594|2
1239
【DigiKey创意大赛】1、收到物料&开箱 [复制链接]
下单后很快就收到物料,给DigiKey的发货、物流速度点赞!本次DIY的主控开发板选用的STM32最强性能之一的STM32H747,ST新包装采用了低碳环保的牛皮纸:
正面:
防静电袋包装,附赠入门小卡片:
板卡正面靓照,板载LCD、按键,外设丰富:
板卡反面,支持arduino接口,可以很方便的设计项目所需的扩展板堆叠上去:
来自官网的板载资源介绍:
All features
  • STM32H747XIH6 Arm®-based microcontroller with 2 Mbytes of Flash memory and 1 Mbyte of RAM in TFBGA240 + 25 package
  • 4” capacitive touch LCD display module with MIPI® DSI interface (STM32H747I-DISCO order code only)
  • Ethernet compliant with IEEE802.3-2002
  • USB OTG HS
  • SAI audio codec
  • ST-MEMS digital microphones
  • 2 x 512-Mbit Quad-SPI NOR Flash memory
  • 256-Mbit SDRAM
  • 4 color user LEDs
  • 1 user and reset push-button
  • 4-direction joystick with selection button
  • Fanout daughterboard
  • Board connectors:
    • Camera (8-bit)
    • USB with Micro-AB
    • Ethernet RJ45
    • SPDIF RCA input and output
    • Stereo headset jack including analog microphone input
    • Audio jack for external speakers
    • microSD™ card
    • TAG-Connect 10-pin footprint
    • Arm® Cortex® 10-pin 1.27 mm-pitch debug connector over STDC14 footprint
  • Board expansion connectors:
    • Arduino™ Uno V3
    • Pmod™ Type 2A and Type 4A
    • STMod+
    • Audio daughterboard
  • Flexible power-supply options:
    • ST-LINK USB VBUS, USB OTG HS connector, or external sources
  • On-board STLINK-V3E debugger/programmer with USB re-enumeration capability: mass storage, Virtual COM port and debug port
  • Comprehensive free software libraries and examples available with the STM32Cube MCU Package
  • Support of a wide choice of integrated development environments (IDEs), including IAR™, Keil® and GCC-based IDEs
主控芯片特写:
来自ST中文官网对STM32H747的介绍:
STM32H7x7系列集成了工作频率高达480 MHz的Cortex-M7内核(具有双精度浮点单元)和Cortex-M4内核(具有单精度浮点单元)的卓越性能
性能
  • 在480 MHz的CPU频率(Cortex-M7)或240 MHz的CPU频率(Cortex-M4)下,从闪存执行程序时,能够提供3224 CoreMark / 1327 DMIPS的性能,利用其L1缓存并实现了零等待执行
  • L1缓存(16 KB的I-缓存 +16 KB的D-缓存)提高外部存储器的执行性能
安全性
STM32H757 MCU包含以下额外安全特性:
  • 加密/哈希硬件加速
  • STM32H757还支持安全固件安装(SFI)嵌入式安全服务,可在执行初始程序时执行安全验证并保护软件IP。
  • 安全启动和安全固件升级(SBSFU)
高能效
  • 多电源域架构可实现将不同的电源域配置为低功耗模式,进而优化功耗效率。
  • 内置SMPS,用于降低电源电压。还可用于为外部电路供电,以及特定应用情况下结合LDO共同使用。
  • USB调节器提供嵌入式物理接口层(PHY)。
  • 在内核运行模式(外设外设关)和SMPS情况下,典型功耗为145 µA/MHz @vdd = 3.3 V和25 °C
  • 低功耗待机模式下的典型功耗电流为2.43 µA
  • 带RTC的VBAT模式(低功耗模式)下通常为460 nA
图形
  • LCD-TFT控制器接口支持双层图形
  • MIPI-DSI接口,用于驱动DSI显示
  • Chrom‑ART Accelerator™。提高了图形内容创建速度,并为其它应用节省了MCU内核处理带宽。
  • JPEG硬件加速器,可进行快速JPEG编码和解码,从而减轻CPU编解码负荷
片内外设
  • 多达35个通信接口包括FD-CAN、USB 2.0高速/全速、以太网MAC、摄像头接口。
  • 可利用带有32位并行接口或双模Quad-SPI串行闪存接口的灵活存储控制器轻松扩展存储器容量。
  • 模拟外设:12位DAC,快速16位ADC
  • 16位高精度定时器上的多个16位和32位定时器运行频率高达480 MHz
STM32H7x7产品提供1到2 MB的Flash存储器,具有分散结构的1 MB SRAM:192 KB的TCM RAM(包括64 KB的ITCM RAM和128 KB的DTCM RAM,用于时间关键型程序和数据),64、288或512 KB的用户SRAM,以及用于在最低功耗模式下保存数据的备份域4 KBSRAM。提供156至240引脚的BGA和LQFP封装型号。STM32H7x7系列包括一个封装尺寸低至4.96 x 4.64 mm的WLCSP封装。
跑分天梯图:
一套ST板块吗?旁边那个小板子是什么?ST开发板配件?   详情 回复 发表于 2023-9-30 09:36
7159
小配件  详情 回复 发表于 2023-9-30 10:28
1239
wangerxian 发表于 2023-9-30 09:36 一套ST板块吗?旁边那个小板子是什么?ST开发板配件?
小配件
