2351|2
83
红外通讯问题 [复制链接]
麻烦哪位大侠帮忙改善下 把接受到信息(rev)以文本形式保存在text中  万分感激
// IrServerDlg.cpp : implementation file
#include "stdafx.h"
//#include "Winsock2.h"
#include "IrServer.h"
#include "IrServerDlg.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// CIrServerDlg dialog
CIrServerDlg::CIrServerDlg(CWnd* pParent /*=NULL*/)
        : CDialog(CIrServerDlg::IDD, pParent)
        //{{AFX_DATA_INIT(CIrServerDlg)
        Ir_SendString = _T("");
        Ir_ClientNumber = 0;
        Ir_RevString = _T("");
        //}}AFX_DATA_INIT
        // Note that LoadIcon does not require a subsequent DestroyIcon in Win32
        //设置服务器地址结构
        Ir_Address.irdaAddressFamily = AF_IRDA;
        Ir_Address.irdaDeviceID[0] = 0;
        Ir_Address.irdaDeviceID[1] = 0;
        Ir_Address.irdaDeviceID[2] = 0;
        Ir_Address.irdaDeviceID[3] = 0;
        strcpy(Ir_Address.irdaServiceName,"IRServer");
        Ir_ClientConnectSocket = NULL;
        Ir_ServerListenSocket = NULL;
        Ir_Connected    = FALSE;
        Ir_pReciveThread = NULL;
        Ir_Thread       = FALSE;
        Ir_CtlString  = _T("");
        m_hIcon = AfxGetApp()->LoadIcon(IDR_MAINFRAME);
void CIrServerDlg::DoDataExchange(CDataExchange* pDX)
        CDialog::DoDataExchange(pDX);
        //{{AFX_DATA_MAP(CIrServerDlg)
        DDX_Control(pDX, IDC_BUTTON_SEND, Ir_Send);
        DDX_Control(pDX, IDC_BUTTON_HALT, Ir_Halt);
        DDX_Control(pDX, IDC_BUTTON_ESTABLISH, Ir_Establish);
        DDX_Text(pDX, IDC_EDIT_SEND, Ir_SendString);
        DDV_MaxChars(pDX, Ir_SendString, 200);
        DDX_Text(pDX, IDC_EDIT_CLIENTS, Ir_ClientNumber);
        DDV_MinMaxDWord(pDX, Ir_ClientNumber, 0, 1);
        DDX_Text(pDX, IDC_EDIT_REV, Ir_RevString);
        //}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CIrServerDlg, CDialog)
        //{{AFX_MSG_MAP(CIrServerDlg)
        ON_BN_CLICKED(IDC_BUTTON_ESTABLISH, OnButtonEstablish)
        ON_BN_CLICKED(IDC_BUTTON_HALT, OnButtonHalt)
        ON_BN_CLICKED(IDC_BUTTON_SEND, OnButtonSend)
        //}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CIrServerDlg message handlers
BOOL CIrServerDlg::OnInitDialog()
        CDialog::OnInitDialog();
        // Set the icon for this dialog.  The framework does this automatically
        //  when the application's main window is not a dialog
        SetIcon(m_hIcon, TRUE);                        // Set big icon
        SetIcon(m_hIcon, FALSE);                // Set small icon
        CenterWindow(GetDesktopWindow());        // center to the hpc screen
        // TODO: Add extra initialization here
        if(Ir_Connected)//如果连接已经存在
                Ir_Establish.EnableWindow(FALSE); //关闭连接建立按钮
                Ir_Halt.EnableWindow(TRUE); //开启连接取消按钮
                Ir_Send.EnableWindow(TRUE); //开启发送功能按钮
        else//连接未存在
                Ir_Establish.EnableWindow(TRUE); //开启连接建立按钮
                Ir_Halt.EnableWindow(FALSE); //关闭连接取消按钮
                Ir_Send.EnableWindow(FALSE);  //关闭发送按钮
        Ir_CtlEvent = CreateEvent(NULL,FALSE,FALSE,_T("IsConnected"));
        if(Ir_CtlEvent == NULL)
                MessageBox(_T("Error created event"));
                DestroyWindow();
        //建立接收线程
        Ir_Thread = TRUE; //保证线程能够正常启动
        Ir_pReciveThread = AfxBeginThread(RevThreadProc,(void*)this,THREAD_PRIORITY_NORMAL);
        if(!Ir_pReciveThread)
                MessageBox(_T("Error created thread for receiving"));
                DestroyWindow();
        this->UpdateData(FALSE);
        return TRUE;  // return TRUE  unless you set the focus to a control
*        函数名         : RevThreadProc
*        功能          : 接收线程,在连接状态下负责接收外部传送的信息,该
*             函数是类外部的函数注意其与类对象之间的交互
*        返回值        :
UINT RevThreadProc(LPVOID pParam)
        CIrServerDlg* pOperateDlg = (CIrServerDlg*)pParam;//取得操作对象
        int iReturn;
        DWORD  BufferSize;
        TCHAR  Rev[300]; //最多一次接收300个字符,包括空字符
        memset(Rev,0,600); //清空接收缓存
        BufferSize = sizeof(TCHAR)*300;
        //接收处理池
        while(pOperateDlg->Ir_Thread) //
                WaitForSingleObject(pOperateDlg->Ir_CtlEvent,INFINITE);
                while(pOperateDlg->Ir_Connected)//如果连接存在,保持接收线程的处理
                        iReturn = recv(pOperateDlg->Ir_ClientConnectSocket,(char*)Rev,BufferSize, 0);
                        // Check if there is any data received. If there is, display it.
                        if (iReturn == SOCKET_ERROR)
                                pOperateDlg->Ir_CtlString.Format(_T("Data recieving errors,maybe need restart connection: \
                                        \r\nReceive Socket errors %d"),WSAGetLastError());
                                ::MessageBox(pOperateDlg->m_hWnd,pOperateDlg->Ir_CtlString.LockBuffer()
                                                 ,NULL,MB_OK);
                                pOperateDlg->Ir_CtlString.UnlockBuffer();
                                pOperateDlg->HaltConnect();
                        else if (iReturn == 0)
                             pOperateDlg->Ir_CtlString.Format(_T("Receive Socket finished\n"),WSAGetLastError());
                                                 ,NULL,MB_OK);
                        else
                                //将得到的字符信息存入输入显示缓冲
                                 pOperateDlg->Ir_RevString.Insert((pOperateDlg->Ir_RevString.GetLength()),Rev);
                                pOperateDlg->UpdateData(FALSE);//显示收集到的数据
                return 0xdead;
不会 帮顶  详情 回复 发表于 2009-6-1 14:36
没人会吗??????????
66
不会 帮顶
