882|3
441
【兆易GD32H759I-EVAL】 SDRAM通道1读写测试 [复制链接]
外扩SDRAM1,测试读写数据。
一、硬件部分
1.1、DIY外扩转接板,SDRAM1电路图部分如下:
1.2、接口部分:
1.3、PCB效果图:
1.4、焊接SDRAM芯片
助焊剂有点多,板子看着有点脏。总线布线没有等长设计,运行频率高有时会有数据错误,需要降低SDRAM时钟频率或等长布线。
1.5、EXMC总线内部框图
1.6、SDRAM1地址
二、测试程序
2.1、gd32h7xxi_eval_exmc_sdram.c
    \file    gd32h7xxi_eval_exmc_sdram.c
    \brief   exmc write or read sdram functions
    \version 2024-01-05, V1.2.0, firmware for GD32H7xx
    Copyright (c) 2024, GigaDevice Semiconductor Inc.
    Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
    1. Redistributions of source code must retain the above copyright notice, this
       list of conditions and the following disclaimer.
    2. Redistributions in binary form must reproduce the above copyright notice,
       this list of conditions and the following disclaimer in the documentation
       and/or other materials provided with the distribution.
    3. Neither the name of the copyright holder nor the names of its contributors
       may be used to endorse or promote products derived from this software without
       specific prior written permission.
    THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
OF SUCH DAMAGE.
//#include "drv_usb_hw.h"
#include "gd32h759i_eval_exmc_sdram.h"
/* define mode register content */
/* burst length */
#define SDRAM_MODEREG_BURST_LENGTH_1             ((uint16_t)0x0000)
#define SDRAM_MODEREG_BURST_LENGTH_2             ((uint16_t)0x0001)
#define SDRAM_MODEREG_BURST_LENGTH_4             ((uint16_t)0x0002)
#define SDRAM_MODEREG_BURST_LENGTH_8             ((uint16_t)0x0003)
/* burst type */
#define SDRAM_MODEREG_BURST_TYPE_SEQUENTIAL      ((uint16_t)0x0000)
#define SDRAM_MODEREG_BURST_TYPE_INTERLEAVED     ((uint16_t)0x0008)
/* cas latency */
#define SDRAM_MODEREG_CAS_LATENCY_2              ((uint16_t)0x0020)
#define SDRAM_MODEREG_CAS_LATENCY_3              ((uint16_t)0x0030)
/* write mode */
#define SDRAM_MODEREG_WRITEBURST_MODE_PROGRAMMED ((uint16_t)0x0000)
#define SDRAM_MODEREG_WRITEBURST_MODE_SINGLE     ((uint16_t)0x0200)
#define SDRAM_MODEREG_OPERATING_MODE_STANDARD    ((uint16_t)0x0000)
#define SDRAM_TIMEOUT                            ((uint32_t)0x0000FFFF)
    \brief    sdram peripheral initialize
    \param[in]  sdram_device: specify the SDRAM device
    \param[out] none
    \retval     none
void exmc_synchronous_dynamic_ram_init(uint32_t sdram_device)
    exmc_sdram_parameter_struct sdram_init_struct;
    exmc_sdram_timing_parameter_struct sdram_timing_init_struct;
    exmc_sdram_command_parameter_struct sdram_command_init_struct;
    uint32_t command_content = 0, bank_select;
    uint32_t timeout = SDRAM_TIMEOUT;
    /* enable EXMC clock*/
    rcu_periph_clock_enable(RCU_EXMC);
    rcu_periph_clock_enable(RCU_GPIOA);
		rcu_periph_clock_enable(RCU_GPIOB);
    rcu_periph_clock_enable(RCU_GPIOC);
    rcu_periph_clock_enable(RCU_GPIOD);
    rcu_periph_clock_enable(RCU_GPIOE);
    rcu_periph_clock_enable(RCU_GPIOF);
    rcu_periph_clock_enable(RCU_GPIOG);
    rcu_periph_clock_enable(RCU_GPIOH);
		//add
		/* SDNE1(PB6),SDCKE1(PH7) pin configuration */
    gpio_af_set(GPIOB, GPIO_AF_12, GPIO_PIN_6);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_6);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_85MHZ, GPIO_PIN_6);
		gpio_af_set(GPIOH, GPIO_AF_12, GPIO_PIN_7);
    gpio_mode_set(GPIOH, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_7);
    gpio_output_options_set(GPIOH, GPIO_OTYPE_PP, GPIO_OSPEED_85MHZ, GPIO_PIN_7);
