891|0
41
【安信可BW16-Kit开发板】BLE应用—温度测量与显示 [复制链接]
   在《【安信可BW16-Kit开发板】DHT11应用》和《【安信可BW16-Kit开发板】WifiWebClient应用》中分别介绍了利用安信可BW16-Kit开发板进行温度测试和wifi应用,本篇介绍一下安信可BW16-Kit开发板在ArduinoIDE下的BLE应用示例。有关BW16-Kit开发板基本性能和Arduino开发环境搭建不在赘述。
一、BLE应用开发示例
  1. 按下图连接好线路,注意BW16-Kit开发板DHT11信号线连接A26引脚。
  1. ArduinoIDE环境下选择开发板为Ameba。
  2. 选择“Tools” -> “Board” -> “Arduino Ameba”
  3. 然后打开AmebaBLE下的DHT over BLEUart示例,“Files”->“Examples” ->“AmebaBLE”->“DHT_over_BLEUart”。
  1. 程序如下
 Example
#include "BLEDevice.h"
#include "DHT.h"
#define UART_SERVICE_UUID      "6E400001-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
#define STRING_BUF_SIZE 100
#define DHTPIN 8
#define DHTTYPE DHT11   // DHT 11
DHT dht(DHTPIN, DHTTYPE);
BLEService UartService(UART_SERVICE_UUID);
BLECharacteristic Rx(CHARACTERISTIC_UUID_RX);
BLECharacteristic Tx(CHARACTERISTIC_UUID_TX);
BLEAdvertData advdata;
BLEAdvertData scndata;
bool notify = false;
void writeCB (BLECharacteristic* chr, uint8_t connID) {
    Serial.print("Characteristic ");
    Serial.print(chr->getUUID().str());
    Serial.print(" write by connection ");
    Serial.println(connID);
    if (chr->getDataLen() > 0) {
        Serial.print("Received string: ");
        Serial.print(chr->readString());
        Serial.println();
void notifCB(BLECharacteristic* chr, uint8_t connID, uint16_t cccd) {
    if (cccd & GATT_CLIENT_CHAR_CONFIG_NOTIFY) {
        Serial.print("Notifications enabled on Characteristic");
        notify = true;
    } else {
        Serial.print("Notifications disabled on Characteristic");
        notify = false;
    Serial.print(" for connection");
void setup() {
    Serial.begin(115200);
    advdata.addFlags();
    advdata.addCompleteName("AMEBA_BLE_DEV");
    scndata.addCompleteServices(BLEUUID(UART_SERVICE_UUID));
    Rx.setWriteProperty(true);
    Rx.setWritePermissions(GATT_PERM_WRITE);
    Rx.setWriteCallback(writeCB);
    Rx.setBufferLen(STRING_BUF_SIZE);
    Tx.setReadProperty(true);
    Tx.setReadPermissions(GATT_PERM_READ);
    Tx.setNotifyProperty(true);
    Tx.setCCCDCallback(notifCB);
    Tx.setBufferLen(STRING_BUF_SIZE);
    UartService.addCharacteristic(Rx);
    UartService.addCharacteristic(Tx);
    BLE.init();
    BLE.configAdvert()->setAdvData(advdata);
    BLE.configAdvert()->setScanRspData(scndata);
    BLE.configServer(1);
    BLE.addService(UartService);
    BLE.beginPeripheral();
    dht.begin();
void loop() {
    float h = dht.readHumidity();
    float t = dht.readTemperature();
    if (isnan(h) || isnan(t)) {
        Serial.println("Failed to read from DHT sensor!");
        return;
    String msg = ("Humidity: " + String((int) h) + "%\t" + "Temperature: " + String((int) t) + "°C\n");
    Tx.writeString(msg);
    if (BLE.connected(0) && notify) {
        Tx.notify(0);
    delay(5000);
二、运行
1、打开手机蓝牙客户端,搜索到蓝牙名为AMEBA_BLE_DEV,并配对;
2、在列表中选择名为“AMEBA_BLE_DEV”,点击进入下面的界面后,选择“UNknown Service”选项;
运行结果如下:
此帖出自RF/无线论坛
