#AI挑战营第一站# PC基于PyTorch的MNIST模型训练过程与模型转换
很高兴参加这个活动,我使用miniconda进行环境配置,并使用pycharm进行开发,电脑配置是 i5 8300h+ 1050ti.本次训练使用PyTorch,与MNIST数据集。
安装完成后,使用conda命令激活虚拟环境。并使用pycharm进行开发
Conda安装pytorch环境:
conda install pytorch torchvision torchaudio pytorch-cuda=11.8 -c pytorch -c nvidia
定义了一个模型,包含三个卷积层和两个全连接层。每个卷积层后面都跟着一个批量归一化(Batch Normalization)层和ReLU激活函数,然后是一个最大池化层。在全连接层之间,还有一个Dropout层用于防止过拟合。
class OptimizedConvNet(nn.Module):
def __init__(self, num_classes=10):
super(OptimizedConvNet, self).__init__()
self.layer1 = nn.Sequential(
nn.Conv2d(1, 16, kernel_size=5, stride=1, padding=2),
nn.BatchNorm2d(16),
nn.ReLU(),
nn.MaxPool2d(kernel_size=2, stride=2))
self.layer2 = nn.Sequential(
nn.Conv2d(16, 32, kernel_size=5, stride=1, padding=2),
nn.BatchNorm2d(32),
nn.ReLU(),
self.layer3 = nn.Sequential(
nn.Conv2d(32, 64, kernel_size=5, stride=1, padding=2),
nn.BatchNorm2d(64),
nn.ReLU(),
self.fc1 = nn.Linear(3 * 3 * 64, 500)
self.dropout = nn.Dropout(0.5)
self.fc2 = nn.Linear(500, num_classes)
def forward(self, x):
out = self.layer1(x)
out = self.layer2(out)
out = self.layer3(out)
out = out.reshape(out.size(0), -1)
out = self.fc1(out)
out = self.dropout(out)
out = self.fc2(out)
return out
完整代码:(使用GPU进行训练)
import torch
import torch.nn as nn
import torch.optim as optim
from torchvision import datasets, transforms
from torch.utils.data import DataLoader
nn.BatchNorm2d(16),
nn.ReLU(),
nn.BatchNorm2d(32),
nn.ReLU(),
nn.BatchNorm2d(64),
nn.ReLU(),
out = self.fc1(out)
out = self.fc2(out)
return out
# 定义超参数
learning_rate = 0.001
batch_size = 64
num_epochs = 10
# 检查是否有可用的GPU
device = torch.device('cuda' if torch.cuda.is_available() else 'cpu')
# 创建模型,并将模型移动到GPU上
model = OptimizedConvNet(num_classes=10).to(device)
# 定义损失函数和优化器
criterion = nn.CrossEntropyLoss()
optimizer = torch.optim.Adam(model.parameters(), lr=learning_rate)
# 加载MNIST数据集
transform = transforms.Compose([transforms.ToTensor(), transforms.Normalize((0.1307,), (0.3081,))])
train_dataset = datasets.MNIST(root='./data', train=True, download=True, transform=transform)
train_loader = DataLoader(train_dataset, batch_size=64, shuffle=True)
# 加载验证集
valid_dataset = datasets.MNIST(root='./data', train=False, download=True, transform=transform)
valid_loader = DataLoader(valid_dataset, batch_size=64, shuffle=False)
# 初始化最优验证损失为无穷大
best_valid_loss = float('inf')
# 训练模型
for epoch in range(num_epochs):
# 在训练集上训练
model.train()
total_train_loss = 0
for i, (images, labels) in enumerate(train_loader):
images = images.to(device)
labels = labels.to(device)
outputs = model(images)
loss = criterion(outputs, labels)
optimizer.zero_grad()
loss.backward()
optimizer.step()
if (i + 1) % 100 == 0:
print(f'Epoch [{epoch + 1}/10], Step [{i + 1}/{len(train_loader)}], Loss: {loss.item()}')
total_train_loss += loss.item()
average_train_loss = total_train_loss / len(train_loader)
print(f'Epoch: {epoch + 1}, Training Loss: {average_train_loss:.4f}')
# 在验证集上验证
model.eval()
valid_loss = 0.0
with torch.no_grad():
for images, labels in valid_loader:
valid_loss += loss.item()
valid_loss /= len(valid_loader)
print(f'Epoch: {epoch+1}, Validation Loss: {valid_loss:.4f}')
# 如果验证损失有所下降,则保存模型
if valid_loss < best_valid_loss:
best_valid_loss = valid_loss
torch.save(model.state_dict(), 'best_model.pth')
print('Model saved.')
print("Training completed.")
训练过程:
在代码中,每次训练完毕后,保存最佳模型。
模型转ONNX
安装ONNX相关依赖库,运行代码即可转换完毕。
conda install -c conda-forge onnx
import torch
import torchvision
nn.BatchNorm2d(16),
nn.ReLU(),
nn.BatchNorm2d(32),
nn.ReLU(),
nn.BatchNorm2d(64),
nn.ReLU(),
out = self.fc1(out)
out = self.fc2(out)
return out
# 加载模型
model = OptimizedConvNet()
model.load_state_dict(torch.load('best_model.pth'))
model.eval()
# 创建一个模拟输入,这需要和您的模型输入维度相同
# 例如,如果您的模型接收1x28x28的图像作为输入,您可以创建一个相应大小的随机张量
dummy_input = torch.randn(1, 1, 28, 28)
# 导出模型
torch.onnx.export(model, dummy_input, "model.onnx")
补充内容 (2024-5-9 08:56):
准确率补充到楼下了
