【得捷电子Follow me第4期】基础任务一:静态IP配置,ping通,抓取报文
【Follow me 第4期任务】基础任务一:完成主控板W5500初始化(静态IP配置),并能使用局域网电脑ping通,同时W5500可以ping通互联网站点;通过抓包软件(Wireshark、Sniffer等)抓取本地PC的ping报文,展示并分析。
1.静态IP配置
首先给开发板配置静态IP地址:这里借用到官方的现有历程。
from usocket import socket
from machine import Pin,SPI
import network
import time
spi=SPI(0,2_000_000, mosi=Pin(19),miso=Pin(16),sck=Pin(18))
nic = network.WIZNET5K(spi,Pin(17),Pin(20))
nic.active(True)
nic.ifconfig(('192.168.2.114','255.255.255.0','192.168.2.1','8.8.8.8'))
print('IP address :', nic.ifconfig())
while not nic.isconnected():
time.sleep(1)
print(nic.regs())
上电,烧录代码调试:
2.使用局域网电脑ping通
使用电脑CMD终端PING配置好的开发板静态IP地址: (Win+R,cmd)
可以看到一切连接正常,电脑可以PING到该地址
3.将开发板的IP 地址显示到屏幕上:
代码如下所示:
from machine import Pin,SPI,PWM
import network
import framebuf
import time
BL = 13
DC = 8
RST = 12
MOSI = 11
SCK = 10
CS = 9
def w5x00_init():
nic.active(True)
time.sleep(1)
print(nic.regs())
class LCD_1inch14(framebuf.FrameBuffer):
def __init__(self):
self.width = 240
self.height = 135
self.cs = Pin(CS,Pin.OUT)
self.rst = Pin(RST,Pin.OUT)
self.cs(1)
self.spi = SPI(1)
self.spi = SPI(1,1000_000)
self.spi = SPI(1,10000_000,polarity=0, phase=0,sck=Pin(SCK),mosi=Pin(MOSI),miso=None)
self.dc = Pin(DC,Pin.OUT)
self.dc(1)
self.buffer = bytearray(self.height * self.width * 2)
super().__init__(self.buffer, self.width, self.height, framebuf.RGB565)
self.init_display()
self.red = 0x07E0
self.green = 0x001f
self.blue = 0xf800
self.white = 0xffff
def write_cmd(self, cmd):
self.cs(1)
self.dc(0)
self.cs(0)
self.spi.write(bytearray([cmd]))
self.cs(1)
def write_data(self, buf):
self.cs(1)
self.dc(1)
self.cs(0)
self.spi.write(bytearray([buf]))
self.cs(1)
def init_display(self):
"""Initialize dispaly"""
self.rst(1)
self.rst(0)
self.rst(1)
self.write_cmd(0x36)
self.write_data(0x70)
self.write_cmd(0x3A)
self.write_data(0x05)
self.write_cmd(0xB2)
self.write_data(0x0C)
self.write_data(0x00)
self.write_data(0x33)
self.write_cmd(0xB7)
self.write_data(0x35)
self.write_cmd(0xBB)
self.write_data(0x19)
self.write_cmd(0xC0)
self.write_data(0x2C)
self.write_cmd(0xC2)
self.write_data(0x01)
self.write_cmd(0xC3)
self.write_data(0x12)
self.write_cmd(0xC4)
self.write_data(0x20)
self.write_cmd(0xC6)
self.write_data(0x0F)
self.write_cmd(0xD0)
self.write_data(0xA4)
self.write_data(0xA1)
self.write_cmd(0xE0)
self.write_data(0xD0)
self.write_data(0x04)
self.write_data(0x0D)
self.write_data(0x11)
self.write_data(0x13)
self.write_data(0x2B)
self.write_data(0x3F)
self.write_data(0x54)
self.write_data(0x4C)
self.write_data(0x18)
self.write_data(0x0B)
self.write_data(0x1F)
self.write_data(0x23)
self.write_cmd(0xE1)
self.write_data(0x44)
self.write_data(0x51)
self.write_data(0x2F)
self.write_cmd(0x21)
self.write_cmd(0x11)
self.write_cmd(0x29)
def show(self):
self.write_cmd(0x2A)
self.write_data(0x28)
self.write_data(0x17)
self.write_cmd(0x2B)
self.write_data(0xBB)
self.write_cmd(0x2C)
self.cs(1)
self.dc(1)
self.cs(0)
self.spi.write(self.buffer)
self.cs(1)
if __name__=='__main__':
pwm = PWM(Pin(BL))
pwm.freq(1000)
pwm.duty_u16(32768)#max 65535
LCD = LCD_1inch14()
#color BRG
LCD.fill(LCD.white)
w5x00_init()
LCD.text("Follow me NO.4",20,20,LCD.red)
LCD.text("Basic Task 1:",20,40,LCD.green)
LCD.text("ping:192.168.2.114",20,60,LCD.red)
LCD.text("by ee_jark",20,80,LCD.blue)
LCD.show()
time.sleep(1)
LCD.fill(0xFFFF)
烧录之后的效果如图:
4.抓取本地PC的ping报文,展示并分析:
在PING开发板的同时,使用Wireshark 抓取PC端PING开发板的包:
可以看到PC端(110)到开发板(114)的完整信息包如下:
以图中第786条为例,分析该报文内容为:
由于作者写到这里的时间有点晚了,先写道这里,开发板PING网站的部分等下一篇文章补充。
