159|0
EMC测试基本环境要求-Mazda MES PW 67602A, MES PW 67602B [复制链接]
标准编号:Mazda  MES PW 67602A, MES PW 67602B
标准名称:Automobile Parts Standard ELECTRONIC COMPONENTS (7.6 7.7 7.8 7.9)
一般环境要求:(b) Environmental test conditions
Unless otherwise specified,
Environmental Test Conditions
Temperature 23± 5 °C
Humidity 20 to 80 % (relative humidity: RH)
静电实验环境要求:ESD The ambient temperature and relative humidity shall be kept at 23±5℃ and 20 % to 40 % respectively in the test facility.
