1096|2
441
【ACM32G103RCT6开发板测评】+ ADC测试 [复制链接]
测试下ADC功能,检测PA1端口输入的电压值。
一、ADC内部框图
内部一共有20路ADC输入
测试使用内部IN1,对应的PA1引脚
二、程序部分
2.1、ADC引脚初始化
acm32g103_hal_msp.c
void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
    uint32_t i;
    GPIO_InitTypeDef GPIO_Handle;
    uint32_t ADC_Pin_Map[][3] =
//        { ADC_CHANNEL_0_EN, (uint32_t)GPIOA, GPIO_PIN_0 },
        { ADC_CHANNEL_1_EN, (uint32_t)GPIOA, GPIO_PIN_1 },
//        { ADC_CHANNEL_2_EN, (uint32_t)GPIOA, GPIO_PIN_2 },
//        { ADC_CHANNEL_3_EN, (uint32_t)GPIOA, GPIO_PIN_3 },
//        { ADC_CHANNEL_4_EN, (uint32_t)GPIOA, GPIO_PIN_4 },
//        { ADC_CHANNEL_5_EN, (uint32_t)GPIOA, GPIO_PIN_5 },
//        { ADC_CHANNEL_6_EN, (uint32_t)GPIOA, GPIO_PIN_6 },
//        { ADC_CHANNEL_7_EN, (uint32_t)GPIOA, GPIO_PIN_7 },
//        { ADC_CHANNEL_8_EN, (uint32_t)GPIOB, GPIO_PIN_0 },
//        { ADC_CHANNEL_9_EN, (uint32_t)GPIOB, GPIO_PIN_1 },
//        { ADC_CHANNEL_10_EN, (uint32_t)GPIOC, GPIO_PIN_0 },
//        { ADC_CHANNEL_11_EN, (uint32_t)GPIOC, GPIO_PIN_1 },
//        { ADC_CHANNEL_12_EN, (uint32_t)GPIOC, GPIO_PIN_2 },
//        { ADC_CHANNEL_13_EN, (uint32_t)GPIOC, GPIO_PIN_3 },
//        { ADC_CHANNEL_14_EN, (uint32_t)GPIOC, GPIO_PIN_4 },
//        { ADC_CHANNEL_15_EN, (uint32_t)GPIOC, GPIO_PIN_5 },
        { 0xffffffff, 0 }, //结束标志
    __HAL_RCC_GPIOA_CLK_ENABLE();
    __HAL_RCC_GPIOB_CLK_ENABLE();
    __HAL_RCC_GPIOC_CLK_ENABLE();
    //Set gpio to analog.
    for(i = 0; ADC_Pin_Map[i][0] != 0xffffffff; i++)
        if(hadc->Init.ChannelEn & ADC_Pin_Map[i][0])
            GPIO_Handle.Pin            = ADC_Pin_Map[i][2];
            GPIO_Handle.Mode           = GPIO_MODE_ANALOG;
            GPIO_Handle.Pull           = GPIO_NOPULL;
            HAL_GPIO_Init((GPIO_TypeDef *)ADC_Pin_Map[i][1], &GPIO_Handle);
    /* Enable ADC Clock */
    __HAL_RCC_ADC12_CLK_ENABLE();
    /* Clear Pending Interrupt */
    NVIC_ClearPendingIRQ(ADC12_IRQn);
    /* Enable External Interrupt */
    NVIC_EnableIRQ(ADC12_IRQn);
2.2、acm32g103_it.c
#include "main.h"
#include "acm32g103_it.h"
extern TIM_HandleTypeDef tim2_handler;
extern ADC_HandleTypeDef ADC_Handle;
void ADC1_2_IRQHandler(void)
    HAL_ADC_IRQHandler();
2.3、adc.c
#include "main.h"
#define BUFFER_LENGTH    (21)
uint32_t gadcBuffer[BUFFER_LENGTH];                 //ADC Value
//ADC_HandleTypeDef hadc;
void ADC_Init_Polling_Nchannels(void)
    ADC_ChannelConfTypeDef ADC_ChannelConf;
    ADC_Handle.Init.ClockPrescaler = ADC_CLOCK_DIV16;       //ADC_CLK分频选择
    ADC_Handle.Init.Resolution     = ADC_RESOLUTION_12B;    //分辨率
