608|4
7228
192
【DigiKey“智造万物,快乐不停”创意大赛】远程监控系统+第5帖 LCD显示 [复制链接]
一LTDC控制器
LTDC全称 LCD-TFT Display Controller,LCD显示控制器,提供了RGB信号和控制信号来直接控制外部LCD显示屏。
一些屏幕称为RGB屏幕,内部没有驱动IC,操作这种屏幕时往往使用MCU内部集成的LCD控制器直接去控制LCD显示,显存空间当然也是在MCU内部,按照空间大小可以选择放在内部SRAM或者外部SDRAM中,如图:
显示应该是这个方式,采用了外置SDRAM
显存指LCD所有像素点数据缓存再传给显示屏,显存的容量至少要能存储显示器一帧的显示数据,分辨率480*272,RGB8888的话,显示一帧数据大小(8+8+8+8)*480*272=4177920bit/8=522,240byte
外置SDRAM
SDRAM采用的地址0xc000 0000
uint8_t BSP_SDRAM_Init(void)
  static uint8_t sdramstatus = SDRAM_ERROR;
  /* SDRAM device configuration */
  sdramHandle.Instance = FMC_SDRAM_DEVICE;
  /* Timing configuration for 100Mhz as SD clock frequency (System clock is up to 200Mhz) */
  Timing.LoadToActiveDelay    = 2;
  Timing.ExitSelfRefreshDelay = 7;
  Timing.SelfRefreshTime      = 4;
  Timing.RowCycleDelay        = 7;
  Timing.WriteRecoveryTime    = 2;
  Timing.RPDelay              = 2;
  Timing.RCDDelay             = 2;
  sdramHandle.Init.SDBank             = FMC_SDRAM_BANK1;
  sdramHandle.Init.ColumnBitsNumber   = FMC_SDRAM_COLUMN_BITS_NUM_8;
  sdramHandle.Init.RowBitsNumber      = FMC_SDRAM_ROW_BITS_NUM_12;
  sdramHandle.Init.MemoryDataWidth    = SDRAM_MEMORY_WIDTH;
  sdramHandle.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4;
  sdramHandle.Init.CASLatency         = FMC_SDRAM_CAS_LATENCY_2;
  sdramHandle.Init.WriteProtection    = FMC_SDRAM_WRITE_PROTECTION_DISABLE;
  sdramHandle.Init.SDClockPeriod      = SDCLOCK_PERIOD;
  sdramHandle.Init.ReadBurst          = FMC_SDRAM_RBURST_ENABLE;
  sdramHandle.Init.ReadPipeDelay      = FMC_SDRAM_RPIPE_DELAY_0;
  /* SDRAM controller initialization */
  BSP_SDRAM_MspInit(&sdramHandle, NULL); /* __weak function can be rewritten by the application */
  if(HAL_SDRAM_Init(&sdramHandle, &Timing) != HAL_OK)
  else
    sdramstatus = SDRAM_OK;
  /* SDRAM initialization sequence */
  BSP_SDRAM_Initialization_sequence(REFRESH_COUNT);
  return sdramstatus;
LCD驱动原理图
背光电源控制IO口为LCD_BL_CTRL即PK3
RGB888(3B):R值8位、G值8位、B值8位
RGB565(2B):R值5位、G值6位、B值5位
显然,RGB888 比 RGB565 表示的颜色更多、LTDC支持RGB888格式,但是RGB888每个像素点需要24bit(3个字节)的显存空间来存储
RK043FN48H的参数
官方推荐的参数配置是这样
  * @brief  RK043FN48H Size
#define  RK043FN48H_WIDTH    ((uint16_t)480)          /* LCD PIXEL WIDTH            */
#define  RK043FN48H_HEIGHT   ((uint16_t)272)          /* LCD PIXEL HEIGHT           */
  * @brief  RK043FN48H Timing
#define  RK043FN48H_HSYNC            ((uint16_t)41)   /* Horizontal synchronization */
#define  RK043FN48H_HBP              ((uint16_t)13)   /* Horizontal back porch      */
#define  RK043FN48H_HFP              ((uint16_t)32)   /* Horizontal front porch     */
#define  RK043FN48H_VSYNC            ((uint16_t)10)   /* Vertical synchronization   */
#define  RK043FN48H_VBP              ((uint16_t)2)    /* Vertical back porch        */
#define  RK043FN48H_VFP              ((uint16_t)2)    /* Vertical front porch       */
还是有一些不一样的,就这么用吧
图形加速器DMA2D
  hDma2dHandler.Init.Mode         = DMA2D_R2M;
  if(hLtdcHandler.LayerCfg[ActiveLayer].PixelFormat == LTDC_PIXEL_FORMAT_RGB565)
  { /* RGB565 format */
    hDma2dHandler.Init.ColorMode    = DMA2D_RGB565;
  else
  { /* ARGB8888 format */
    hDma2dHandler.Init.ColorMode    = DMA2D_ARGB8888;
  hDma2dHandler.Init.OutputOffset = OffLine;
  hDma2dHandler.Instance = DMA2D;
  /* DMA2D Initialization */
  if(HAL_DMA2D_Init(&hDma2dHandler) == HAL_OK)
整个显示过程原理应该是通过LTDC、DMA2D以及存储器,构成一个完整的液晶控制器,LTDC不断刷新液晶屏,DMA2D搬运图像数据、混合及格式转换,外置的SDRAM存储器作为显存。
五 画线
    BSP_LCD_DrawRect(80,120,70,70);
    BSP_LCD_DrawCircle(250,150,70);
    BSP_LCD_DrawEllipse(380,120,30,40);
void BSP_LCD_DrawRect(uint16_t Xpos, uint16_t Ypos, uint16_t Width, uint16_t Height)
  /* Draw horizontal lines */
  BSP_LCD_DrawHLine(Xpos, Ypos, Width);
  BSP_LCD_DrawHLine(Xpos, (Ypos+ Height), Width);
  /* Draw vertical lines */
  BSP_LCD_DrawVLine(Xpos, Ypos, Height);
  BSP_LCD_DrawVLine((Xpos + Width), Ypos, Height);
结果
这个LCD不错 看起来挺大的 我的5寸觉得有点小了  详情 回复 发表于 2023-12-31 23:06
419
图文并茂,这个帖子真是精彩绝伦,让我收获颇丰!!!!
7244
不知道显示摄像头画面能达到多少帧。
这个真不知道 目前只会显示个图片 显示字母 画个线啥的基本操作 传输动态画面这种没玩过  详情 回复 发表于 2024-1-2 13:30
4942
7228
192
wangerxian 发表于 2023-12-31 20:54 不知道显示摄像头画面能达到多少帧。
传输动态画面这种没玩过
