3138|4
菜鸟 基于单片机的红外线心率计c程序对吗?敬请大侠指教!!!! [复制链接]
#include
#include
#include
#define uint unsigned int
#define uchar unsigned char
#define ulong unsigned long
#define key P3_4//s3
#define signal P1_3
#define sw P1_6//开关
#define baiwei P2_5
#define shiwei P2_6
#define gewei P2_7
#define lamp1 P1_7
code uchar TABLE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//共阴极
uint num;
bit flag=1;
void chushi(void)
        lamp1=1;
    TMOD=0x11;//16位计数
    TL0=0xDF;
    TH0=0xB1;
    TH1=0x3C;
    TL1=0xAF;
    IE=0x8A;
    IP=0x08;
    TR0=1;
        TR1=1;
void delay1ms(uint count)
     int m,n;
     for(m=0;m          for(n=0;n<60;n++)
void timer0() interrupt 1//5ms扫描一次
    uchar ge,shi,bai;
    TL0=0xDF;
    TH0=0xB1;
        ge=num%10;
    shi=(num/10)%10;
    bai=num/100;
        shiwei=1;
        baiwei=1;
        P0=TABLE[ge];
        gewei=0;
        delay1ms(1);
        gewei=1;
        baiwei=1;
        P0=TABLE[shi];
        shiwei=0;
        delay1ms(1);
        gewei=1;
        shiwei=1;
        P0=TABLE[bai];
        baiwei=0;
        delay1ms(1);
void timer1() interrupt 3//一分钟计时
        uchar i,j;
        TL1=0xAF;
    TH1=0x3C;
    i++;
    if(i==20)
       i=0;
           j++;
           if(j==60)
              j=0;
                  flag=0;
void celiang(void)
   num=0;
   while(sw==1)
      if(key==0)
        while(flag==1)
             TR1=1;
             lamp1=0;
         if(signal==1) delay1ms(20);
         if(signal==1) num++;
         if(signal==0) delay1ms(20);
        while(flag==0)
             TR1=0;
             lamp1=1;
             if(key==0)
                    flag=1;
                num=0;
                        delay1ms(500);
   while(sw==0)
        num=0700308103;
void main(void)
    chushi();
    num=888;
        delay1ms(500);
    while(1)
        celiang();
这样长的程序,要自己去分析,遇到难搞定的问题再来求助,不要把全部程序贴上来  详情 回复 发表于 2009-6-25 16:13
没硬件,很难看的懂的。
学习下。
更要命的是连注释都少...