    ADC_Handle.Init.DataAlign      = ADC_DATAALIGN_RIGHT;   //数据对齐
    ADC_Handle.Init.ConConvMode    = DISABLE;               //连续转换模式
    ADC_Handle.Init.DiscontinuousConvMode = DISABLE;        //间断模式
    ADC_Handle.Init.NbrOfDiscConversion   =1;               //间断模式通道计数
    ADC_Handle.Init.ExternalTrigConv = ADC_SOFTWARE_START;  //触发模式:外部触发或软件触发
    ADC_Handle.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;//外部触发边沿选择
    ADC_Handle.Init.DMAMode = ADC_DMAMODE_DISABLE;          //DMA选择
    ADC_Handle.Init.OverMode = ADC_OVERMODE_DISABLE;        //溢出时是否保留上次采样数据
    ADC_Handle.Init.OverSampMode = ADC_OVERSAMPMODE_DISABLE;//过采样使能
    ADC_Handle.Init.Oversampling.Ratio =ADC_OVERSAMPLING_RATIO_2;//过采样率
    ADC_Handle.Init.Oversampling.RightBitShift =ADC_RIGHTBITSHIFT_2;//过采样移位系数
    ADC_Handle.Init.Oversampling.TriggeredMode =0;          //过采样触发模式
    ADC_Handle.Init.AnalogWDGEn = ADC_ANALOGWDGEN_DISABLE;  //模拟看门狗
    ADC_Handle.Init.ChannelEn = ADC_CHANNEL_1_EN;
    ADC_Handle.Instance = ADC1;
    HAL_ADC_Init(&ADC_Handle);
    /* The total adc regular channels number */
    ADC_Handle.ChannelNum = 1;
    ADC_ChannelConf.Channel = ADC_CHANNEL_1;
    ADC_ChannelConf.Sq = ADC_SEQUENCE_SQ1;
    ADC_ChannelConf.Smp = ADC_SMP_CLOCK_320;
    ADC_ChannelConf.SingleDiff = ADC_SINGLE_ENDED;
    ADC_ChannelConf.OffsetNumber = ADC_OFFSET_NONE;
    ADC_ChannelConf.Offset = 0;
    HAL_ADC_ConfigChannel(&ADC_Handle,&ADC_ChannelConf);
void HAL_ADC_IRQCallback(void)
    __IO uint32_t Status;
    Status = ADC_Handle.Instance->SR;
    /************ Check End of Conversion flag for injected ************/
    if(__HAL_ADC_GET_IT_SOURCE(&ADC_Handle, ADC_IE_JEOCIE))
        if((Status & ADC_SR_JEOC) == ADC_SR_JEOC)
            /* Conversion complete callback */
            if (NULL != ADC_Handle.InjectedConvCpltCallback)
                ADC_Handle.InjectedConvCpltCallback(&ADC_Handle);
            /* Clear injected group conversion flag */
            __HAL_ADC_CLEAR_FLAG(&ADC_Handle, ADC_SR_JEOC);
    /************ Check End of Conversion flag for injected group ************/
    if(__HAL_ADC_GET_IT_SOURCE(&ADC_Handle, ADC_IE_JEOGIE))
        if((Status & ADC_SR_JEOG) == ADC_SR_JEOG)
            if(ADC_IS_SOFTWARE_START_INJECTED(&ADC_Handle)    || \
            (ADC_IS_SOFTWARE_START_REGULAR(&ADC_Handle) &&(ADC_Handle.Init.ConConvMode == 0)) && (HAL_IS_BIT_CLR(ADC_Handle.Instance->CR1, ADC_CR1_JAUTO)))
                /* Disable ADC end of conversion interrupt on injected injected */
                __HAL_ADC_DISABLE_IT(&ADC_Handle, ADC_IE_JEOCIE);
        if (NULL != ADC_Handle.InjectedGroupConvCpltCallback)