    /* common GPIO configuration */
    /* SDNE0(PC2),SDCKE0(PC3) pin configuration */
    gpio_af_set(GPIOC, GPIO_AF_12, GPIO_PIN_2 | GPIO_PIN_3);
    gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_2 | GPIO_PIN_3);
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_85MHZ, GPIO_PIN_2 | GPIO_PIN_3);
    /* D12(PC0) pin configuration */
    gpio_af_set(GPIOC, GPIO_AF_1, GPIO_PIN_0);
    gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_0);
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_85MHZ, GPIO_PIN_0);
    /* D2(PD0),D3(PD1),D13(PD8),D14(PD9),D15(PD10),D0(PD14),D1(PD15) pin configuration */
    gpio_af_set(GPIOD, GPIO_AF_12, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_8 | GPIO_PIN_9 |
                GPIO_PIN_10 | GPIO_PIN_14 | GPIO_PIN_15);
    gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_0  | GPIO_PIN_1  | GPIO_PIN_8 | GPIO_PIN_9 |
    gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_85MHZ, GPIO_PIN_0  | GPIO_PIN_1  | GPIO_PIN_8 | GPIO_PIN_9 |
    /* NBL0(PE0),NBL1(PE1),D4(PE7),D5(PE8),D6(PE9),D7(PE10),D8(PE11),D9(PE12),D10(PE13),D11(PE14) pin configuration */
    gpio_af_set(GPIOE, GPIO_AF_12, GPIO_PIN_0  | GPIO_PIN_1  | GPIO_PIN_7  | GPIO_PIN_8 |
                GPIO_PIN_9  | GPIO_PIN_10 | GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_13 |
                GPIO_PIN_14);
    gpio_mode_set(GPIOE, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_0  | GPIO_PIN_1  | GPIO_PIN_7  | GPIO_PIN_8 |
                  GPIO_PIN_14);
    gpio_output_options_set(GPIOE, GPIO_OTYPE_PP, GPIO_OSPEED_85MHZ, GPIO_PIN_0  | GPIO_PIN_1  | GPIO_PIN_7  | GPIO_PIN_8 |
                            GPIO_PIN_14);
    /* A0(PF0),A1(PF1),A2(PF2),A3(PF3),A4(PF4),A5(PF5),NRAS(PF11),A6(PF12),A7(PF13),A8(PF14),A9(PF15) pin configuration */
    gpio_af_set(GPIOF, GPIO_AF_12, GPIO_PIN_0  | GPIO_PIN_1  | GPIO_PIN_2  | GPIO_PIN_3  |
                GPIO_PIN_4  | GPIO_PIN_5  | GPIO_PIN_11 | GPIO_PIN_12 |
                GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15);
    gpio_mode_set(GPIOF, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_0  | GPIO_PIN_1  | GPIO_PIN_2  | GPIO_PIN_3  |
    gpio_output_options_set(GPIOF, GPIO_OTYPE_PP, GPIO_OSPEED_85MHZ, GPIO_PIN_0  | GPIO_PIN_1  | GPIO_PIN_2  | GPIO_PIN_3  |
    /* A10(PG0),A11(PG1),A12(PG2),BA0/A14(PG4),BA1/A15(PG5),SDCLK(PG8),NCAS(PG15) pin configuration */
    gpio_af_set(GPIOG, GPIO_AF_12, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_4 |
                GPIO_PIN_5 | GPIO_PIN_8 | GPIO_PIN_15);
    gpio_mode_set(GPIOG, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_4 |
    gpio_output_options_set(GPIOG, GPIO_OTYPE_PP, GPIO_OSPEED_85MHZ, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_4 |
    /* SDNWE(PH5) pin configuration */
    gpio_af_set(GPIOH, GPIO_AF_12, GPIO_PIN_5);
    gpio_mode_set(GPIOH, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_5);
    gpio_output_options_set(GPIOH, GPIO_OTYPE_PP, GPIO_OSPEED_85MHZ, GPIO_PIN_5);
    /* specify which SDRAM to read and write */
    if(EXMC_SDRAM_DEVICE0 == sdram_device) {
        bank_select = EXMC_SDRAM_DEVICE0_SELECT;
    } else {
        bank_select = EXMC_SDRAM_DEVICE1_SELECT;
    /* EXMC SDRAM device initialization sequence --------------------------------*/
    /* Step 1 : configure SDRAM timing registers --------------------------------*/
    /* LMRD: 2 clock cycles */
