1997|0
75
在windows下使用PVM中添加节点机出现如下问题 [复制链接]
pvm> add node1
add node1
0 successful
HOST DTID
node1 Can't start pvmd
Auto-Diagnosing Failed Hosts...
node1...
Verifying Local Path to "rsh"...
Error - File /usr/ucb/rsh Not Found!
Determine the path to the "rsh" command on your
system, and edit PVM_ROOT\conf\WIN32.def
to adjust the path for the -DRSHCOMMAND=\"\"
flag. Then recompile PVM and your applications.
看来是rsh的问题,但是我两台机器都是直接安装的rsh,一点都没改设置,用rsh node1 dir c:\都可以显示node1机器的c盘文件夹列表。
有哪位大侠知道如何解决这个问题吗?感激不尽!
