777|4
107
【国民技术车规MCU N32A455开发板】 N32A455的 IAP [复制链接]
官网有有个IAP例程,但不是N32A455的,要根据例程改一下
#include "main.h"
#include "n32a455_rcc.h"
#include <stdio.h>
#include <stdint.h>
#include "string.h"
#include "bsp_usart.h"
#include "iap.h"
//f_IAP_start                 启动IAP升级标置
//slot_timer                  定时器定时标置         定事情中断中累计 串口接收到数据则清零
//receive_cnt                 用于计算串口接收到数据数据
//receive_app_done            更新完所有闪存的标志
//RX_buf                      串口接收到的数据的缓存数组
//TIM3 用做定时100微秒 中断中进入更新后检查f_IAP_start 如果启动IAP升级 则检查200毫秒内串口是否收到数据,没有收到则清空RX_buf
#define app_update_flag_addr 0x08005800 //该地址必须超出APP的内容范围。demo的bin内容结束于0x080054F8
#define TRIGGER_IAP_PIN      GPIO_PIN_12
#define TRIGGER_IAP_PORT     GPIOD
uint32_t receive_cnt = 0;
uint8_t  receive_app_done = 0;
uint8_t f_IAP_flashing = 0;
uint8_t f_IAP_start = 0;
uint16_t slot_timer = 0;
uint8_t f_receive_frame = 0;
uint8_t f_final_frame = 0;
        Delay function
void m_delay_ms(uint32_t ms)
	uint32_t us = 0;
	for(; ms!=0; ms--)
		us = 1440;
		while(us--);
        Read Flash
uint32_t FLASH_ReadWord(uint32_t address)
  return *(__IO uint32_t*)address;
 * [url=home.php?mod=space&uid=159083]@brief[/url] Timer3 initialization configuration.
void tim3_init(uint16_t Period, uint16_t Prescaler)
    TIM_TimeBaseInitType timInitStruct;
    NVIC_InitType NVIC_InitStructure;
    RCC_EnableAPB1PeriphClk(RCC_APB1_PERIPH_TIM3, ENABLE);
    timInitStruct.Period    = Period;
    timInitStruct.Prescaler = Prescaler;
    timInitStruct.ClkDiv    = 0;
    timInitStruct.CntMode   = TIM_CNT_MODE_UP;
    TIM_InitTimeBase(TIM3, &timInitStruct);
    TIM_ConfigInt(TIM3, TIM_INT_UPDATE, ENABLE);
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    NVIC_InitStructure.NVIC_IRQChannel                   = TIM3_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority        = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd                = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    TIM_Enable(TIM3, ENABLE);
  * @brief  TIM3 interrupt process function each 100us.Get the TIM2->CNT value, and Calculate the number of pulses by
  the difference of two times. Then take the delta pules into the buffer of last channel and toggle to new channel.
void TIM3_IRQHandler(void)
    if (TIM_GetIntStatus(TIM3, TIM_INT_UPDATE) != RESET)
        TIM_ClrIntPendingBit(TIM3, TIM_INT_UPDATE);
        if(f_IAP_start==1) //Start IAP update
            slot_timer++;
            if(slot_timer>=2000) //200ms no data is issued, clear RX_buf data
                memset(RX_buf,0,256);
                slot_timer = 0;
                receive_cnt = 0;
        else
            slot_timer = 0;
void Trigger_IAP_GPIO_init(void)
    GPIO_InitType GPIO_InitStructure;
    /* Check the parameters */
    RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOD, ENABLE);
		GPIO_InitStructure.Pin        = GPIO_PIN_12;
		GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_IPU;
		GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
		GPIO_InitPeripheral(GPIOD, &GPIO_InitStructure);
int main(void)
	  Trigger_IAP_GPIO_init();
  	tim3_init(99, 71); //72MH/(71+1)=1M Hz; 1M Hz/(99+1)=100us
    USART_Config();
    printf("NZ3601_init success! \r\n");
    while(1)
			   if (GPIO_ReadInputDataBit(GPIOD, GPIO_PIN_12) == Bit_RESET)
					    printf("Enter the upgrade! \r\n");
					    while(receive_app_done == 0) //No APP program, waiting to receive updates
									if(f_IAP_flashing == 1)
											TIM_Enable(TIM3, DISABLE);
											USART_Enable(DEBUG_USARTx, DISABLE);
											IAP_UPDATE_APP(); //Update the received pack package
											f_IAP_flashing = 0;
											f_receive_frame = 0; //Clear the receive frame flag
											if(f_final_frame == 1)
													f_final_frame = 0;
													receive_app_done = 1; //Update is complete
													app_flag_write(0x12345678 ,app_update_flag_addr);//Write IAP upgrade flag
											USART_Enable(DEBUG_USARTx, ENABLE);
				printf("iap_load_app! \r\n");
				if(FLASH_ReadWord(app_update_flag_addr) == 0x12345678) //Whether the power-on detection needs to jump directly
				if(receive_app_done) //App has been updated
						TIM_Enable(TIM3, DISABLE); //Turn off timer interrupt
						printf("APP address:%x\r\n",(FLASH_START_ADDR));
						printf("Start to execute Flash user code!!\r\n");
						SCB->VTOR = FLASH_BASE | 0x4000;	//Set up interrupt vector table before jump
						iap_load_app(FLASH_START_ADDR); //Jump to the start address of the APP, during which it cannot be interrupted by other interrupts, otherwise the jump will fail
				else{
						while(1)printf("receive_app_done OFF\r\n");
有需要可以测测
N32A455_IAP.zip (17.14 MB, 下载次数: 3)
AN_N32G45X_FR_WB series chip IAP upgrade application note_V1.1.zip (8.39 MB, 下载次数: 2)
此帖出自汽车电子论坛
您好楼主 我想请问一下 我移植到G430为什么不能成功跳转呢  详情 回复 发表于 2024-6-19 17:46
6980
楼主只分享了代码,建议亲自试一下IAP的效果如何,附测试的过程视频与截图,你这样的帖子,只算是分享资料!
此帖出自汽车电子论坛
此帖出自汽车电子论坛
你是啥身份,有没有FAE服务你,一般都有现成的  详情 回复 发表于 2024-6-19 20:21
107
柠溪skr 发表于 2024-6-19 17:46 您好楼主 我想请问一下 我移植到G430为什么不能成功跳转呢
此帖出自汽车电子论坛
107
我是根据他的文档改的
此帖出自汽车电子论坛
