4645|4
WINCE NANDFLASH分区的问题! [复制链接]
大家好,我现在想把NANDFLASH分出来两个FAT分区,我调用了BP_OpenPartition进行分区,但是却始终没有成功!请问哪里错了!
学习  详情 回复 发表于 2009-12-5 15:31
64
BP_OpenPartition参数不正确
BOOL NANDFormatDataStorage(void)
    FlashInfo flashInfo;
    DWORD dwStartBlock, dwNumBlocks;
    DWORD dwIndex;
    // Get NAND flash data bytes per sector.
    if (!FMD_GetInfo(&flashInfo))
        EdbgOutputDebugString("ERROR: Unable to get NAND flash information.\r\n");
        return(FALSE);
    // Calculate the physical block range for the NK image
        dwStartBlock = IMAGE_BOOT_RECOVERY_NAND_OFFSET / flashInfo.dwBytesPerBlock;
    dwNumBlocks = flashInfo.dwNumBlocks - dwStartBlock;
    KITLOutputDebugString("\r\nReserving System Blocks... (Block ID: 0 - 0x%x) \r\n", dwStartBlock);
    for (dwIndex = 0; dwIndex < dwStartBlock; dwIndex++)
        FMD_SetBlockStatus(dwIndex, (BLOCK_STATUS_READONLY | BLOCK_STATUS_RESERVED));
    EdbgOutputDebugString("INFO: Starting format of NAND data storage region.\r\n");
    if (!BP_LowLevelFormat(dwStartBlock, dwNumBlocks, 0))
        EdbgOutputDebugString("\r\nERROR: Unable to format data storage region! \r\n");
    EdbgOutputDebugString("\r\nINFO: Creating partition table... \r\n");
    // Program storage region
    if (BP_OpenPartition((200 * flashInfo.wSectorsPerBlock), 64*500, PART_DOS32 , TRUE,  PART_OPEN_ALWAYS) == INVALID_HANDLE_VALUE)
        EdbgOutputDebugString("\r\nERROR: Fail to create program partition... \r\n");
        return FALSE;
    if (BP_OpenPartition(NEXT_FREE_LOC, USE_REMAINING_SPACE, PART_DOS32, FALSE, PART_OPEN_ALWAYS) == INVALID_HANDLE_VALUE)
        EdbgOutputDebugString("\r\nERROR: Fail to create user storage partition... \r\n");
        return FALSE;
    EdbgOutputDebugString("\r\nINFO: Format of NAND data storage region completed successfully.\r\n");
    return TRUE;
这是我的分区代码,参考一下。
收藏
66
学习
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
