809|4
441
【兆易GD32H759I-EVAL】ADC测试 [复制链接]
测试开发板的ADC功能,使用板卡上的VR1电位器来测试ADC功能。
一、硬件部分
1.1、ADC电位器电路
1.2、VREF+引脚
通过JP76跳冒连接VREF+到VDDA。
1.3、PC2_C在手册中的定义
PC2_C只能用于模拟引脚功能。
二、程序部分
2.1、adc.c
#include "main.h"
__IO uint32_t adc_value[4];
static float val_value;
void init_adc(void)
	/* enable GPIO clock */
	rcu_periph_clock_enable(RCU_GPIOC);
	/* enable ADC clock */
	rcu_periph_clock_enable(RCU_ADC2);
	/* config the GPIO as analog mode */
	gpio_mode_set(GPIOC, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_2);
	/* reset ADC */
	adc_deinit(ADC2);
	/* ADC clock config */
	adc_clock_config(ADC2, ADC_CLK_SYNC_HCLK_DIV6);
	/* ADC scan mode enable */
	adc_special_function_config(ADC2, ADC_SCAN_MODE, ENABLE);
	/* ADC data alignment config */
	adc_data_alignment_config(ADC2, ADC_DATAALIGN_RIGHT);
	/* ADC channel length config */
	adc_channel_length_config(ADC2, ADC_REGULAR_CHANNEL, 1);
	/* ADC regular channel config */
	adc_regular_channel_config(ADC2, 0, ADC_CHANNEL_0, 240);
	/* ADC trigger config */
	adc_external_trigger_config(ADC2, ADC_REGULAR_CHANNEL, EXTERNAL_TRIGGER_DISABLE);
	/* enable ADC interface */
	adc_enable(ADC2);
	/* wait for ADC stability */
	delay_1ms(1);
	/* ADC calibration mode config */
	adc_calibration_mode_config(ADC2, ADC_CALIBRATION_OFFSET);
	/* ADC calibration number config */
	adc_calibration_number(ADC2, ADC_CALIBRATION_NUM1);
	/* ADC calibration and reset calibration */
	adc_calibration_enable(ADC2);
uint32_t adc_channel_sample(uint8_t channel)
    adc_regular_channel_config(ADC2, 0U, channel, 240);
    /* ADC software trigger enable */
    adc_software_trigger_enable(ADC2, ADC_REGULAR_CHANNEL);
    /* wait the end of conversion flag */
    while(!adc_flag_get(ADC2, ADC_FLAG_EOC));
    /* clear the end of conversion flag */
    adc_flag_clear(ADC2, ADC_FLAG_EOC);
    /* return regular channel sample value */
    return (adc_regular_data_read(ADC2));
uint32_t  adc_readval(void)
	uint32_t  adv=0;
	adv = adc_channel_sample(ADC_CHANNEL_0);
	return adv;
void adc_test(void)
	delay_1ms(1000);
	adc_value[0] = adc_channel_sample(ADC_CHANNEL_0);
	val_value = (adc_value[0]*3.3)/4096;
	printf(" the data adc_value[0] is %d , var1 voltage : %4.2fV \r\n", adc_value[0], val_value);
2.2、adc.h
#ifndef _ADC_H
#define _ADC_H
void init_adc(void);
void adc_test(void);
uint32_t  adc_readval(void);
#endif
2.3、main.c
#include "main.h"
void cache_enable(void);
int main(void)
	cache_enable();
	systick_config();
	init_usart(115200);
	init_adc();
	while(1)
		adc_test();
    /* enable i-cache */
    SCB_EnableICache();
    /* enable d-cache */
    SCB_EnableDCache();
三、运行结果
下载程序,复位开发板,调整电位器VR1,串口输出采集的电压。
四、附件
测试代码: gd32h759_prj_eeworld.rar (824.38 KB, 下载次数: 5)
我在pc2上给了一个1.2v电压 为什么采集不到数据呢   详情 回复 发表于 2025-1-8 10:10
7044
友商的STM32H7xx是有14、16bit的ADC,不知道这款ADC是多少位?
用户手册介绍,  ADC0/1可配置14位、 12位、 10位或者8位分辨率, ADC2可配置12位、 10位、 8位或者6位分辨率; 这里测试使用ADC2,配置的12位分辨率。  详情 回复 发表于 2024-6-11 09:44
441
lugl4313820 发表于 2024-6-10 18:48 友商的STM32H7xx是有14、16bit的ADC,不知道这款ADC是多少位?
用户手册介绍,
ADC端口配置正常?  详情 回复 发表于 2025-1-8 10:47
441
zz19940910 发表于 2025-1-8 10:10 我在pc2上给了一个1.2v电压 为什么采集不到数据呢
ADC端口配置正常?
