1086|1
基于Pytorch的神经网络识别MNIST数据集  [复制链接]
一、首先,下载安装环境:
matplotlib>=3.2.2
numpy>=1.19.5
pandas>=1.1.5
Pillow>=9.0.0
torch>=1.10.1
torchvision>=0.11.2
tqdm>=4.62.3
二、设计一个网络模型
import torch
# 神经网络结构
class CNN(torch.nn.Module):
    def __init__(self):
        super(CNN, self).__init__()
        self.conv1 = torch.nn.Conv2d(1, 10, kernel_size=5)
        self.conv2 = torch.nn.Conv2d(10, 20, kernel_size=5)
        self.pooling = torch.nn.MaxPool2d(2)
        self.fc = torch.nn.Linear(320, 10)
        self.relu = torch.nn.ReLU()
    def forward(self, x):
        batch_size = x.size(0)
        x = self.conv1(x)
        x = self.pooling(x)
        x = self.relu(x)
        x = self.conv2(x)
        x = self.pooling(x)
        x = self.relu(x)
        x = x.view(batch_size, -1)
        x = self.fc(x)
        return x
三、添加数据集
import torch
import os
from PIL import Image
from torch.utils.data import Dataset
class MyMnistDataset(Dataset):
    def __init__(self, root, transform):
        self.myMnistPath = root
        self.imagesData = []
        self.labelsData = []
        self.labelsDict = {}
        self.trans = transform
        self.loadLabelsDate()
        self.loadImageData()
    # 读取标签txt文件,并生成字典
    def loadLabelsDate(self):
        labelsPath = os.path.join(self.myMnistPath, "labels", "labels.txt")
        f = open(labelsPath)
        lines = f.readlines()
        for line in lines:
            name = line.split(' ')[0]
            label = line.split(' ')[1]
            self.labelsDict[name] = int(label)
    # 读取手写图片数据,并将图片数据和对应的标签组合在一起
    def loadImageData(self):
        imagesFolderPath = os.path.join(self.myMnistPath, 'images')
        imageFiles = os.listdir(imagesFolderPath)
        for imageName in imageFiles:
            imagePath = os.path.join(imagesFolderPath, imageName)
            image = Image.open(imagePath)
            grayImage = image.convert("L")
            imageTensor = self.trans(grayImage)
            self.imagesData.append(imageTensor)
            self.labelsData.append(self.labelsDict[imageName])
        self.labelsData = torch.Tensor(self.labelsData)
    # 重写魔法函数
    def __getitem__(self, index):
        return self.imagesData[index], self.labelsData[index]
    # 重写魔法函数
    def __len__(self):
        return len(self.labelsData)
四、训练代码
import os.path
import torch
import argparse
import pandas as pd
import numpy as np
from torch.optim import lr_scheduler
from torchvision import transforms
from torchvision import datasets
from torch.utils.data import DataLoader
from tqdm import tqdm
from model import CNN
def parse_opt():
    parser = argparse.ArgumentParser(description='ResNet-MNIST')
    parser.add_argument('--epochs', type=int, default=30, help='input total epoch')
    parser.add_argument('--batch_size', type=int, default=64, help='dataloader batch size')
    parser.add_argument('--lr', type=float, default=0.001, help='optimizer learning rate')
    parser.add_argument('--weight_decay', type=float, default=0.00001, help='optimizer weight_decay')
    args = parser.parse_args()
    return args
def train(epoch):
    total_loss = 0
    total_correct = 0
    total_data = 0
    global iteration
    model.train()
    train_bar = tqdm(train_loader)
    for data in train_bar:
        images, labels = data
        images, labels = images.to(device), labels.to(device)
        # 梯度清零
        optimizer.zero_grad()
        # 正向传播
        outputs = model(images)
        _, predicted = torch.max(outputs.data, dim=1)