        ADC_Handle.InjectedGroupConvCpltCallback(&ADC_Handle);
        __HAL_ADC_CLEAR_FLAG(&ADC_Handle, ADC_SR_JEOG);
    /************ Check Conversion flag for regular Channel ************/
    if(__HAL_ADC_GET_IT_SOURCE(&ADC_Handle, ADC_IE_EOCIE))
        if((Status & ADC_SR_EOC) == ADC_SR_EOC)
            if (NULL != ADC_Handle.ConvCpltCallback)
            ADC_Handle.ConvCpltCallback(&ADC_Handle);
            /* Clear conversion flag */
            __HAL_ADC_CLEAR_FLAG(&ADC_Handle, ADC_SR_EOC);
    /************ Check End of Conversion flag for regular group ************/
    if(__HAL_ADC_GET_IT_SOURCE(&ADC_Handle, ADC_IE_EOGIE))
        if((Status & ADC_SR_EOG) == ADC_SR_EOG)
            if((__HAL_ADC_CHECK_TRIG_REGULAR(&ADC_Handle, ADC_SOFTWARE_START)) &&
                /* Disable ADC end of conversion interrupt on group regular */
                __HAL_ADC_DISABLE_IT(&ADC_Handle, ADC_IE_EOGIE);
            if (NULL != ADC_Handle.GroupCpltCallback)
            ADC_Handle.GroupCpltCallback(&ADC_Handle);
            /* Clear regular group conversion flag */
            __HAL_ADC_CLEAR_FLAG(&ADC_Handle, ADC_SR_EOG);
    /************ Check Analog watchdog flags ************/
    if(__HAL_ADC_GET_IT_SOURCE(&ADC_Handle, ADC_IE_AWDIE))
        if((Status & ADC_SR_AWD) == ADC_SR_AWD)
            /* Level out of window callback */
            if (NULL != ADC_Handle.LevelOutOfWindowCallback)
            ADC_Handle.LevelOutOfWindowCallback(&ADC_Handle);
            /* Clear the ADC analog watchdog flag */
            __HAL_ADC_CLEAR_FLAG(&ADC_Handle, ADC_SR_AWD);
void adc_test(void)
	uint32_t i;
	float vol=0.0;
	ADC_Init_Polling_Nchannels();
	while(1)
			for (i = 0; i < BUFFER_LENGTH; i++)
					gadcBuffer[i] = 0;
			HAL_ADC_Polling(&ADC_Handle, gadcBuffer, ADC_Handle.ChannelNum, 0);
			for (i = 0; i < ADC_Handle.ChannelNum; i++)
					vol = (gadcBuffer[i]&0xFFF)*3.3/4095;
					printf("PA1 Voltage is: %0.1f V \r\n", vol);
			HAL_DelayMs(1000);
2.4、main.c
#include "main.h"
int main(void)
	HAL_Init();
	SystemClock_Config();
	usart_init(115200);
	printf("\r\n\r\n====== ACM32G103 MCU is runing ======\r\nSysCoreClk: %dHz, HCLK:%dHz\r\nPCLK1:%dHz, PCLK2:%dHz\r\n\r\n",g_SystemCoreClock, HAL_RCC_GetHCLKFreq(),HAL_RCC_GetPCLK1Freq(),HAL_RCC_GetPCLK2Freq());
	init_led();
	init_tim2();
	init_key();
	adc_test();
	while(1)
 三、运行结果
3.1、硬件连接图
3.2、调节电位器,串口输出
感谢大佬分享ADC的精彩示例,他的ADC那是又快双好!   详情 回复 发表于 2024-1-16 20:26
7042
这个芯片介绍ADC转换速率最高3Msps  详情 回复 发表于 2024-1-16 21:37
441
lugl4313820 发表于 2024-1-16 20:26 感谢大佬分享ADC的精彩示例,他的ADC那是又快双好!
