631|2
37
ST NUCLEO-U083RC 使用TIM1通道1和通道2输出互补PWM [复制链接]
一、环境搭建
使用STM32CubeMX生成工程,使用KEIL编译。
二、搭建工程流程
1、选择相应芯片
2、STM32CubeMX选项如下图
因为要做成互补输出的PWM所以通道一作为PWM mode1,通道二作为PWM mode2。
最后点击右上角的GENERATE CODE。
代码如下:
/* USER CODE BEGIN Header */
 * [url=home.php?mod=space&uid=1307177]@File[/url] : main.c
 * [url=home.php?mod=space&uid=159083]@brief[/url] : Main program body
 * [url=home.php?mod=space&uid=1020061]@attention[/url] *
 * Copyright (c) 2024 STMicroelectronics.
 * All rights reserved.
 * This software is licensed under terms that can be found in the LICENSE file
 * in the root directory of this software component.
 * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "tim.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
uint16_t pwm_bri_val1;
uint16_t pwm_freq_val;
uint8_t pwm_dir;
extern TIM_HandleTypeDef htim1;
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
void delay_us(uint16_t us)
  while (us != 0)
    // hal_delay(20);
    __NOP();
    __NOP();
    __NOP();
    __NOP();
    __NOP(); //
    __NOP();
    __NOP();
    __NOP();
    __NOP();
    __NOP(); //
    __NOP();
    __NOP();
    __NOP();
    __NOP();
    __NOP(); //
    __NOP();
    __NOP();
    __NOP();
    __NOP();
    __NOP(); //
    us--;
 * @brief  delay_ms.
void delay_ms(uint16_t ms)
  while (ms != 0)
    delay_us(2600);
    ms--;
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_TIM1_Init();
  /* USER CODE BEGIN 2 */
  pwm_bri_val1 = 0;
  pwm_freq_val = 4445;
  HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1);
  HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_2);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
    delay_ms(500);
    if (pwm_bri_val1 > pwm_freq_val)
      pwm_dir = 0;
      pwm_bri_val1 = pwm_freq_val;
    else if (pwm_bri_val1 == 0)
      pwm_dir = 1;
    if (pwm_dir)
      pwm_bri_val1 += 100;
    else
      pwm_bri_val1 -= 100;
    __HAL_TIM_SetCompare(&htim1, TIM_CHANNEL_1, pwm_bri_val1);
    __HAL_TIM_SetCompare(&htim1, TIM_CHANNEL_2, pwm_freq_val - pwm_bri_val1);
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
  RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_11;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
三、实验效果
89791f558cfea4a68c7dc6ab9c447eaf
此帖出自stm32/stm8论坛
[attach]807953[/attach]     测试效果还是可以滴   详情 回复 发表于 2024-5-12 08:52
6822
测试效果还是可以滴
此帖出自stm32/stm8论坛
37
附件如下
ST NUCLEO-U083RC 使用TIM1通道1和通道2输出互补PWM.zip
17.09 MB, 下载次数: 0
此帖出自stm32/stm8论坛
