sin 1000加上噪声
- import torch
- from torch import nn
- import matplotlib.pyplot as plt
- T = 1000
- time = torch.arange(1, T + 1, dtype=torch.float32)
- x = torch.sin(0.01 * time) + torch.normal(0, 0.2, (T,))
- plt.plot(time.tolist(), x.tolist())
- plt.show()
训练后,进行单步预测
- import torch
- from torch.utils import data
- from torchvision import transforms
- def load_array(data_arrays, batch_size, is_train=True):
- dataset = data.TensorDataset(*data_arrays)
- return data.DataLoader(dataset, batch_size, shuffle=is_train, num_workers=6)
- T = 1000
- # plt.plot(time.tolist(), x.tolist())
- # plt.show()
- tau = 4
- # [996, 4]
- features = torch.zeros((T - tau, tau))
- for i in range(tau):
- # pick up 996 elements of x and then slide 1 element every time
- features[:, i] = x[i: T - tau + i]
- # print(features[:, i])
- # print(features[:, i].shape)
- labels = x[tau:].reshape((-1, 1))
- batch_size, n_train = 16, 600
- train_iter = load_array((features[:n_train], labels[:n_train]),
- batch_size, is_train=True)
- def init_weights(m):
- if type(m) == nn.Linear:
- nn.init.xavier_uniform_(m.weight)
- def get_net():
- net = nn.Sequential(nn.Linear(4, 10),
- nn.ReLU(),
- nn.Linear(10, 1))
- net.apply(init_weights)
- return net
- class Accumulator:
- def __init__(self, n) -> None:
- self.data = [0.0]*n
- def add(self, *args):
- # args is a tupe
- self.data = [a + float(b) for a, b in zip(self.data, args)]
- def reset(self):
- self.data = [0.0] * len(self.data)
- def __getitem__(self, idx):
- return self.data[idx]
- def evaluate_loss(net, data_iter, loss):
- metric = Accumulator(2)
- for X, y in data_iter:
- out = net(X)
- y = y.reshape(out.shape)
- l = loss(out, y)
- metric.add(l.sum(), l.numel())
- return metric[0] / metric[1]
- loss = nn.MSELoss(reduction='none')
- def train(net, train_iter, loss, epochs, lr):
- trainer = torch.optim.Adam(net.parameters(), lr)
- for epoch in range(epochs):
- for X, y in train_iter:
- trainer.zero_grad()
- l = loss(net(X), y)
- l.sum().backward()
- trainer.step()
- print(f'epoch {epoch + 1}, '
- f'loss: {evaluate_loss(net, train_iter, loss):f}')
- net = get_net()
- train(net, train_iter, loss, 5, 0.01)
- onestep_preds = net(features)
- plt.plot(time[tau:].tolist(), onestep_preds.tolist())
- plt.show()
