U-Boot 1.1.6 (Apr 13 2009 - 09:09:56)
U-Boot code: 23F00000 -> 23F2CADC BSS: -> 23F8BB28
RAM Configuration:
Bank #0: 20000000 64 MB
NAND: NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended !!
64 MiB
DataFlash:AT45DB161
Nb pages: 4096
Page Size: 528
Size= 2162688 bytes
Logical address: 0xC0000000
Area 0: C0000000 to C0003FFF (RO)
Area 1: C0004000 to C0007FFF
Area 2: C0008000 to C0037FFF (RO)
Area 3: C0038000 to C020FFFF
vga init 0x4::0x20
VGA INIT DONE
[LCD] Initializing LCD frambuffer at 00300000
lcd_init
[LCD] Drawing the logo...
Logo: width 160 height 96 colors 31 cmap 31
In: serial
Out: serial
Err: serial
DM9161A PHY Detected
No link
MAC: error during RMII initialization
### main_loop entered: bootdelay=3
### main_loop: bootcmd=" nand read 0x22200000 0x00000000 0x0017D620; bootm 0x22200000"
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x0, size 0x17d620
nand_read_ecc: eccmode 0
1562144 bytes read: OK
## Booting image at 22200000 ...
Image Name: Linux-2.6.20
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1562080 Bytes = 1.5 MB
Load Address: 20008000
Entry Point: 20008000
Verifying Checksum ... OK
OK
No initrd
## Transferring control to Linux (at address 20008000) ...
Starting kernel ...
Uncompressing Linux...................................................................................................... done, booting the kernel.
Linux version 2.6.20 (root@localhost.localdomain) (gcc version 3.4.5) #215 Fri Apr 17 20:33:13 CST 2009
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: Atmel AT91SAM9263-EK
Ignoring unrecognised tag 0x54410008
Memory policy: ECC disabled, Data cache writeback
Clocks: CPU 200 MHz, master 100 MHz, main 16.000 MHz
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Built 1 zonelists. Total pages: 16256
Kernel command line: mem=64M console=ttyS0,115200 initrd=0x21100000,25165824 root=/dev/mtdblock2 rw init=linuxrc
AT91: 160 gpio irqs in 5 banks
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x30
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 37016KB available (2876K code, 275K data, 120K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 2048 bind 1024)
TCP reno registered
checking if image is initramfs...it isn't (bad gzip magic numbers); looks like an initrd
Freeing initrd memory: 24576K
NetWinder Floating Point Emulator V0.97 (double precision)
NTFS driver 2.1.28 [Flags: R/W DEBUG].
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler anticipatory registered (default)
atmel_lcdfb atmel_lcdfb.0: atmel_lcdfb_probe BEGIN
atmel_lcdfb atmel_lcdfb.0: atmel_lcdfb_check_var:
atmel_lcdfb atmel_lcdfb.0: resolution: 1024x768
atmel_lcdfb atmel_lcdfb.0: pixclk: 48902 KHz
atmel_lcdfb atmel_lcdfb.0: bpp: 16
atmel_lcdfb atmel_lcdfb.0: clk: 100000 KHz
atmel_lcdfb atmel_lcdfb.0: atmel_lcdfb_probe::map=00000000
atmel_lcdfb atmel_lcdfb.0: 1536KiB frame buffer at 21200000 (mapped at ffc00000)
atmel_lcdfb atmel_lcdfb.0: atmel_lcdfb_set_par:
atmel_lcdfb atmel_lcdfb.0: * resolution: 1024x768 (1024x768 virtual)
atmel_lcdfb atmel_lcdfb.0: * update DMA engine
atmel_lcdfb atmel_lcdfb.0: * LCDCON2 = 80008682
atmel_lcdfb atmel_lcdfb.0: * LCDTIM1 = 00001401
atmel_lcdfb atmel_lcdfb.0: * LCDTIM2 = 08a00945
atmel_lcdfb atmel_lcdfb.0: * re-enable DMA engine
atmel_lcdfb atmel_lcdfb.0: * re-enable LCDC core
DONE
atmel_lcdfb atmel_lcdfb.0: * DONE
atmel_lcdfb atmel_lcdfb.0: fb0: Atmel LCDC at 0x00700000 (mapped at c485c000), irq 26
atmel_usart.0: ttyS0 at MMIO 0xfeffee00 (irq = 1) is a ATMEL_SERIAL
atmel_usart.1: ttyS1 at MMIO 0xfff8c000 (irq = 7) is a ATMEL_SERIAL
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
loop: loaded (max 8 devices)
nbd: registered device at major 43
PPP generic driver version 2.4.2
macb macb: detected PHY at address 0 (ID 0181:b8a0)
eth0: Atmel MACB at 0xfffbc000 irq 21 (00:00:00:00:00:00)
block2mtd: version $Revision: 1.30 $
Scanning device for bad blocks
Creating 2 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x00000000-0x00300000 : "Partition 1"
0x00300000-0x04000000 : "Partition 2"
atmel_spi atmel_spi.0: Atmel SPI Controller at 0xfffa4000 (irq 14)
at91_ohci at91_ohci: AT91 OHCI
at91_ohci at91_ohci: new USB bus registered, assigned bus number 1
at91_ohci at91_ohci: irq 29, io mem 0x00a00000
usb usb1: Product: AT91 OHCI
usb usb1: Manufacturer: Linux 2.6.20 ohci_hcd
usb usb1: SerialNumber: at91
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
udc: at91_udc version 3 May 2006
mice: PS/2 mouse device common for all mice
ads7846 spi0.3: touchscreen, irq 31
input: ADS784x Touchscreen as /class/input/input0
i2c /dev entries driver
AT91 MMC: 4 wire bus mode not supported by this driver - using 1 wire
Advanced Linux Sound Architecture Driver Version 1.0.14rc1 (Tue Jan 09 09:56:17 2007 UTC).
AC97C regs = FFFA0000
AC97C irq = 18
at91-ac97: codec read timeout
<4>at91-ac97: codec read timeout
<6>ALSA device list:
#0: Atmel AC97 Controller at 0xfffa0000, irq 18
TCP cubic registered
NET: Registered protocol family 17
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
RAMDISK: Couldn't find valid RAM disk image starting at 0.
VFS: Mounted root (cramfs filesystem) readonly.
Freeing init memory: 120K
mount /etc as ramfs
linuxrc: line 12: cannot create /proc/sys/kernel/hotplug: nonexistent directory
mount: mounting none on /dev/pts failed
mount: mounting tmpfs on /dev/shm failed
init started: BusyBox v1.6.0 (2008-01-09 17:10:28 CST) multi-call binary
starting pid 772, tty '': '/etc/init.d/rcS'
ifconfig: SIOCSIFFLAGS: Cannot assign requested address
eth0: link down
Please press Enter to activate this console.【这个地方有时会出现Error -3 while decompressing! 错误】 [9;0][?33l[?25lWarning: Generating '/usr/etc/dict/words' dawg from word list.
Warning: could not register server
QDir::readDirEntries: Cannot read the directory: /usr/lib/ipkg/externinfo
这时正常启动时的信息,出错一般是在启动QTE时
