962|2
862
【得捷Follow me第4期】W5500-EVB-Pico PIO UDP收发测试 [复制链接]
1. 新建基础工程并添加Ethernet3库文件到工程目录
2. UDP协议收发代码编辑
Internet 协议集支持一个无连接的传输协议,该协议称为用户数据报协议(UDP,User Datagram Protocol)。UDP 为应用程序提供了一种无需建立连接就可以发送封装的 IP 数据包的方法。
即UDP基于无连接,通过IP地址和端口即可以收发数据。
上代码:
  • #include <Arduino.h>
  • #include <SPI.h> // needed for Arduino versions later than 0018
  • #include <Ethernet3.h>
  • #include <EthernetUdp3.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
  • // Enter a MAC address and IP address for your controller below.
  • // The IP address will be dependent on your local network:
  • byte mac[] = {
  • 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
  • IPAddress ip(192, 168, 2, 177);
  • unsigned int localPort = 8888; // local port to listen on
  • // buffers for receiving and sending data
  • char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
  • char ReplyBuffer[] = "acknowledged"; // a string to send back
  • // An EthernetUDP instance to let us send and receive packets over UDP
  • EthernetUDP Udp;
  • void setup() {
  • Ethernet.setCsPin(17);
  • Ethernet.setRstPin(20);
  • // start the Ethernet and UDP:
  • Ethernet.begin(mac, ip);
  • Udp.begin(localPort);
  • Serial.begin(115200);
  • void loop() {
  • // if there's data available, read a packet
  • int packetSize = Udp.parsePacket();
  • if (packetSize)
  • Serial.print("Received packet of size ");
  • Serial.println(packetSize);
  • Serial.print("From ");
  • IPAddress remote = Udp.remoteIP();
  • for (int i = 0; i < 4; i++)
  • Serial.print(remote[i], DEC);
  • if (i < 3)
  • Serial.print(".");
  • Serial.print(", port ");
  • Serial.println(Udp.remotePort());
  • // read the packet into packetBufffer
  • Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
  • Serial.println("Contents:");
  • Serial.println(packetBuffer);
  • // send a reply, to the IP address and port that sent us the packet we received
  • Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
  • Udp.write(ReplyBuffer);
  • Udp.endPacket();
  • delay(10);
主要步骤:
第一步:定义mac地址、本机ip地址、端口号和EthernetUDP 实例。
第二步:在setup中
初始化/定义cs引脚和rst引脚,
Ethernet.begin(mac, ip);初始化网络参数
Udp.begin(localPort);启动UDP服务器
第三步:在loop中
监听Udp.parsePacket(),如果有数据,进行解析
Udp.read()读取数据并通过串口输出后,再通过Udp.write()函数进行应答。
other:
UDP客户端实例就会以上例子反过来,因为UDP为无连接协议。因此
大概思路就是:
实例化UDP
封装发送数据
通过
    Udp.endPacket();
进行发送
然后解析、读取应答数据
Udp.parsePacket();
需要的话增加超时判断(可能没有应答)即可。
个人签名水不撩不知深浅 人不拼怎知输赢
862
UDP 测试pc端口
个人签名水不撩不知深浅 人不拼怎知输赢
862
udp rp2040串口打印信息:
个人签名水不撩不知深浅 人不拼怎知输赢
福禄克有奖直播:高精度测温赋能电子制造 报名中!
直播时间:2025年2月28日(周五)上午10:00
直播主题:高精度测温赋能电子制造
小伙伴们儿快来报名直播吧~好礼等你拿!
