1757|2
7219
195
【ST NUCLEO-U5A5ZJ-Q开发板】第4帖 可配置的14Bit的ADC [复制链接]
之前接触的STM32的芯片大部分都是常规的12bit的ADC
这个STM32U5是14bit的ADC
而且是可以配置的
可以选择配置14Bit还是12bit
不同bit位的采样率是不一样的
看下手册里的参数
工程建立就不多说了
配置下ADC
static void MX_ADC1_Init(void)
  /* USER CODE BEGIN ADC1_Init 0 */
  /* USER CODE END ADC1_Init 0 */
  ADC_ChannelConfTypeDef sConfig = {0};
  /* USER CODE BEGIN ADC1_Init 1 */
  /* USER CODE END ADC1_Init 1 */
  /** Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV2;
  //hadc1.Init.Resolution = ADC_RESOLUTION_14B;
         hadc1.Init.Resolution = ADC_RESOLUTION_12B;
  hadc1.Init.GainCompensation = 0;
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait = DISABLE;
  hadc1.Init.ContinuousConvMode = DISABLE;
  hadc1.Init.NbrOfConversion = 1;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;
  hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
  hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
  hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR;
  hadc1.Init.OversamplingMode = DISABLE;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    Error_Handler();
  /** Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_9;
  sConfig.Rank = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_391CYCLES_5;
  sConfig.SingleDiff = ADC_SINGLE_ENDED;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
    Error_Handler();
换成配置14Bit ADC
修改一下
通过仿真查看下,我们定点采样的结果
14bit
12bit ADC
常规的采样结果肯定是差不多的
此帖出自stm32/stm8论坛
大佬示例一下DMA采样呀,这DMA有点小麻烦。   详情 回复 发表于 2024-2-8 13:19
点赞 关注(1)
6993
此帖出自stm32/stm8论坛
这个芯片 DMA和stm32其他的不一样? 我都没研究过 还是大佬你眼力尖啊  详情 回复 发表于 2024-2-8 14:33
7219
195
lugl4313820 发表于 2024-2-8 13:19 大佬示例一下DMA采样呀,这DMA有点小麻烦。
此帖出自stm32/stm8论坛
