1139|2
136
【ST NUCLEO-U5A5ZJ-Q开发板测评】-4-图形化配置时钟HCLK [复制链接]
STM32CubeIDE提供了非常便捷的图形化配置U5器件时钟的功能,在HCLK输入器件支持的最高160MHz,然后工具会自动的计算相关参数以达到这个时钟频率。
点击保存后,自动生成代码:
  • * @brief System Clock Configuration
  • * @retval None
  • void SystemClock_Config(void)
  • RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  • RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  • /** Configure the main internal regulator output voltage
  • if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
  • Error_Handler();
  • /** Initializes the CPU, AHB and APB buses clocks
  • RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  • RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  • RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  • RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  • RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  • RCC_OscInitStruct.PLL.PLLMBOOST = RCC_PLLMBOOST_DIV1;
  • RCC_OscInitStruct.PLL.PLLM = 1;
  • RCC_OscInitStruct.PLL.PLLN = 7;
  • RCC_OscInitStruct.PLL.PLLP = 2;
  • RCC_OscInitStruct.PLL.PLLQ = 2;
  • RCC_OscInitStruct.PLL.PLLR = 1;
  • RCC_OscInitStruct.PLL.PLLRGE = RCC_PLLVCIRANGE_1;
  • RCC_OscInitStruct.PLL.PLLFRACN = 24576;
  • if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  • Error_Handler();
  • RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  • |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
  • |RCC_CLOCKTYPE_PCLK3;
  • RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  • RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  • RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  • RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  • RCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV1;
  • if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
  • Error_Handler();
通过串口打印出来HCLK的频率:
  • printf("\r\nSystemCoreClock = %u", SystemCoreClock);
整体来说,使用图形化配置工具来配置时钟是非常方便,快捷,免去了手工计算相关参数等繁琐工作。
不过发现串口打印出来的频率仅有112MHz,为目标时钟频率的70%。
请教一下大佬,是否哪里需要额外设置?
谢谢!
查看本帖全部内容,请登录或者注册
此帖出自stm32/stm8论坛
136
下午重新下载了CubeMx + Keil:
  • * @retval None
  • Error_Handler();
  • RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
  • RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  • RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
  • RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_0;
  • RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
  • RCC_OscInitStruct.PLL.PLLMBOOST = RCC_PLLMBOOST_DIV4;
  • RCC_OscInitStruct.PLL.PLLM = 3;
  • RCC_OscInitStruct.PLL.PLLN = 10;
  • RCC_OscInitStruct.PLL.PLLFRACN = 0;
  • Error_Handler();
  • Error_Handler();
串口输出结果:
160Mhz是可以正常打印出来。看来应该是CubeIDE生成的代码有问题。
此帖出自stm32/stm8论坛
136
使用CubeMX + Keil可以使得时钟HCLK频率达到160MHz,接下来就可以开启第一次Coremark之旅了!
此帖出自stm32/stm8论坛
站长推荐上一条 2/10 下一条
有奖直播 | AI之眼——安森美图像传感器 报名中
直播主题:AI之眼——安森美图像传感器
报名观看直播、直播间提问、填写问卷均有机会获得精美礼品!