    sdram_timing_init_struct.load_mode_register_delay = 2;
    /* XSRD: min = 67ns */
    sdram_timing_init_struct.exit_selfrefresh_delay = 12;
    /* RASD: min=42ns , max=120k (ns) */
    sdram_timing_init_struct.row_address_select_delay = 8;
    /* ARFD: min=60ns */
    sdram_timing_init_struct.auto_refresh_delay = 11;
    /* WRD:  min=1 Clock cycles +6ns */
    sdram_timing_init_struct.write_recovery_delay = 2;
    /* RPD:  min=18ns */
    sdram_timing_init_struct.row_precharge_delay = 4;
    /* RCD:  min=18ns */
    sdram_timing_init_struct.row_to_column_delay = 4;
    /* step 2 : configure SDRAM control registers ---------------------------------*/
    sdram_init_struct.sdram_device = sdram_device;
    sdram_init_struct.column_address_width = EXMC_SDRAM_COW_ADDRESS_9;
    sdram_init_struct.row_address_width = EXMC_SDRAM_ROW_ADDRESS_13;
    sdram_init_struct.data_width = EXMC_SDRAM_DATABUS_WIDTH_16B;
    sdram_init_struct.internal_bank_number = EXMC_SDRAM_4_INTER_BANK;
    sdram_init_struct.cas_latency = EXMC_CAS_LATENCY_3_SDCLK;
    sdram_init_struct.write_protection = DISABLE;
    sdram_init_struct.sdclock_config = EXMC_SDCLK_PERIODS_4_CK_EXMC;
    sdram_init_struct.burst_read_switch = ENABLE;
    sdram_init_struct.pipeline_read_delay = EXMC_PIPELINE_DELAY_1_CK_EXMC;
    sdram_init_struct.timing = &sdram_timing_init_struct;
    /* EXMC SDRAM bank initialization */
    exmc_sdram_init(&sdram_init_struct);
    /* step 3 : configure CKE high command---------------------------------------*/
    sdram_command_init_struct.command = EXMC_SDRAM_CLOCK_ENABLE;
    sdram_command_init_struct.bank_select = bank_select;
    sdram_command_init_struct.auto_refresh_number = EXMC_SDRAM_AUTO_REFLESH_1_SDCLK;
    sdram_command_init_struct.mode_register_content = 0;
    /* wait until the SDRAM controller is ready */
    while((exmc_flag_get(sdram_device, EXMC_SDRAM_FLAG_NREADY) != RESET) && (timeout > 0)) {
        timeout--;
    /* send the command */
    exmc_sdram_command_config(&sdram_command_init_struct);
    /* step 4 : insert 10ms delay */
    //usb_mdelay (10);
    /* step 5 : configure precharge all command */
    sdram_command_init_struct.command = EXMC_SDRAM_PRECHARGE_ALL;
    while((exmc_flag_get(sdram_device, EXMC_SDRAM_FLAG_NREADY) != RESET) && (timeout > 0)){
        timeout--;
    /* step 6 : configure Auto-Refresh command */
    sdram_command_init_struct.command = EXMC_SDRAM_AUTO_REFRESH;
    sdram_command_init_struct.auto_refresh_number = EXMC_SDRAM_AUTO_REFLESH_8_SDCLK;
        timeout--;
    /* step 7 : configure load mode register command */
    /* program mode register */
    command_content = (uint32_t)SDRAM_MODEREG_BURST_LENGTH_1        |
                                SDRAM_MODEREG_BURST_TYPE_SEQUENTIAL   |
                                SDRAM_MODEREG_CAS_LATENCY_3           |
                                SDRAM_MODEREG_OPERATING_MODE_STANDARD |
                                SDRAM_MODEREG_WRITEBURST_MODE_SINGLE;
    sdram_command_init_struct.command = EXMC_SDRAM_LOAD_MODE_REGISTER;
    sdram_command_init_struct.mode_register_content = command_content;
        timeout--;
    /* step 8 : set the auto-refresh rate counter */
    /* 64ms, 8192-cycle refresh, 64ms/8192=7.81us */
    /* SDCLK_Freq = SYS_Freq/2 */
    /* (7.81 us * SDCLK_Freq) - 20 */
    exmc_sdram_refresh_count_set(1151);
        timeout--;
    \brief    fill the buffer with specified value
