543|1
22
【DigiKey“智造万物,快乐不停”创意大赛】7,TTS功能实现 [复制链接]
TTS功能的实现基于的是edge-tts这个库,这个库是基于爬虫方法进行实现的。
首先是安装这个库:
pip3 install edge-tts
用以下命令可以列出所有支持的语言角色:
edge-tts --list-voices
测试代码如下:
#!/usr/bin/env python3
import edge_tts
import pydub
import io
async def tts(text, actor = "zh-CN-XiaoyiNeural", fmt = "mp3"):
    _voices = await edge_tts.VoicesManager.create()
    _voices = _voices.find(ShortName=actor)
    _communicate = edge_tts.Communicate(text, _voices[0]["Name"])
    _out = bytes()
    async for _chunk in _communicate.stream():
        if _chunk["type"] == "audio":
            # print(chunk["data"])
            _out += _chunk["data"]
        elif _chunk["type"] == "WordBoundary":
            # print(f"WordBoundary: {chunk}")
            pass
    if fmt == "mp3":
        return _out
    if fmt == "wav":
        _raw = pydub.AudioSegment.from_file(io.BytesIO(_out))
        _raw = _raw.set_frame_rate(16000)
        _wav = io.BytesIO()
        _raw.export(_wav, format="wav")
        # for i in range(len(_wav.getvalue())-1,-1,-1):
        #     if _wav.getvalue()[i] != 0x00:
        #         break
        return _wav.getvalue()#[:i+1]
if __name__ == "__main__":
    import asyncio
    import pydub.playback
    while True:
        text_in = input(">说点什么:")
        raw_wav = asyncio.run(tts(text_in, actor = "zh-CN-XiaoyiNeural", fmt = "wav"))
        wav = pydub.AudioSegment.from_file(io.BytesIO(raw_wav))
        pydub.playback. _play_with_pyaudio (wav)
这里强制使用了pyaudio方法来播,是为了指定播放设备,因为我们这里要使用I2S HAT来进行播放,而不是默认设备。先使用aplay -l查询设备编号,接着修改库的源代码,在site-packages/pydub/playback.py中第26行中添加output_device_index=1, 完整函数如下:
def _play_with_pyaudio(seg):
    import pyaudio
    p = pyaudio.PyAudio()
    stream = p.open(format=p.get_format_from_width(seg.sample_width),
                    channels=seg.channels,
                    rate=seg.frame_rate,
                    output=True)
    # Just in case there were any exceptions/interrupts, we release the resource
    # So as not to raise OSError: Device Unavailable should play() be used again
    try:
        # break audio into half-second chunks (to allows keyboard interrupts)
        for chunk in make_chunks(seg, 500):
            stream.write(chunk._data)
    finally:
        stream.stop_stream()
        stream.close()
        p.terminate()
牛  详情 回复 发表于 2023-12-21 20:53
26
