; Set up the memory control registers.
add r0, pc, #SMRDATA - (. + 8)
ldr r1, =BWSCON ; BWSCON Address.
add r2, r0, #52 ; End address of SMRDATA.
ldr r3, [r0], #4
str r3, [r1], #4
cmp r2, r0
bne %B3
mov r0, #0x2000
subs r0, r0, #1
bne %B4
; Recover Process : Starting Point
; 1. Checksum Calculation saved Data
ldr r5, =SLEEPDATA_BASE_PHYSICAL ; pointer to physical address of reserved Sleep mode info data structure
mov r3, r5 ; pointer for checksum calculation
ldr r2, =0x0
ldr r0, =(SLEEPDATA_SIZE-1) ; get size of data structure to do checksum on
ldr r1, [r3], #4 ; pointer to SLEEPDATA
and r1, r1, #0x1
mov r1, r1, ROR #31
add r2, r2, r1
subs r0, r0, #1 ; dec the count
bne %b50 ; loop till done
ldr r0,=GSTATUS3
ldr r3, [r0] ; get the Sleep data checksum from the Power Manager Scratch pad register
cmp r2, r3 ; compare to what we saved before going to sleep
bne BringUpWinCE ; bad news - do a cold boot
; 2. MMU Enable
ldr r10, [r5, #SleepState_MMUDOMAIN] ; load the MMU domain access info
ldr r9, [r5, #SleepState_MMUTTB] ; load the MMU TTB info
ldr r8, [r5, #SleepState_MMUCTL] ; load the MMU control info
ldr r7, [r5, #SleepState_WakeAddr ] ; load the LR address
nop
nop
nop
nop
nop
; if software reset
mov r1, #0
teq r1, r7
bne %f60
b BringUpWinCE
; Are we waking up from a suspended state?
ldr r1, =GSTATUS2
ldr r0, [r1]
tst r0, #0x2
; Yes? Then go to the resume handler code...
bne WAKEUP_POWER_OFF
ldr r3, [r0], #4
str r3, [r1], #4
cmp r2, r0
bne %B15
; If this is a cold boot or a warm reset, clear RAM because the RAM filesystem may be
; bad. If this is a software reboot (triggered by the watchdog timer), don't clear RAM.
ldr r1, =GSTATUS2 ; Determine why we're in the startup code.
ldr r10, [r1] ;
str r10, [r1] ; Clear GPSTATUS2.
tst r10, #0x4 ; Watchdog (software) reboot? Skip code that clears RAM.
bne %F30
SMRDATA DATA
; Memory configuration should be optimized for best performance .
; The following parameter is not optimized.
; Memory access cycle parameter strategy
; 1) The memory settings is safe parameters even at HCLK=75Mhz.
; 2) SDRAM refresh period is for HCLK=75Mhz.
DCD (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28))
DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC)) ;GCS0
DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC)) ;GCS1
DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC)) ;GCS2
DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC)) ;GCS3
DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC)) ;GCS4
DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC)) ;GCS5
DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN)) ;GCS6
DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN)) ;GCS7
DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT)
DCD (0x32|0x80) ; SCLK power saving mode, BANKSIZE 128M/128M, 4-burst.
