417|0
【Follow me第二季第2期】 扩展任务二:通过外部SHT40温湿度传感器,上传温湿度到H... [复制链接]
任务步骤:
1.单片机接收传感器数据并打印
2.将数据通过MQTT协议传输到Home Assistant上
1.单片机接收传感器数据并打印
(1)下载“SHT4x”库,使用SHT4test样例测试传感器传输数据到单片机
  This is an example for the SHT4x Humidity & Temp Sensor
  Designed specifically to work with the SHT4x sensor from Adafruit
  ----> https://www.adafruit.com/products/4885
  These sensors use I2C to communicate, 2 pins are required to
  interface
#include "Adafruit_SHT4x.h"
Adafruit_SHT4x sht4 = Adafruit_SHT4x();
void setup() {
  Serial.begin(115200);
  while (!Serial)
    delay(10);     // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit SHT4x test");
  if (! sht4.begin()) {
    Serial.println("Couldn't find SHT4x");
    while (1) delay(1);
  Serial.println("Found SHT4x sensor");
  Serial.print("Serial number 0x");
  Serial.println(sht4.readSerial(), HEX);
  // You can have 3 different precisions, higher precision takes longer
  sht4.setPrecision(SHT4X_HIGH_PRECISION);
  switch (sht4.getPrecision()) {
     case SHT4X_HIGH_PRECISION:
       Serial.println("High precision");
       break;
     case SHT4X_MED_PRECISION:
       Serial.println("Med precision");
       break;
     case SHT4X_LOW_PRECISION:
       Serial.println("Low precision");
       break;
  // You can have 6 different heater settings
  // higher heat and longer times uses more power
  // and reads will take longer too!
  sht4.setHeater(SHT4X_NO_HEATER);
  switch (sht4.getHeater()) {
     case SHT4X_NO_HEATER:
       Serial.println("No heater");
       break;
     case SHT4X_HIGH_HEATER_1S:
       Serial.println("High heat for 1 second");
       break;
     case SHT4X_HIGH_HEATER_100MS:
       Serial.println("High heat for 0.1 second");
       break;
     case SHT4X_MED_HEATER_1S:
       Serial.println("Medium heat for 1 second");
       break;
     case SHT4X_MED_HEATER_100MS:
       Serial.println("Medium heat for 0.1 second");
       break;
     case SHT4X_LOW_HEATER_1S:
       Serial.println("Low heat for 1 second");
       break;
     case SHT4X_LOW_HEATER_100MS:
       Serial.println("Low heat for 0.1 second");
       break;
void loop() {
  sensors_event_t humidity, temp;
  uint32_t timestamp = millis();
  sht4.getEvent(&humidity, &temp);// populate temp and humidity objects with fresh data
  timestamp = millis() - timestamp;
  Serial.print("Temperature: "); Serial.print(temp.temperature); Serial.println(" degrees C");
  Serial.print("Humidity: "); Serial.print(humidity.relative_humidity); Serial.println("% rH");
  Serial.print("Read duration (ms): ");
  Serial.println(timestamp);
  delay(1000);
测试结果:
(1)在Home Assistant上创建传感器主题(各个参数的信息可以在MQTT Sensor查看)
点击“配置”,发送数据包,创建传感器
(2)发送数据包创建传感器数据(通过监听测试发送是否成功)
homeassistant/sensor/SHT40_HUMI/config //创建湿度数据
    "device_class":"humidity",
    "name":"Humidity",
    "state_topic":"homeassistant/SHT40/state",
    "unit_of_measurement":"rH%",
    "value_template":"{{ value_json.humidity}}",
    "unique_id":"hum_HA101",
    "device":{
        "identifiers":[
            "SHT40"
        "name":"SHT40-HUMI_HUMI"
homeassistant/sensor/SHT40_TEMP/config //创建温度数据
    "device_class":"temperature",
    "name":"Temperature",
    "unit_of_measurement":"°C",
    "value_template":"{{ value_json.temperature}}",
    "unique_id":"temp_HA101",
    "device":{
        "identifiers":[
            "SHT40"
        "name":"SHT40-TEMP_TEMP"
测试结果:得到接收湿度数据和温度数据的主体
(3)单片机将传感器的数据传输到HomeAssistant中
  This example connects to a MQTT broker and publishes a message to
  a topic once a second.
  The circuit:
  - Arduino MKR 1000, MKR 1010 or Uno WiFi Rev2 board
  This example code is in the public domain.
#include <ArduinoMqttClient.h>
#include <WiFiS3.h>
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = "一觉睡到日三竿";    // your network SSID (name)
char pass[] = "chen2456594826";    // your network password (use for WPA, or use as key for WEP)
// To connect with SSL/TLS:
// 1) Change WiFiClient to WiFiSSLClient.
// 2) Change port value from 1883 to 8883.
// 3) Change broker value to a server with a known SSL/TLS root certificate
//    flashed in the WiFi module.
WiFiClient wifiClient;
MqttClient mqttClient(wifiClient);
const char broker[] = "192.168.187.230";
int        port     = 1883;
const char topic[]  = "homeassistant/SHT40/state";
const long interval = 1000;
unsigned long previousMillis = 0;
int count = 0;
void setup() {
  //Initialize serial and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // attempt to connect to WiFi network:
  Serial.print("Attempting to connect to WPA SSID: ");
  Serial.println(ssid);
  while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
    // failed, retry
    Serial.print(".");
    delay(5000);
  Serial.println("You're connected to the network");
  printWifiStatus();
  Serial.println();
  // You can provide a unique client ID, if not set the library uses Arduino-millis()
  // Each client must have a unique client ID
   mqttClient.setId("clientIdmurong");
  // You can provide a username and password for authentication
//   mqttClient.setUsernamePassword("arduinoUnoBoard", "arduinoUnoBoard");
  mqttClient.setUsernamePassword("admin", "20030121chen");
  Serial.print("Attempting to connect to the MQTT broker: ");
  Serial.println(broker);
#if 0
  if (!mqttClient.connect(broker, port)) {
    Serial.print("MQTT connection failed! Error code = ");
    Serial.println(mqttClient.connectError());
    while (1);
#endif
while (!mqttClient.connect(broker, port)) {
    delay(100);
  Serial.println("You're connected to the MQTT broker!");
  Serial.println();
  //Following are SHT4x Test
  Serial.println("Adafruit SHT4x Init");
    while (1) delay(1);
       break;
       break;
       break;
       break;
       break;
       break;
       break;
       break;
       break;
       break;
void loop() {
  // call poll() regularly to allow the library to send MQTT keep alives which
  // avoids being disconnected by the broker
  mqttClient.poll();
  // to avoid having delays in loop, we'll use the strategy from BlinkWithoutDelay
  // see: File -> Examples -> 02.Digital -> BlinkWithoutDelay for more info
  unsigned long currentMillis = millis();
  if (currentMillis - previousMillis >= interval) {
    // save the last time a message was sent
    previousMillis = currentMillis;
    Serial.print("Sending message to topic: ");
    Serial.println(topic);
    Serial.println(count);
    // send message, the Print interface can be used to set the message contents
    mqttClient.beginMessage(topic);
    mqttClient.print("{\"humidity\": ");
    mqttClient.print(humidity.relative_humidity);
    mqttClient.print(", \"temperature\": ");
    mqttClient.print(temp.temperature);
    mqttClient.print("}");
    mqttClient.endMessage();
    Serial.println();
    count++;
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
