111|0
33
三伍微 射频开关WiFi   GSR1370S 兼容替代 [复制链接]
三伍微 射频开关WiFi   GSR1370S 兼容替代SKY/RTC/KCT/Qorvo
GSR1370S: CMOS SOI SPDT Switch 0.01 – 7.2 GHz
*WLAN 802.11a/b/g/n/ac/ax networks
* ISM band radios
* Low power T/R systems
*P0.1dB +32dBm typical @ +3.3V
*Low insertion loss (0.50dB @ 2.5GHz, 0.58dB @ 5.8GHz)
* High isolation (25dB @ 2.5GHz)
* Low delay, switch time: 75~125nS
* 1.5mm × 1.5mm QFN Package (MSL3, 260°C per JEDEC-J-STD-020)
Using advanced switching technologies, the GSR1370S is a single pole dual throw (SPDT) high power switch in a low cost miniature 1.5 mm × 1.5 mm package. The GSR1370S is ideally suited for applications where high power, low insertion loss and small size are required. Typical applications are for handset systems that connect separate transmit and receive functions to a common antenna, as well as other related handset and general purpose applications. This part can be used in all systems operating up to 7.2 GHz required high power at low control voltage.
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
