293|0
1286
【Follow me第二季第3期】quad-spi flash和octo-spi flash程序配置及读写速度测试 [复制链接]
测试quad-spi flash和octo-spi flash读写速度对比,如下图
对应代码如下:
进入主函数(main.c)找到菜单任务
通过菜单任务逐布找到菜单选项部分程序,也就是串口调试页面的菜单选项,如下
进入spi测试部分程序
SPI读写测试程序及转换程序如下
ospi_performance_test (block_size_actual, &ospi_performance_write_result, &ospi_performance_read_result);
ospi_write_result = ((100000000 / timer_frequency) * ospi_performance_write_result) / 100;
qspi_write_result  = ((100000000 / timer_frequency) * qspi_write_test(block_size_actual)) / 100;
print_to_console((uint8_t *)"Writing to flash completed\r\n");
print_to_console((uint8_t *)"\r\nReading the text block from external Quad-SPI and Octo-SPI flash memories...\r\n");
ospi_read_result  = ((100000000 / timer_frequency) * ospi_performance_read_result) / 100;
qspi_read_result  = ((100000000 / timer_frequency) * qspi_read_test(block_size_actual)) / 100;
ospi数据写入测试程序如下:
static uint32_t write_dopi_ospi(uint32_t data_size)
    fsp_err_t err;
    uint32_t test_var;
    uint8_t * p_dest = (uint8_t *)OSPI_DMA_ADDRESS;
    timer_status_t status = {};
    uint32_t number_of_pages;
    R_GPT_Open(g_memory_performance.p_ctrl, g_memory_performance.p_cfg);
    number_of_pages = (uint32_t)(data_size * (1024 / OSPI_TEST_PAGE_SIZE));
for (test_var = 0; test_var < number_of_pages; test_var++ )
        R_GPT_Start(g_memory_performance.p_ctrl);
        err = R_OSPI_Write(g_ospi.p_ctrl, s_page, p_dest, OSPI_TEST_PAGE_SIZE);
        if (FSP_SUCCESS != err)
            __asm("bkpt");
        ospi_test_wait_until_wip();
        p_dest += OSPI_TEST_PAGE_SIZE;
        R_GPT_Stop(g_memory_performance.p_ctrl);
        vTaskDelay(1U);
    R_GPT_StatusGet(g_memory_performance.p_ctrl, &status);
    R_GPT_Reset(g_memory_performance.p_ctrl);
    R_GPT_Close(g_memory_performance.p_ctrl);
    return (status.counter);
ospi数据读取测试程序如下:
static uint32_t read_dopi_ospi(uint32_t data_size)
    uint32_t * p_src = (uint32_t *)OSPI_DMA_ADDRESS;
    uint32_t * p_dest = (uint32_t *)s_perf_read;
#ifdef READ_PAGE_BY_PAGE
    number_of_blocks = data_size * ( 1024 / OSPI_TEST_PAGE_SIZE);
    while(number_of_blocks--)
           data = (OSPI_TEST_PAGE_SIZE) / 4U;
#ifdef MANUAL_READ
        while (data)
            *p_dest = *p_src;
            p_dest++;
            p_src++;
            data--;
#endif
#define READ_MEMCPY
#ifdef READ_MEMCPY
        memcpy ( p_dest, p_src, OSPI_TEST_PAGE_SIZE / 4);
        p_src += OSPI_TEST_PAGE_SIZE / 4;
        p_dest += OSPI_TEST_PAGE_SIZE / 4;
        vTaskDelay(1U);
#endif
#endif
#ifdef READ_AS_SINGLE_BLOCK
    R_OSPI_XipEnter(g_ospi.p_ctrl);
    memcpy (p_dest, p_src, (data_size * 1024) / 4);
    R_OSPI_XipExit(g_ospi.p_ctrl);
#endif
qspi数据写入测试程序如下:
static uint32_t qspi_write_test(uint32_t block_size)
    fsp_err_t fsp_err;
    uint32_t qspi_write_result = 0;
    fsp_err_t err = FSP_SUCCESS;
