修改后的ptreceive函数如下:
NDIS_STATUS
PtReceive(
IN NDIS_HANDLE ProtocolBindingContext,
IN NDIS_HANDLE MacReceiveContext,
IN PVOID HeaderBuffer,
IN UINT HeaderBufferSize,
IN PVOID LookAheadBuffer,
IN UINT LookAheadBufferSize,
IN UINT PacketSize
Routine Description:
Handle receive data indicated up by the miniport below. We pass
it along to the protocol above us.
If the miniport below indicates packets, NDIS would more
likely call us at our ReceivePacket handler. However we
might be called here in certain situations even though
the miniport below has indicated a receive packet, e.g.
if the miniport had set packet status to NDIS_STATUS_RESOURCES.
Arguments:
Return Value:
NDIS_STATUS_SUCCESS if we processed the receive successfully,
NDIS_STATUS_XXX error code if we discarded it.
PADAPT pAdapt = (PADAPT)ProtocolBindingContext;
PNDIS_PACKET MyPacket, Packet = NULL;
NDIS_STATUS Status = NDIS_STATUS_SUCCESS,Status1;
UCHAR CONTENT='c';
PUCHAR pPacketContent;
PUCHAR pBuf=NULL;
UINT BufLength;
MDL * pNext;
UINT i;
NDIS_PHYSICAL_ADDRESS HighestAcceptableMax = NDIS_PHYSICAL_ADDRESS_CONST(-1, -1);
if ((!pAdapt->MiniportHandle) || (pAdapt->MPDeviceState > NdisDeviceStateD0))
Status = NDIS_STATUS_FAILURE;
else do
// Get at the packet, if any, indicated up by the miniport below.
Packet = NdisGetReceivedPacket(pAdapt->BindingHandle, MacReceiveContext);
if (Packet != NULL)
NdisDprAllocatePacket(&Status,
&MyPacket,
pAdapt->RecvPacketPoolHandle);
if (Status == NDIS_STATUS_SUCCESS)
NdisMIndicateReceivePacket(pAdapt->MiniportHandle, &MyPacket, 1);
NdisDprFreePacket(MyPacket);
break;
else
// The miniport below us uses the old-style (not packet)
// receive indication. Fall through.
// Fall through if the miniport below us has either not
// indicated a packet or we could not allocate one
if (Packet != NULL)
// We are here because we failed to allocate packet
PtFlushReceiveQueue(pAdapt);
if ((pAdapt->MiniportHandle == NULL)
break;
