聘广告铺天盖地,我们很多的大学生们又该忙找工作了。我作为一个人到中年的职场油子,今天跟大家谈谈招 ...
关于ICL7135A/D转换器串行接口的最优化设计
ICL7135AD转换器除了可以并行输出万、千、百、十、个位上的BCD码这种形式外,还可以利用BUSY和CLK的相与功能进行串行数据输出, ...
【TI原创】采用8962驱动3.2寸TFT屏幕(非官方GUI版本)
看到坛子里面有关于8962驱动TFT的文章,主要是讲解如何使用官方的tft示例程序,个人觉得那个代码繁琐难懂,移植起来也是相当不方 ...
MSP430F5529系统实验AD部分,问题求解
这个是网站下载的程序,因为本人用的是F5529的板子,没有P6.0的端口输入插头,所以想改用P6.7端口输入,进行试验,中间除了一些 ...
【GD32L233C-START评测】4、电位器+ws2812做一个简易可调灯色的灯环
本帖最后由 emmnn 于 2022-3-2 00:02 编辑 前言 不知不觉,春节已经过去一个月了,2022年也过去了两个月。年后因为种种原 ...
[先楫HPM6750测评之一]两种IDE(SES和RS)开发平台体验
SES是segger公司所出的segger embedded studio的开发平台,而RS是rtthread所出的rtthread studio。两个开发平台均支持hpm系列开 ...
在产生自我质疑时可以多跟朋友交流交流
最近工作不太顺利,不够细心,开始怀疑自己工作能力。跟朋友讲了一下好多了
加防护,更安全!OK-MX9352-C开发板让通信安全又稳定
随着新基建的加快推进,智能制造迎来了更好的发展时机,嵌入式板卡等智能设备也在更多的应用场景中大放异彩。但随着现场的设备数 ...
有没有3D打印机推荐
想弄个小的3D打印机玩玩,有没有那种适合DIY的小型3D打印机推荐,价格不要太贵。
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
