【ACM32G103RCT6开发板测评】+ I2C之OELD驱动测试
测试下使用ACM32G103RCT6硬件i2c驱动OLED显示屏
一、硬件部分
驱动OLED硬件使用了I2C1的PB6和PB7引脚。
二、程序部分
2.1、i2c初始化部分
这部分和上篇https://bbs.eeworld.com.cn/thread-1270022-1-1.html配置一样。
2.2、oled.c
#include "main.h"
#include "oled/oled.h"
#include "oled/codetab.h"
//extern I2C_HandleTypeDef hi2c1;
#define OLED_HANDLE I2C_Handle
void I2C_WriteByte(uint8_t addr, uint8_t dat)
uint8_t temp[2];
temp[0] = dat;
HAL_I2C_Mem_Write(&OLED_HANDLE,OLED_ADDRESS,addr,I2C_MEMADD_SIZE_8BIT,temp,1,10);
void WriteCmd(unsigned char I2C_Command)
I2C_WriteByte(0x00, I2C_Command);
void WriteDat(unsigned char I2C_Data)
I2C_WriteByte(0x40, I2C_Data);
void OLED_WrCmd(unsigned char IIC_Command)
WriteCmd(IIC_Command);
void OLED_Init(void)
HAL_Delay(100);
WriteCmd(0xAE); //display off
WriteCmd(0x20); //Set Memory Addressing Mode
WriteCmd(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
WriteCmd(0xb0); //Set Page Start Address for Page Addressing Mode,0-7
WriteCmd(0xc8); //Set COM Output Scan Direction
WriteCmd(0x00); //---set low column address
WriteCmd(0x10); //---set high column address
WriteCmd(0x40); //--set start line address
WriteCmd(0x81); //--set contrast control register
WriteCmd(0xff); //亮度调节 0x00~0xff
WriteCmd(0xa1); //--set segment re-map 0 to 127
WriteCmd(0xa6); //--set normal display
WriteCmd(0xa8); //--set multiplex ratio(1 to 64)
WriteCmd(0x3F); //
WriteCmd(0xa4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
WriteCmd(0xd3); //-set display offset
WriteCmd(0x00); //-not offset
WriteCmd(0xd5); //--set display clock divide ratio/oscillator frequency
WriteCmd(0xf0); //--set divide ratio
WriteCmd(0xd9); //--set pre-charge period
WriteCmd(0x22); //
WriteCmd(0xda); //--set com pins hardware configuration
WriteCmd(0x12);
WriteCmd(0xdb); //--set vcomh
WriteCmd(0x40); //0x20,0.77xVcc
WriteCmd(0x8d); //--set DC-DC enable
WriteCmd(0x14); //
WriteCmd(0xaf); //--turn on oled panel
void OLED_SetPos(unsigned char x, unsigned char y)
WriteCmd(0xb0+y);
WriteCmd(((x&0xf0)>>4)|0x10);
WriteCmd((x&0x0f)|0x01);
void OLED_Fill(unsigned char fill_Data)//全屏填充
unsigned char m,n;
for(m=0;m<8;m++)
WriteCmd(0xb0+m); //page0-page1
WriteCmd(0x00); //low column start address
WriteCmd(0x10); //high column start address
for(n=0;n<128;n++)
WriteDat(fill_Data);
void OLED_CLS(void)//清屏
OLED_Fill(0xff);
void OLED_ON(void)
WriteCmd(0X8D); //设置电荷泵
WriteCmd(0X14); //开启电荷泵
WriteCmd(0XAF); //OLED唤醒
void OLED_OFF(void)
WriteCmd(0X10); //关闭电荷泵
WriteCmd(0XAE); //OLED休眠
void OLED_ShowStr(unsigned char x, unsigned char y, unsigned char ch[], unsigned char TextSize)
unsigned char c = 0,i = 0,j = 0;
switch(TextSize)
case 1:
while(ch[j] != '\0')
c = ch[j] - 32;
if(x > 126)
x = 0;
y++;
OLED_SetPos(x,y);
for(i=0;i<6;i++)
WriteDat(F6x8[c][i]);
x += 6;
j++;
}break;
case 2:
c = ch[j] - 32;
if(x > 120)
x = 0;
y++;
OLED_SetPos(x,y);
for(i=0;i<8;i++)
WriteDat(F8X16[c*16+i]);
OLED_SetPos(x,y+1);
for(i=0;i<8;i++)
WriteDat(F8X16[c*16+i+8]);
x += 8;
j++;
}break;
void OLED_ShowCN(unsigned char x, unsigned char y, unsigned char N)
unsigned char wm=0;
unsigned int adder=32*N;
OLED_SetPos(x , y);
for(wm = 0;wm < 16;wm++)
WriteDat(F16x16[adder]);
adder += 1;
OLED_SetPos(x,y + 1);
adder += 1;
void OLED_DrawBMP(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[])
unsigned int j=0;
unsigned char x,y;
if(y1%8==0)
y = y1/8;
else
y = y1/8 + 1;
for(y=y0;y<y1;y++)
OLED_SetPos(x0,y);
for(x=x0;x<x1;x++)
WriteDat(BMP[j++]);
void oled_test(void)
OLED_Init();
OLED_Fill(0x00);
OLED_ShowStr(0,0,"ACM32G103RCT6",2);
OLED_ShowStr(0,2,"I2C OLED TEST",2);
2.3、main.c
#include "main.h"
int main(void)
HAL_Init();
SystemClock_Config();
usart_init(115200);
printf("\r\n\r\n====== ACM32G103 MCU is runing ======\r\nSysCoreClk: %dHz, HCLK:%dHz\r\nPCLK1:%dHz, PCLK2:%dHz\r\n\r\n",g_SystemCoreClock, HAL_RCC_GetHCLKFreq(),HAL_RCC_GetPCLK1Freq(),HAL_RCC_GetPCLK2Freq());
init_led();
init_tim2();
init_key();
I2C_Init();
//adc_test();
//eeprom_test();
oled_test();
while(1)
//HAL_Delay(500);
//led1_tog();
//printf("https://bbs.eeworld.com.cn/\r\n");
三、程序运行
下载程序后,复位开发板,OLED显示如下
