1261|0
504
【NUCLEO H533RE】ECC384 PKA模块测试 [复制链接]
完整的工程间附件,替换\STM32Cube_FW_H5_V1.2.0\Projects\NUCLEO-H533RE\Applications\ThreadX\Tx_Thread_Creation
Tx_Thread_Creation.zip (576.87 KB, 下载次数: 2)
  • 前言
前一篇我们体验了HASH384算法,这一篇继续安全相关加速器的ECC384. PKA模块。测试硬件计算。
  • ECC-384
ECC384原理见https://www.rfc-editor.org/rfc/rfc5639
https://wiki.openssl.org/index.php/Elliptic_Curve_Cryptography
三.软件算法
参考英飞凌的
micro-ecc项目
https://github.com/kmackay/micro-ecc
git clone https://github.com/kmackay/micro-ecc
  • STM32硬件驱动
添加驱动文件
stm32h5xx_hal_pka.c
stm32h5xx_hal_rng_ex.c
stm32h5xx_hal_rng.c
stm32h5xx_hal_conf.h中取消注释
#define HAL_PKA_MODULE_ENABLED
#define HAL_RNG_MODULE_ENABLED
MSP初始化 PKA和RNG
* @brief PKA MSP Initialization
* This function configures the hardware resources used in this example
* @param hpka: PKA handle pointer
* @retval None
void HAL_PKA_MspInit(PKA_HandleTypeDef* hpka)
  if(hpka->Instance==PKA)
  /* USER CODE BEGIN PKA_MspInit 0 */
  /* USER CODE END PKA_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_PKA_CLK_ENABLE();
  /* USER CODE BEGIN PKA_MspInit 1 */
  /* USER CODE END PKA_MspInit 1 */
* @brief PKA MSP De-Initialization
* This function freeze the hardware resources used in this example
* @retval None
void HAL_PKA_MspDeInit(PKA_HandleTypeDef* hpka)
  /* USER CODE BEGIN PKA_MspDeInit 0 */
  /* Enable PKA reset state */
  __HAL_RCC_PKA_FORCE_RESET();
  /* Release PKA from reset state */
  __HAL_RCC_PKA_RELEASE_RESET();
  /* USER CODE END PKA_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_PKA_CLK_DISABLE();
  /* USER CODE BEGIN PKA_MspDeInit 1 */
  /* USER CODE END PKA_MspDeInit 1 */
* @brief RNG MSP Initialization
* @param hrng: RNG handle pointer
* @retval None
void HAL_RNG_MspInit(RNG_HandleTypeDef* hrng)
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
  if(hrng->Instance==RNG)
  /* USER CODE BEGIN RNG_MspInit 0 */
  /* USER CODE END RNG_MspInit 0 */
  /** Initializes the peripherals clock
    PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RNG;
    PeriphClkInitStruct.RngClockSelection = RCC_RNGCLKSOURCE_HSI48;
    if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
      Error_Handler();
    __HAL_RCC_RNG_CLK_ENABLE();
    /* RNG interrupt Init */
    HAL_NVIC_SetPriority(RNG_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(RNG_IRQn);
  /* USER CODE BEGIN RNG_MspInit 1 */
  /* USER CODE END RNG_MspInit 1 */
* @brief RNG MSP De-Initialization
* @retval None
void HAL_RNG_MspDeInit(RNG_HandleTypeDef* hrng)
  /* USER CODE BEGIN RNG_MspDeInit 0 */
  /* USER CODE END RNG_MspDeInit 0 */
    __HAL_RCC_RNG_CLK_DISABLE();
    /* RNG interrupt DeInit */
    HAL_NVIC_DisableIRQ(RNG_IRQn);
  /* USER CODE BEGIN RNG_MspDeInit 1 */
  /* USER CODE END RNG_MspDeInit 1 */
PKA_HandleTypeDef hpka;
RNG_HandleTypeDef hrng;
RNG初始化
  hrng.Instance = RNG;
  hrng.Init.ClockErrorDetection = RNG_CED_ENABLE;
  if (HAL_RNG_Init(&hrng) != HAL_OK)
    Error_Handler();
PKA初始化
  hpka.Instance = PKA;
  if (HAL_PKA_Init(&hpka) != HAL_OK)
    Error_Handler();
计算
PKA_ECDSASignInTypeDef in = {0};
PKA_ECDSASignOutTypeDef out = {0};
  /* Set input parameters */
  in.primeOrderSize =  prime256v1_Order_len;
  in.modulusSize =     prime256v1_Prime_len;
  in.coefSign =        prime256v1_A_sign;
  in.coef =            prime256v1_absA;
  in.coefB =           prime256v1_B;
  in.modulus =         prime256v1_Prime;
  in.basePointX =      prime256v1_GeneratorX;
  in.basePointY =      prime256v1_GeneratorY;
  in.primeOrder =      prime256v1_Order;
  in.integer =         SigGen_k;
  in.hash =            SigGen_Hash_Msg;
  in.privateKey =      SigGen_d;
  /* Launch the verification */
  if(HAL_PKA_ECDSASign(&hpka, &in, 5000) != HAL_OK)
    Error_Handler();
  /* Allocate required space */
  out.RSign = malloc(prime256v1_Order_len);
  out.SSign = malloc(prime256v1_Order_len);
  if(out.RSign == NULL || out.SSign == NULL)
    /* Not enough memory in heap */
    Error_Handler();
  /* Copy the result to allocated space */
  HAL_PKA_ECDSASign_GetResult(&hpka , &out, NULL);
  /* Compare to expected result */
  if (memcmp(out.RSign, SigGen_R, SigGen_R_len) != 0)
    Error_Handler();
  if (memcmp(out.SSign, SigGen_S, SigGen_S_len) != 0)
    Error_Handler();
  /* Deinitialize the PKA */
  if(HAL_PKA_DeInit(&hpka) != HAL_OK)
    Error_Handler();
中断处理
extern RNG_HandleTypeDef hrng;
  * @brief This function handles RNG global interrupt.
void RNG_IRQHandler(void)
  /* USER CODE BEGIN RNG_IRQn 0 */
  /* USER CODE END RNG_IRQn 0 */
  HAL_RNG_IRQHandler(&hrng);
  /* USER CODE BEGIN RNG_IRQn 1 */
  /* USER CODE END RNG_IRQn 1 */
  • 测试
shell_func.c中
#include "prime256v1.c"
#include "SigGen.c"
申明实现函数
static void hw_pkatest_func(uint8_t* param);
新增命令用于计算
  { (uint8_t*)"hw_pkatest",   hw_pkatest_func,  (uint8_t*)"hw_pkatest testtimes"},
实现如下
uint8_t outRSign[32];
uint8_t outSSign[32];
//out.RSign = malloc(prime256v1_Order_len);
//out.SSign = malloc(prime256v1_Order_len);
out.RSign = outRSign;
out.SSign = outSSign;
xprintf("test RSign err\r\n");
else
xprintf("test RSign ok\r\n");
xprintf("test SSign err\r\n");
else
xprintf("test SSign ok\r\n");
if(HAL_RNG_DeInit(&hrng) != HAL_OK)
测试如下
hw_pkatest
  • 总结
以上测试了PKA加速计算,使用硬件加速计算运算很快,接口也很简单。
注意一定要使能HSI48时钟
SystemClock_Config中
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI48|RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
驱动这里可以优化下,既然依赖于时钟HSI48那么使用对应的驱动时就应该自动使能。
此帖出自stm32/stm8论坛
