324|3
3243
读写ISL12026EEPROM失败 [复制链接]
代码:
#include<reg51.h>
#include"OLED.H"
extern unsigned char code Dot[];
#define uint unsigned int
#define uchar unsigned char
#define UINT8 unsigned char
#define HMS_FLAG  1
//--------与24C02相关的设置和子函数-------------
void delay(){ ;;;;;;;;;;;;;; ;;;;;;;;;;;;;;}                 //简单短延时子函数
sbit sda_24c02=P2^6;    //定义24C02的数据线与单片机的连接
sbit scl_24c02=P2^7;
void start_24c02();          //24C02开始信号
void stop_24c02();           //24C02停止
void respons_24c02();          //24C02应答
void init_24c02();                  //24C02初始化
void write_byte_24c02(uchar date);         //写一个byte到24C02
uchar read_byte_24c02();                         //从24C02读一个byte
void write_add_24c02(uchar address,uchar date);        //写一个字节到指定的24C02单元
uchar read_add_24c02(uchar address);                        //从24C02指定单元读一个字节数据
void write_add1_24c02(uchar address,uchar date);        //写一个字节到指定的24C02单元
uchar read_add1_24c02(uchar address);                        //从24C02指定单元读一个字节数据
void XWrite_eeprom(UINT8 Address,UINT8 eeprom_Data);
UINT8  XRead_eeprom(UINT8 Address);
sbit led=P1^0;
unsigned char code table_num[]="0123456789";   //LCD显示的数字代码
void delay_ms(uint xms);                   //ms级延时子函数
unsigned char i;                        //
struct ccb
	uchar second;
	uchar minute;
	uchar hour;
	uchar day;
	uchar month;
	uchar year;
struct ccb CurrentTime;
UINT8 Change10ToBCD(UINT8 data1)         //10->BCD数值转化
    UINT8 high,low,result;
    high=data1/10;
    low=data1%10;
    result=(high<<4)|low;
    return result;
void init_ISL12026()
    XWrite_eeprom(0x3F,0x02);
    XWrite_eeprom(0x3F,0x06);
void ResetRtcTime()
    init_ISL12026();
    XWrite_eeprom(0x37,Change10ToBCD(20));//世纪
    XWrite_eeprom(0x36,Change10ToBCD(0));//周
    XWrite_eeprom(0x35,Change10ToBCD(10));//年
    XWrite_eeprom(0x34,Change10ToBCD(1));//月
    XWrite_eeprom(0x33,Change10ToBCD(1));//日
    XWrite_eeprom(0x32,Change10ToBCD(12)|0x80);//时
    XWrite_eeprom(0x31,Change10ToBCD(12));//分
    XWrite_eeprom(0x30,Change10ToBCD(12));//秒
UINT8 ChangeBCDTo10(UINT8 data1)         //BCD->10数值转化
    UINT8 temp,result;
    result=data1&0x0F;
    temp=data1>>4;
    result+=temp*10;
    return result;
void readCurrentTime()
    CurrentTime.year=ChangeBCDTo10(XRead_eeprom(0x35));
    CurrentTime.month=ChangeBCDTo10(XRead_eeprom(0x34));
    CurrentTime.day=ChangeBCDTo10(XRead_eeprom(0x33));
    CurrentTime.hour=ChangeBCDTo10(XRead_eeprom(0x32)&0x7F);
    CurrentTime.minute=ChangeBCDTo10(XRead_eeprom(0x31));
    CurrentTime.second=ChangeBCDTo10(XRead_eeprom(0x30));
//按页写入。  pBuffer数组指针首地址,WriteAddr要写入页的首地址,NumByteToWrite写入字符个数
void ISL12026_PageWrite(UINT8* pBuffer, UINT8 WriteAddr, UINT8 NumByteToWrite)
    init_ISL12026();
    //XStart_iic();
    start_24c02();
	write_byte_24c02(0xde);
    respons_24c02();
    //XWriteByte(0);
    //XReceiveAck();
	write_byte_24c02(0);
    respons_24c02();
    //XWriteByte(WriteAddr);
    //XReceiveAck();
	write_byte_24c02(WriteAddr);
