Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Opened \\.\pipe\com_1
Waiting to reconnect...
Connected to Windows XP 2600 x86 compatible target at (Wed Oct 21 11:08:24.024 2009 (GMT+8)), ptr64 FALSE
Kernel Debugger connection established.
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntoskrnl.exe -
Windows XP Kernel Version 2600 UP Free x86 compatible
Built by: 2600.xpsp_sp2_rtm.040803-2158
Machine Name:
Kernel base = 0x804d8000 PsLoadedModuleList = 0x8055bb20
System Uptime: not available
ERROR: DavReadRegistryValues/RegQueryValueExW(4). WStatus = 5
ERROR: DavReadRegistryValues/RegQueryValueExW(5). WStatus = 5
ERROR: DavReadRegistryValues/RegQueryValueExW(6). WStatus = 5
watchdog!WdUpdateRecoveryState: Recovery enabled.
按网上的教材设置的
启动是,先把VM 里的XP ,选到调试启动方式
然后,运行 WINDBG
然后,在VM里的 XP 调试启动方式选项上回车
Connected to Windows XP 2600 x86 compatible target at (Wed Oct 21 16:07:59.732 2009 (GMT+8)), ptr64 FALSE
Symbol search path is: C:\WINDOWS\Symbols;srv*C:\WINDOWS\Symbols*http://msdl.microsoft.com/download/symbols
Machine Name:
