962|1
441
【STM32F723 Discovery Kit】移植LVGL [复制链接]
这篇来学习下在STM32F723 Discovery Kit开发板上移植LVGL。
一、下载LVGL
1.1、源码地址
下载地址:
链接已隐藏,如需查看请登录或者注册
1.2、使用git下载源码
下载v8.3版本分支
执行命令:git clone -b release/v8.3 --depth=1
链接已隐藏,如需查看请登录或者注册
二、添加文件
在项目中添加源文件,将LVGL相应目录下的文件添加到项目。
三、修改文件
3.1、修改lv_port_disp_template.c
修改显示屏尺寸、初始化和驱动程序。
 * @File lv_port_disp_templ.c
/*Copy this file as "lv_port_disp.c" and set this value to "1" to enable content*/
#if 1
 *      INCLUDES
#include "lv_port_disp_template.h"
#include <stdbool.h>
#include "STM32F723E-Discovery/stm32f723e_discovery_lcd.h"
 *      DEFINES
//#ifndef MY_DISP_HOR_RES
//    #warning Please define or replace the macro MY_DISP_HOR_RES with the actual screen width, default value 320 is used for now.
//    #define MY_DISP_HOR_RES    320
//#endif
//#ifndef MY_DISP_VER_RES
//    #warning Please define or replace the macro MY_DISP_HOR_RES with the actual screen height, default value 240 is used for now.
//    #define MY_DISP_VER_RES    240
//#endif
 *      TYPEDEFS
#define MY_DISP_HOR_RES    240
 *  STATIC PROTOTYPES
static void disp_init(void);
static void disp_flush(lv_disp_drv_t * disp_drv, const lv_area_t * area, lv_color_t * color_p);
//static void gpu_fill(lv_disp_drv_t * disp_drv, lv_color_t * dest_buf, lv_coord_t dest_width,
//        const lv_area_t * fill_area, lv_color_t color);
 *  STATIC VARIABLES
 *      MACROS
 *   GLOBAL FUNCTIONS
void lv_port_disp_init(void)
     * Initialize your display
    disp_init();
     * Create a buffer for drawing
     * LVGL requires a buffer where it internally draws the widgets.
     * Later this buffer will passed to your display driver's `flush_cb` to copy its content to your display.
     * The buffer has to be greater than 1 display row
     * There are 3 buffering configurations:
     * 1. Create ONE buffer:
     *      LVGL will draw the display's content here and writes it to your display
     * 2. Create TWO buffer:
     *      LVGL will draw the display's content to a buffer and writes it your display.
     *      You should use DMA to write the buffer's content to the display.
     *      It will enable LVGL to draw the next part of the screen to the other buffer while
     *      the data is being sent form the first buffer. It makes rendering and flushing parallel.
     * 3. Double buffering
     *      Set 2 screens sized buffers and set disp_drv.full_refresh = 1.
     *      This way LVGL will always provide the whole rendered screen in `flush_cb`
     *      and you only need to change the frame buffer's address.
    /* Example for 1) */
    static lv_disp_draw_buf_t draw_buf_dsc_1;
    static lv_color_t buf_1[MY_DISP_HOR_RES * 10];                          /*A buffer for 10 rows*/
    lv_disp_draw_buf_init(&draw_buf_dsc_1, buf_1, NULL, MY_DISP_HOR_RES * 10);   /*Initialize the display buffer*/
//    /* Example for 2) */
//    static lv_disp_draw_buf_t draw_buf_dsc_2;
//    static lv_color_t buf_2_1[MY_DISP_HOR_RES * 10];                        /*A buffer for 10 rows*/
//    static lv_color_t buf_2_2[MY_DISP_HOR_RES * 10];                        /*An other buffer for 10 rows*/
//    lv_disp_draw_buf_init(&draw_buf_dsc_2, buf_2_1, buf_2_2, MY_DISP_HOR_RES * 10);   /*Initialize the display buffer*/
//    /* Example for 3) also set disp_drv.full_refresh = 1 below*/
//    static lv_disp_draw_buf_t draw_buf_dsc_3;
//    static lv_color_t buf_3_1[MY_DISP_HOR_RES * MY_DISP_VER_RES];            /*A screen sized buffer*/
//    static lv_color_t buf_3_2[MY_DISP_HOR_RES * MY_DISP_VER_RES];            /*Another screen sized buffer*/
//    lv_disp_draw_buf_init(&draw_buf_dsc_3, buf_3_1, buf_3_2,
//                          MY_DISP_VER_RES * LV_VER_RES_MAX);   /*Initialize the display buffer*/
     * Register the display in LVGL
    static lv_disp_drv_t disp_drv;                         /*Descriptor of a display driver*/
    lv_disp_drv_init(&disp_drv);                    /*Basic initialization*/
    /*Set up the functions to access to your display*/
    /*Set the resolution of the display*/
    disp_drv.hor_res = MY_DISP_HOR_RES;
    disp_drv.ver_res = MY_DISP_VER_RES;
    /*Used to copy the buffer's content to the display*/
    disp_drv.flush_cb = disp_flush;
    /*Set a display buffer*/
    disp_drv.draw_buf = &draw_buf_dsc_1;
    /*Required for Example 3)*/
    //disp_drv.full_refresh = 1;
    /* Fill a memory array with a color if you have GPU.
     * Note that, in lv_conf.h you can enable GPUs that has built-in support in LVGL.
     * But if you have a different GPU you can use with this callback.*/
    //disp_drv.gpu_fill_cb = gpu_fill;
    /*Finally register the driver*/
    lv_disp_drv_register(&disp_drv);
 *   STATIC FUNCTIONS
/*Initialize your display and the required peripherals.*/
    /*You code here*/
	BSP_LCD_Init();
	BSP_LCD_Clear(LCD_COLOR_RED);
volatile bool disp_flush_enabled = true;
/* Enable updating the screen (the flushing process) when disp_flush() is called by LVGL
void disp_enable_update(void)
/* Disable updating the screen (the flushing process) when disp_flush() is called by LVGL
void disp_disable_update(void)
    disp_flush_enabled = false;
/*Flush the content of the internal buffer the specific area on the display
 *You can use DMA or any hardware acceleration to do this operation in the background but
 *'lv_disp_flush_ready()' has to be called when finished.*/
		if (disp_flush_enabled)
		BSP_LCD_DrawRGBImage(area->x1, area->y1, area->x2 - area->x1 + 1, area->y2 - area->y1 + 1, (uint8_t *)color_p);
    /*IMPORTANT!!!
     *Inform the graphics library that you are ready with the flushing*/
    lv_disp_flush_ready(disp_drv);
/*OPTIONAL: GPU INTERFACE*/
/*If your MCU has hardware accelerator (GPU) then you can use it to fill a memory with a color*/
//    /*It's an example code which should be done by your GPU*/
//    int32_t x, y;
//    dest_buf += dest_width * fill_area->y1; /*Go to the first line*/
//    for(y = fill_area->y1; y <= fill_area->y2; y++) {
//        for(x = fill_area->x1; x <= fill_area->x2; x++) {
//            dest_buf[x] = color;
//        dest_buf+=dest_width;    /*Go to the next line*/
#else /*Enable this file at the top*/
/*This dummy typedef exists purely to silence -Wpedantic.*/
typedef int keep_pedantic_happy;
#endif
3.2、心跳程序
  * @brief  This function handles SysTick Handler.
  * @param  None
  * @retval None
void SysTick_Handler(void)
  HAL_IncTick();
	lv_tick_inc(1);
3.3、main.c
#include "main.h"
#include "led/led.h"
#include "delay/delay.h"
#include "key/key.h"
#include "usart/usart.h"
#include "sram/sram.h"
#include "STM32F723E-Discovery/stm32f723e_discovery_qspi.h"
#include "lvgl.h"
#include "lv_port_indev_template.h"
#include "lvgl/demos/benchmark/lv_demo_benchmark.h"
static void MPU_Config(void);
static void SystemClock_Config(void);
static void CPU_CACHE_Enable(void);
int main(void)
	uint16_t i=0;
	uint8_t txbuf[10];
	uint8_t rxbuf[10];
	HAL_Init();
  MPU_Config();					/* Configure the MPU attributes */
  CPU_CACHE_Enable();		/* Enable the CPU Cache */
  SystemClock_Config();	/* Configure the system clock to 216 MHz */
	delay_init(216);
	led_init();
	usart_init(115200);
	lv_init();
	lv_port_disp_init();
	lv_demo_benchmark();
  while (1)
		LED5_TOGGLE();
    delay_ms(5);
		lv_task_handler();
四、程序运行
lvgl
此帖出自stm32/stm8论坛
谢谢分享,期待后续   详情 回复 发表于 2023-10-25 16:48
7628
谢谢分享,期待后续
此帖出自stm32/stm8论坛
默认摸鱼,再摸鱼。2022、9、28
推荐帖子
FPGA——人工智能的未来
FPGA——人工智能的未来 基于大规模数字逻辑的人工智能实现的可行性分析 注:本文为一年前写成,具有一定的科普性,其中有一些 ...
1602的学习总结(菜鸟入门级)
先来叙述一些概念。 LCM和LCD的区别 LCM【Liquid Crystal Module】液晶显示模块,通常包括显示驱动电路,接口电路等等。往 ...
ubuntu下修改内核发生“ncurses libraries“错误(解决方法)
BSEC@bsec-server:~/kernel/Kernel$ make menuconfig HOSTCC scripts/basic/fixdep HOSTCC scripts/basic/docproc HOSTCC script ...
有奖直播:nanoPower技术:延长电池寿命,提升传感器性能 直播资料合集
直播资料合集 nanoPower技术:延长电池寿命,提升传感器性能 直播回放: >>点击观看 直播文档: > ...
【小熊派BearPi-HM Micro】三:烧录编译的固件程序
本帖最后由 数码小叶 于 2022-4-5 13:15 编辑 上一篇已经成功编译了源码,接下来就是把编译的源码结果烧录到小熊派BearPi-HM ...
DC-DC升压到5V异常
我的升压电路图如下图: 608263 我的BAT输入是三节7号干电池,用的DC-DC升压芯片是PT1311,下图是PT1311部分介绍: 608 ...
【花雕动手做】有趣好玩的音乐可视化系列小项目(19)--通体光纤灯
偶然心血来潮,想要做一个音乐可视化的系列专题。这个专题的难度有点高,涉及面也比较广泛,相关的FFT和FHT等算法也相当复杂,不 ...
请问你们平常芯片或者元件都是去哪买的?
请问你们平常芯片或者元件都是去哪买的?我发现某宝现在太病态了,价格乱七八糟,每一个标实价的,只要你拍了,基本都不发货,要 ...
System Identification Methods for (Operational) Modal Analysis Review and Com...
本帖最后由 lihuanyang 于 2022-12-19 09:49 编辑 基于模型分析预览对照的系统辨识方法;全英文原版
【大学生电子竞赛题目分析】——2023年全国赛B题《同轴电缆长度与终端负载检测装置》
没有在论坛内看到这次竞赛B题的讨论,只看到一个问的,还没人回答 其实,今年的竞赛题中,B题是工作量最小的一个。问题是必须 ...