        total_correct += torch.eq(predicted, labels).sum().item()
        # 计算损失
        loss = criterion(outputs, labels)
        total_loss += loss.item()
        # 反向传播
        loss.backward()
        # 权重更新
        optimizer.step()
        total_data += labels.size(0)
        iteration = iteration + 1
        train_bar.desc = "train epoch[{}/{}] loss:{:.3f} iteration:{}".format(epoch + 1,
        args.epochs,
        loss,
        iteration)
    # 更新学习率
    scheduler.step()
    print(optimizer.state_dict()['param_groups'][0]['lr'])
    loss = total_loss / len(train_loader)
    acc = 100 * total_correct / total_data
    train_loss.append(loss)
    train_acc.append(acc)
    print('accuracy on train set:%d %%' % acc)
# 验证函数
def validate(epoch):
    total_loss = 0
    total_correct = 0
    total_data = 0
    with torch.no_grad():
        test_bar = tqdm(test_loader)
        for data in test_bar:
            # 正向传播
            # 计算损失
            # 进度条描述训练进度
            test_bar.desc = "validate epoch[{}/{}]".format(epoch + 1,
                                                           args.epochs)
        validate_loss.append(loss)
        validate_acc.append(acc)
        print('accuracy on validate set:%d %%\n' % acc)
if __name__ == "__main__":
    args = parse_opt()
    device_type = "GPU" if torch.cuda.is_available() else "CPU"
    device = torch.device("cuda:0" if torch.cuda.is_available() else "cpu")
    print("using {} device.".format(device))
    # 由于神经网络中数据对象为tensor,所以需要用transform将普通数据转换为tensor
    transform = transforms.Compose([
        transforms.ToTensor(),
        transforms.Normalize((0.1307,), (0.3081,))
    # 训练数据集,torchvision中封装了数据集的下载方式,调用下面函数就会自动下载
    train_dataset = datasets.MNIST(root='../dataset/', train=True, download=True, transform=transform)
    train_loader = DataLoader(train_dataset, shuffle=True, batch_size=args.batch_size)
    # 测试数据集
    test_dataset = datasets.MNIST(root='../dataset/', train=False, download=True, transform=transform)
    test_loader = DataLoader(test_dataset, shuffle=False, batch_size=args.batch_size)
    # 生成神经网络实例
    model = CNN()
    model.to(device)
    # 损失函数和优化器
    criterion = torch.nn.CrossEntropyLoss()
    optimizer = torch.optim.Adam(model.parameters(), lr=args.lr, weight_decay=args.weight_decay)
    # 设置动态学习率
    scheduler = lr_scheduler.ExponentialLR(optimizer, gamma=0.9)
    train_loss = []
    train_acc = []
    validate_loss = []
    validate_acc = []
    iteration = 1
    for i in range(args.epochs):
        train(i)
        validate(i)
    torch.save(model.state_dict(), "./{}/CNN.pth".format(device_type))
    epoch = np.arange(1, args.epochs + 1)
    dataframe = pd.DataFrame({'epoch': epoch,
                              'train loss': train_loss,
                              'train accuracy': train_acc,
                              'validate loss': validate_loss,
                              'validate accuracy': validate_acc
    dataframe.to_csv(r"./{}/loss&acc.csv".format(device_type))
五、网络训练结果:使用GPU训练
六、网络训练模型权重转换
import torch
# 加载预训练模型
model = CNN()
model.load_state_dict(torch.load("E:\PythonProjects\MNIST-pytorch\CNN\GPU\Mnisty.pth"),strict=False)
# 设置模型为评估模式
# model.eval()
# 输入示例,需符合模型输入要求
dummy_input = torch.randn(1, 1, 28, 28)
# 转换模型为 ONNX 格式
torch.onnx.export(model, dummy_input, "Mnist.onnx", verbose=True, input_names=['input'], output_names=['output'])
Mnisty.pth
35.15 KB, 下载次数: 0
Mnist.onnx
45.96 KB, 下载次数: 0
此帖出自ARM技术论坛
代码增加一些注释呗,,,     详情 回复 发表于 2024-4-23 07:29
6822
代码增加一些注释呗,,,
此帖出自ARM技术论坛