    respons_24c02();
    while(NumByteToWrite--)
        //XWriteByte(*pBuffer);
        //Point to the next byte to be written
		write_byte_24c02(*pBuffer);
    	respons_24c02();
        pBuffer++;
        //XReceiveAck();
    //XStop_iic();
    stop_24c02();
	for(i=0;i<40;i++)
		delay();
//写入时间信息,按照秒,分,时,天,月,年的顺序写入
void ISL12026_TimeWrite(UINT8 second,UINT8 minute,UINT8 hour,UINT8 day,UINT8 month,UINT8 year)
    UINT8 temp[8];
    temp[0]=Change10ToBCD(second);
    temp[1]=Change10ToBCD(minute);
    temp[2]=Change10ToBCD(hour)|0x80;
    temp[3]=Change10ToBCD(day);
    temp[4]=Change10ToBCD(month);
    temp[5]=Change10ToBCD(year);
    temp[6]=Change10ToBCD(0);      //周,不用则写0
    temp[7]=Change10ToBCD(20);
    ISL12026_PageWrite(temp,0x30,8);
void saveX1226(UINT8 hour_year,UINT8 minute_month,UINT8 second_day,UINT8 index)
    init_X1226();
    if(index==HMS_FLAG)//写时分秒
        XWrite_eeprom(0x30,Change10ToBCD(second_day));//秒
        XWrite_eeprom(0x31,Change10ToBCD(minute_month));//分
        XWrite_eeprom(0x32,Change10ToBCD(hour_year)|0x80);//时
    else//写年月日星期
        XWrite_eeprom(0x33,Change10ToBCD(second_day));//日
        XWrite_eeprom(0x34,Change10ToBCD(minute_month));//月
        XWrite_eeprom(0x35,Change10ToBCD(hour_year));//年
    XWrite_eeprom(0x11,0x00);//按定时输出
    //XWrite_eeprom(0x3F,0x00);
    Delay(50);
/*void init_ISL12026_IQR()
    //UINT8 mRtcStatus;
    init_ISL12026();
    //mRtcStatus=ChangeBCDTo10(XRead_eeprom(0x11));
    //mRtcStatus=mRtcStatus;
    XWrite_eeprom(0x11,0x00);//0x18, 1秒一个频冲
    //Delay(100);
	for(i=0;i<80;i++)
		delay();
void init_ISL12026_Alarm(UINT8 Hour_Week,UINT8 Minute_Month,UINT8 Second_Day,UINT8 index) // 设置报警时间
    init_ISL12026();
        XWrite_eeprom(0x00,Change10ToBCD(Second_Day));//秒
        XWrite_eeprom(0x01,Change10ToBCD(Minute_Month));//分
        XWrite_eeprom(0x02,Change10ToBCD(Hour_Week)|0x80);//时
    else//写月日星期
        XWrite_eeprom(0x03,Change10ToBCD(Second_Day));//日
        XWrite_eeprom(0x04,Change10ToBCD(Minute_Month));//月
        XWrite_eeprom(0x06,Change10ToBCD(Hour_Week));//年
    XWrite_eeprom(0x11,0xA0);//按定时输出
    //Delay(50);
	for(i=0;i<40;i++)
		delay();
void PowerInitTime(void)
    struct ccb DownTime;
    UINT8 mRtcStatus;
    init_ISL12026();
    //mRtcStatus=XRead_eeprom(0x14);
    XWrite_eeprom(0x14,0x00);
    mRtcStatus=ChangeBCDTo10(XRead_eeprom(0x3F));
    if ( mRtcStatus & 0x01 )                             //如果完全断电,设置为上次参数下载的时间
        /*DownTime.year=ByteReadEeprom(DownLoadYearAddrOne);
        DownTime.month=ByteReadEeprom(DownLoadMonthAddrOne);
        DownTime.day=ByteReadEeprom(DownLoadDayAddrOne);
        DownTime.hour=ByteReadEeprom(DownLoadHourAddrOne);
        DownTime.minute=ByteReadEeprom(DownLoadMinuteAddrOne);
        DownTime.second=ByteReadEeprom(DownLoadSecondAddrOne);
        ISL12026_TimeWrite(DownTime.second,DownTime.minute,DownTime.hour,DownTime.day,DownTime.month,DownTime.year);
void readSecond()