    \param[in]  pbuffer: pointer on the buffer to fill
    \param[in]  buffer_lengh: length of the buffer to fill
    \param[in]  offset: the offset of the buffer
    \param[out] none
    \retval     none
void fill_buffer(uint8_t *pbuffer, uint16_t buffer_lengh, uint16_t offset)
    uint16_t index = 0;
    /* put in global buffer same values */
    for (index = 0; index < buffer_lengh; index++ ){
        pbuffer[index] = index + offset;
    \brief    write a byte buffer(data is 8 bits) to the EXMC SDRAM memory
    \param[in]  sdram_device: specify which a SDRAM memory block is written
    \param[in]  pbuffer: pointer to buffer
    \param[in]  writeaddr: SDRAM memory internal address from which the data will be written
    \param[in]  numbytetowrite: number of bytes to write
    \param[out] none
    \retval     none
void sdram_writebuffer_8(uint32_t sdram_device,uint8_t* pbuffer, uint32_t writeaddr, uint32_t numbytetowrite)
    uint32_t temp_addr;
    /* Select the base address according to EXMC_Bank */
    if(sdram_device == EXMC_SDRAM_DEVICE0){
        temp_addr = SDRAM_DEVICE0_ADDR;
    }else{
        temp_addr = SDRAM_DEVICE1_ADDR;
     /* While there is data to write */
    for(; numbytetowrite != 0; numbytetowrite--){
        /* Transfer data to the memory */
        *(uint8_t *) (temp_addr + writeaddr) = *pbuffer++;
        /* Increment the address*/
        writeaddr += 1;
    \brief    read a block of 8-bit data from the EXMC SDRAM memory
    \param[in]  readaddr: SDRAM memory internal address to read from
    \param[in]  numbytetoread: number of bytes to read
    \param[out] none
    \retval     none
void sdram_readbuffer_8(uint32_t sdram_device,uint8_t* pbuffer, uint32_t readaddr, uint32_t numbytetoread)
    uint32_t temp_addr;
    /* select the base address according to EXMC_Bank */
    }else{
    /* while there is data to read */
    for(; numbytetoread != 0; numbytetoread--){
        /* read a byte from the memory */
        *pbuffer++ = *(uint8_t*) (temp_addr + readaddr);
        /* increment the address */
        readaddr += 1;
2.2、main.c
#include "main.h"
uint16_t sdram1_testdat[1000] __attribute__((at(0XC0000000)));
uint16_t sdram2_testdat[1000] __attribute__((at(0XD0000000)));
void cache_enable(void);
float val_value=0.0;
uint32_t adda;
int main(void)
	uint32_t sd=0;
	cache_enable();
	systick_config();
	exmc_synchronous_dynamic_ram_init(EXMC_SDRAM_DEVICE1);
	exmc_synchronous_dynamic_ram_init(EXMC_SDRAM_DEVICE0);
	init_usart(115200);
	printf("\r\n SDRAM1写入数据!\r\n ");
	for(sd=0;sd<100;sd++)
		sdram1_testdat[sd]=sd;
		printf("%d ",sd);
		if((sd%50)==0)
			printf("\r\n");
	printf("\r\n");
	printf("\r\n SDRAM1读出数据!\r\n ");
		//sdram_testdat[sd]=sd;
		printf("%d ",sdram1_testdat[sd]);
		if((sd%50)==0)
			printf("\r\n");
	printf("\r\n");
	printf("\r\n SDRAM2写入数据!\r\n ");
		sdram2_testdat[sd]=sd;
		printf("%d ",sd);
		if((sd%50)==0)
			printf("\r\n");
	printf("\r\n");
	printf("\r\n SDRAM2读出数据!\r\n ");
		printf("%d ",sdram2_testdat[sd]);
		if((sd%50)==0)
			printf("\r\n");
	printf("\r\n");
	while(1)
		delay_1ms(200);
    /* enable i-cache */
    SCB_EnableICache();
    /* enable d-cache */
    SCB_EnableDCache();
三、测试结果
下载程序后,串口输出测试结果
四、附件
程序源码: gd32h759_prj_eeworld_sdram1.rar (811.71 KB, 下载次数: 4)
怎么让定义的变量在SDRAM里,不会在每个变量后面指定吧?   详情 回复 发表于 2024-8-6 15:37
6992
这是自己设计打版的吗?这测试,可用心了!
嗯,自己设计的转接板。  详情 回复 发表于 2024-7-1 20:49
441
lugl4313820 发表于 2024-7-1 06:35 这是自己设计打版的吗?这测试,可用心了!
嗯,自己设计的转接板。
