687|4
365
[RISC-V]Milk-V开发板测试pwm及波形输出 [复制链接]
邀请:@spacexplorer   @bigbat   @hotsauce1861   @汤权   参与回复
简介
加载pwm模块
[root@cvitek]/mnt/system/ko# ls
3rd                      cv180x_pwm.ko            cv180x_vpss.ko
cfbcopyarea.ko           cv180x_rgn.ko            cv180x_wdt.ko
cfbfillrect.ko           cv180x_rtc.ko            cvi_mipi_rx.ko
cfbimgblt.ko             cv180x_rtos_cmdqu.ko     cvi_vc_driver.ko
cv180x_base.ko           cv180x_saradc.ko         cvi_wiegand.ko
cv180x_clock_cooling.ko  cv180x_sys.ko            cviaudio_core.ko
cv180x_dwa.ko            cv180x_thermal.ko        efivarfs.ko
cv180x_fast_image.ko     cv180x_tpu.ko            fb_ssd1306.ko
cv180x_jpeg.ko           cv180x_vcodec.ko         loadsystemko.sh
cv180x_mon.ko            cv180x_vi.ko             snsr_i2c.ko
insmod /mnt/system/ko/cv180x_pwm.ko
查看设备
[root@cvitek]/sys/class/pwm# ls
pwmchip0   pwmchip12  pwmchip4   pwmchip8
例子:PWM10
原理图
修改pinmux
build\boards\cv180x\cv1800b_sophpi_duo_sd\u-boot\cvi_board_init.c
//PWM10 PINMUX_CONFIG(SD1_GPIO1, PWM_10);
测试
pwm10,也就是pwmchip8的第三个,也就是pwmchip8/pwm2
echo 2 > /sys/class/pwm/pwmchip8/export
echo 1000000 > /sys/class/pwm/pwmchip8/pwm2/period
echo 500000 > /sys/c
lass/pwm/pwmchip8/pwm2/duty_cycle
echo 1 > /sys/class/pwm/pwmchip8/pwm2/enable
真不错,学习学习!   详情 回复 发表于 2024-5-17 13:36
6802
视频效果演示的pwm波形还可以
小板子挺好玩  详情 回复 发表于 2024-4-28 15:51
365
Jacktang 发表于 2024-4-26 07:33 视频效果演示的pwm波形还可以
小板子挺好玩
34
真不错,学习学习!
感谢,希望上面的视频和说明对你有帮助  详情 回复 发表于 2024-6-1 00:17
365
leilei0000 发表于 2024-5-17 13:36 真不错,学习学习!
感谢,希望上面的视频和说明对你有帮助