    //CurrentTime.minute=ChangeBCDTo10(XRead_eeprom(0x31));
void main(void)
	unsigned int i;
	unsigned char temp;
	unsigned char second;
	unsigned char bai,shi,ge;
	unsigned char year,month,day,hour,minute;
	LCD_Init();
     LCD_CLS();
	//LCD_P8x16Str(45,5,(u8*)"EASEAR");
	//LCD_P6x8Str(0,7,(u8*)"www.holteksupport.com");
	//Draw_BMP(0,0,100,3,(u8*)Dot);
	init_ISL12026();
		//XWrite_eeprom(0x3F,0x82);
		//delay2();
    	//XWrite_eeprom(0x3F,0x86);
		XWrite_eeprom(0x50,209);//
		for(i=0;i<60000;i++);
		XWrite_eeprom(0x52,126);//
		XWrite_eeprom(0x54,158);//
		temp=XRead_eeprom(0x52);
		bai=temp/100+48;
		shi=temp%100/10+48;
		ge=temp%10+48;
		LCD_P8x16Char(0,0,bai);
		LCD_P8x16Char(8,0,shi);
		LCD_P8x16Char(16,0,ge);
		temp=XRead_eeprom(0x54);
		bai=temp/100+48;
		shi=temp%100/10+48;
		ge=temp%10+48;
		LCD_P8x16Char(32,0,bai);
		LCD_P8x16Char(40,0,shi);
		LCD_P8x16Char(48,0,ge);
		temp=XRead_eeprom(0x50);
		bai=temp/100+48;
		shi=temp%100/10+48;
		ge=temp%10+48;
		LCD_P8x16Char(64,0,bai);
		LCD_P8x16Char(72,0,shi);
		LCD_P8x16Char(80,0,ge);
		//XWrite_eeprom(0x10,0x00);//去除写保护
		/*XWrite_eeprom(0x37,0x06);//
		second=XRead_eeprom(0x3f);
		bai=second/100;
		shi=second%100/10;
		ge=second%10;
		lcd_display_char(12,0,bai+0x30);
		lcd_display_char(13,0,shi+0x30);
		lcd_display_char(14,0,ge+0x30);
		//XWrite_eeprom(0x3f,0x00);//
		XWrite_eeprom(0x14,0x00);//	*/
		LCD_P8x16Str(0,2,(u8*)"  :  :  ");
		LCD_P8x16Str(0,4,(u8*)"20  -  -  ");
		ISL12026_TimeWrite(50,59,23,31,12,23);
	while(1)
//		readSecond();
		readCurrentTime();
		shi=(CurrentTime.second/10)+0x30;
		ge=(CurrentTime.second%10)+0x30;
		LCD_P8x16Char(48,2,shi);
		LCD_P8x16Char(56,2,ge);
		shi=(CurrentTime.minute/10)+0x30;
		ge=(CurrentTime.minute%10)+0x30;
		LCD_P8x16Char(24,2,shi);
		LCD_P8x16Char(32,2,ge);
		shi=(CurrentTime.hour/10)+0x30;
		ge=(CurrentTime.hour%10)+0x30;
		LCD_P8x16Char(0,2,shi);
		LCD_P8x16Char(8,2,ge);
		shi=(CurrentTime.day/10)+0x30;
		ge=(CurrentTime.day%10)+0x30;
		LCD_P8x16Char(64,4,shi);
		LCD_P8x16Char(72,4,ge);
		shi=(CurrentTime.month/10)+0x30;
		ge=(CurrentTime.month%10)+0x30;
		LCD_P8x16Char(40,4,shi);
		LCD_P8x16Char(48,4,ge);
		shi=(CurrentTime.year/10)+0x30;
		ge=(CurrentTime.year%10)+0x30;
		LCD_P8x16Char(16,4,shi);
		LCD_P8x16Char(24,4,ge);
		for(i=0;i<20000;i++);
void delay_ms(uint xms)        //ms级延时子程序
        {        unsigned int aa,bb;
                for(aa=xms;aa>0;aa--)
                        for(bb=4000;bb>0;bb--);        //调整数值以使本句运行时间为1ms
void start_24c02()  //24c02开始信号
{        sda_24c02=1;        delay();
        scl_24c02=1;        delay();
        sda_24c02=0;        delay(); }
void stop_24c02()   //24c02停止
{        sda_24c02=0;        delay();
        sda_24c02=1;        delay(); }
void respons_24c02()  //24c02应答
{        uchar i;
        scl_24c02=1;
        delay();
        while((sda_24c02==1)&&(i<250))i++;
        scl_24c02=0;
        delay(); }
void init_24c02()                 //24c02初始化
