277|0
1464
【翌创ET6001测评】点阵板显示驱动 [复制链接]
在通常的情况下,我们所用的显示器件多为数码管、液晶屏等。但在公共场合,则需要使用较大尺寸和规格的显示器件。
市场上的告广牌多是由半板拼接而成的,这里就选用一款P4.75的红色点阵板,其显示分辨率为16*64像素点,其外观如图1所示。
图1 点阵屏外观
该点阵板随使用的接口方式为HUB08,其各引脚的名称如图2所示。
图2  HUB08接口
点阵板与开发板的引脚连接关系为:
A  ---- P24
B  ---- P11
C  ---- P12
D  ----P13
R1 ---- P23
CLK----P22
EN ---- P21
STB---- P25
所用引脚的工作模式配置函数为:
static void dzp_CONFIG(void)
    IOC_Init_TypeDef init;
    IOC_ConfigStructInit(&init);
    init.mode = IOC_AF_MODE_3;
    init.dir = GPIO_DIR_OUT;
    init.pull = IOC_PULL_NONE;
    IOC_Config(IOC_PIN_GPIO_PLL_REF, &init);
    GPIO_PortOutputEnable(GPIO2, GPIO_PIN_01);
    GPIO_PortOutputEnable(GPIO2, GPIO_PIN_02);
    GPIO_PortOutputEnable(GPIO2, GPIO_PIN_03);
    GPIO_PortOutputEnable(GPIO2, GPIO_PIN_04);
    GPIO_PortOutputEnable(GPIO2, GPIO_PIN_05);
    GPIO_PortOutputEnable(GPIO1, GPIO_PIN_01);
    GPIO_PortOutputEnable(GPIO1, GPIO_PIN_02);
    GPIO_PortOutputEnable(GPIO1, GPIO_PIN_03);
所用引脚输出高低电平的语句定义为:
#define LR1_high   GPIO_WritePin(GPIO2, GPIO_PIN_03, SET)
#define LR1_low    GPIO_WritePin(GPIO2, GPIO_PIN_03, RESET)
#define CLK_high   GPIO_WritePin(GPIO2, GPIO_PIN_02, SET)
#define CLK_low    GPIO_WritePin(GPIO2, GPIO_PIN_02, RESET)
#define LSTB_high  GPIO_WritePin(GPIO2, GPIO_PIN_05, SET)
#define LSTB_low   GPIO_WritePin(GPIO2, GPIO_PIN_05, RESET)
#define LEN_high   GPIO_WritePin(GPIO2, GPIO_PIN_01, SET)
#define LEN_low    GPIO_WritePin(GPIO2, GPIO_PIN_01, RESET)
#define LA_high    GPIO_WritePin(GPIO2, GPIO_PIN_04, SET)
#define LA_low     GPIO_WritePin(GPIO2, GPIO_PIN_04, RESET)
#define LB_high    GPIO_WritePin(GPIO1, GPIO_PIN_01, SET)
#define LB_low     GPIO_WritePin(GPIO1, GPIO_PIN_01, RESET)
#define LC_high    GPIO_WritePin(GPIO1, GPIO_PIN_02, SET)
#define LC_low     GPIO_WritePin(GPIO1, GPIO_PIN_02, RESET)
#define LD_high    GPIO_WritePin(GPIO1, GPIO_PIN_03, SET)
#define LD_low     GPIO_WritePin(GPIO1, GPIO_PIN_03, RESET)
点阵板发送数据的函数为:
static void OutByte(uint16_t dat)
    uint8_t i=0 ;
    for(i=0;i<16;i++)
        CLK_low;
        if(dat&0x0001)
            LR1_high;
        else
            LR1_low;
        dat=dat>>1;
        CLK_high;
发送多列数据的函数为:
static void DisCol(uint16_t lenght)
    uint16_t dat;
    uint8_t m=0;
    while(lenght--)
         dat=(S[sj[m+1]*16+ScanRow]<<8)+S[sj[m]*16+ScanRow];
         OutByte(dat);
         m=m+2;
输出行地址的函数为:
static void  SeleRow(uint8_t Nd)
    uint8_t N;
    N=Nd;
    N=N%16;
    if(N&0x01)   LA_high;
    else  LA_low;
    if (N&0x02)  LB_high;
    else  LB_low;
    if (N&0x04)  LC_high;
    else  LC_low;
    if (N&0x08)  LD_high;
    else  LD_low;
实现显示输出的函数为:
static void  Display(void)
      DisCol(4);
      LEN_high;
      LSTB_high;
      LSTB_low;
      SeleRow(ScanRow);
      LEN_low;
      ScanRow++;
      if(ScanRow>15)  ScanRow=0;
模拟RTC计时效果的显示函数为:
static void ShowTime(void)
    sj[0]= 1;
    sj[1]= 2;
	sj[2]= 10;
    sj[3]= 3;
    sj[4]= 0;
	sj[5]= 10;
    sj[6]= 0;
    sj[7]= 8;
    Display();
为进行显示,所配置的字模由数组来存储,其内容为:
uint8_t S[]={
0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,/*"0",0*/
0x00,0x00,0x00,0x08,0x0E,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x3E,0x00,0x00,/*"1",1*/
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x20,0x20,0x10,0x08,0x04,0x42,0x7E,0x00,0x00,/*"2",2*/
0x00,0x00,0x00,0x3C,0x42,0x42,0x20,0x18,0x20,0x40,0x40,0x42,0x22,0x1C,0x00,0x00,/*"3",3*/
0x00,0x00,0x00,0x20,0x30,0x28,0x24,0x24,0x22,0x22,0x7E,0x20,0x20,0x78,0x00,0x00,/*"4",4*/
0x00,0x00,0x00,0x7E,0x02,0x02,0x02,0x1A,0x26,0x40,0x40,0x42,0x22,0x1C,0x00,0x00,/*"5",5*/
0x00,0x00,0x00,0x38,0x24,0x02,0x02,0x1A,0x26,0x42,0x42,0x42,0x24,0x18,0x00,0x00,/*"6",6*/
0x00,0x00,0x00,0x7E,0x22,0x22,0x10,0x10,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,/*"7",7*/
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x24,0x18,0x24,0x42,0x42,0x42,0x3C,0x00,0x00,/*"8",8*/
0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x64,0x58,0x40,0x40,0x24,0x1C,0x00,0x00,/*"9",9*/
0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,/*":",10*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"-",11*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
实现显示输出的主程序为:
int32_t main(void)
    dzp_CONFIG();
    ScanRow=0;
    while (1)
         ShowTime();
经程序的编译与运行,其执行效果如图3所示。
图3  硬件连接及显示效果