    spi_flash_protocol_t current_spi_mode;
    block_size *= 1024;
    current_spi_mode = SPI_FLASH_PROTOCOL_EXTENDED_SPI;
    err = qpi_init();
    if (FSP_SUCCESS == err)
        current_spi_mode = g_qspi_cfg.spi_protocol;
    uint32_t page_write_count = 0;
    uint8_t  * p_mem_addr;
    p_mem_addr = (uint8_t *)QSPI_DEVICE_START_ADDRESS;
    while (((page_write_count * SECTOR_SIZE) < block_size)
        && ( FSP_SUCCESS == err ) )
        err = R_QSPI_Erase(&g_qspi_ctrl, p_mem_addr, SECTOR_SIZE);
            sprintf(s_print_buffer, "R_QSPI_Erase Failed\r\n");
        else
            err = get_flash_status();
                sprintf(s_print_buffer, "Failed to get status for QSPI operation\r\n");
            uint32_t count;
            for (count = 0; count < SECTOR_SIZE; count++ )
                if (DEFAULT_MEM_VAL != p_mem_addr[count])
                    err = FSP_ERR_NOT_ERASED;
        p_mem_addr += SECTOR_SIZE;
        page_write_count++;
    fsp_err = R_GPT_Start(g_memory_performance.p_ctrl);
    if (FSP_SUCCESS != fsp_err)
        SYSTEM_ERROR
    while (((page_write_count * PAGE_WRITE_SIZE) < block_size)
        && (FSP_SUCCESS == err))
            err = R_QSPI_Write(&g_qspi_ctrl, &(sp_source[page_write_count]), p_mem_addr, PAGE_WRITE_SIZE);
                sprintf(s_print_buffer, "R_QSPI_Write Failed\r\n");
            else
        p_mem_addr += PAGE_WRITE_SIZE;
        page_write_count++;
    deinit_qspi(current_spi_mode);
    fsp_err = R_GPT_Stop(g_memory_performance.p_ctrl);
        SYSTEM_ERROR
    fsp_err = R_GPT_StatusGet(g_memory_performance.p_ctrl, &status);
        SYSTEM_ERROR
    fsp_err = R_GPT_Reset(g_memory_performance.p_ctrl);
        SYSTEM_ERROR
    qspi_write_result = status.counter;
    return (qspi_write_result);
qspi数据读取测试程序如下:
static uint32_t qspi_read_test(uint32_t block_size)
    fsp_err_t fsp_err;
    uint32_t qspi_read_result = 0;
    uint8_t  * p_dma_read_buffer;
    uint32_t   page_read_count;
    block_size *= 1024;
    p_dma_read_buffer = pvPortMalloc(block_size);
    if (NULL == p_dma_read_buffer)
        HeapStats_t pxHeapStats;
        vPortGetHeapStats(&pxHeapStats);
        sprintf(s_print_buffer, "\r\nQSPI malloc operation Failed - Max free mem: %dbytes\r\n",
        pxHeapStats.xSizeOfLargestFreeBlockInBytes);
    err = qpi_init();
        SYSTEM_ERROR
    page_read_count = 0;
    while (((page_read_count * PAGE_WRITE_SIZE) < block_size)
        if ((fsp_err_t) (memcmp (p_mem_addr, &(sp_source[page_read_count]), PAGE_WRITE_SIZE)) != FSP_SUCCESS)
            sprintf(s_print_buffer, "\r\nQSPI operation Failed -> Data read does not match with written data\r\n");
        page_read_count++;
        SYSTEM_ERROR
        SYSTEM_ERROR
        SYSTEM_ERROR
    qspi_read_result = status.counter;
    vPortFree(p_dma_read_buffer);
    return (qspi_read_result);