        scl_24c02=1;        delay(); }
void write_byte_24c02(uchar date) //写8个
{        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
        {        temp=temp<<1;
                scl_24c02=0;            delay();
                sda_24c02=CY;                delay();
{        uchar i,k;
        for(i=0;i<8;i++)
        {        scl_24c02=1;                delay();
                k=(k<<1)|sda_24c02;
        return k;  }
void write_add_24c02(uchar address,uchar date)//将某数据写入24C02某个单元中
{        start_24c02();
        write_byte_24c02(0xa0);         //24c02的写地址(1010 0000)
        respons_24c02();
        write_byte_24c02(address);
        respons_24c02();
        write_byte_24c02(date);
        respons_24c02();
        stop_24c02();         }
uchar read_add_24c02(uchar address)//读出24c02某个单元数据到变量中
{        uchar date;
        start_24c02();
        write_byte_24c02(0xa0);           //24c02的读地址(1010 0001)
        respons_24c02();
        respons_24c02();
        start_24c02();
        write_byte_24c02(0xa1);
        respons_24c02();
        date=read_byte_24c02();
        stop_24c02();
        return date; }
//--------与24C02相关的设置和子函数  结束-----------
void write_add1_24c02(uchar address,uchar date)//将某数据写入24C02某个单元中
{        start_24c02();
        write_byte_24c02(address<<1);
        respons_24c02();
        respons_24c02();
        stop_24c02();         }
uchar read_add1_24c02(uchar address)//读出24c02某个单元数据到变量中
{        uchar date;
        start_24c02();
        write_byte_24c02((address<<1)+1);
        respons_24c02();
        //start_24c02();
        //write_byte_24c02(0xa1);
        //respons_24c02();
        stop_24c02();
        return date; }
	//XStart_iic();
	start_24c02();
    //XWriteByte(0xDE);
    //XReceiveAck();
	respons_24c02();
    /*XWriteByte(0);
    XReceiveAck();
    XWriteByte(Address);
    XReceiveAck();
    XWriteByte(eeprom_Data);
    XReceiveAck();
    XStop_iic();*/
    //XReceiveAck();
	respons_24c02();
	write_byte_24c02(Address);
    //XReceiveAck();
	respons_24c02();
	write_byte_24c02(eeprom_Data);
    //XReceiveAck();
	respons_24c02();
	stop_24c02();
    UINT8 rdata;
    //XStart_iic();
    //XWriteByte(0xDE);
    //XReceiveAck();
	start_24c02();
	respons_24c02();
    //XWriteByte(0);
    //XReceiveAck();
    //XWriteByte(Address);
    //XReceiveAck();
	respons_24c02();
	respons_24c02();
    /*XStart_iic();
    XWriteByte(0xDF);
    XReceiveAck();
    rdata=XReadByte();
    XNo_Acknowledge();
    XStop_iic(); */
	start_24c02();
	write_byte_24c02(0xdf);
	respons_24c02();
	rdata=read_byte_24c02();
        stop_24c02();
    return(rdata);
读写时间都没问题。读写EEPROM,读出来都是158,也就是最后写进去的值。
请问高手,哪里有错?谢谢
此帖出自51单片机论坛
只能抓一下IIC的时序了   详情 回复 发表于 2024-12-16 09:07
个人签名为江山踏坏了乌骓马,为社稷拉断了宝雕弓。
7244
啥问题,是写不进去吗?
此帖出自51单片机论坛
不知道,写了读出来不对。  详情 回复 发表于 2024-12-13 09:37
3243
wangerxian 发表于 2024-12-12 16:22 啥问题,是写不进去吗?
不知道,写了读出来不对。
此帖出自51单片机论坛
7244
chenbingjy 发表于 2024-12-13 09:37 不知道,写了读出来不对。
只能抓一下IIC的时序了
此帖出自51单片机论坛
