【STM32F769-discovery开发板】第二篇ADC测温度
首先看下温度用的ADC的通道
#define ADC_INTERNAL_NONE 0x80000000U
#define ADC_CHANNEL_VREFINT ((uint32_t)ADC_CHANNEL_17)
#define ADC_CHANNEL_VBAT ((uint32_t)ADC_CHANNEL_18)
#define ADC_CHANNEL_TEMPSENSOR ((uint32_t)(ADC_CHANNEL_18 | 0x10000000U))
AdcHandle.Instance = ADC1;
AdcHandle.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV4;
AdcHandle.Init.Resolution = ADC_RESOLUTION_12B;
AdcHandle.Init.ScanConvMode = DISABLE; /* Sequencer disabled (ADC conversion on only 1 channel: channel set on rank 1) */
AdcHandle.Init.ContinuousConvMode = ENABLE; /* Continuous mode enabled to have continuous conversion */
AdcHandle.Init.DiscontinuousConvMode = DISABLE; /* Parameter discarded because sequencer is disabled */
AdcHandle.Init.NbrOfDiscConversion = 0;
AdcHandle.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; /* Conversion start not trigged by an external event */
AdcHandle.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T1_CC1;
AdcHandle.Init.DataAlign = ADC_DATAALIGN_RIGHT;
AdcHandle.Init.NbrOfConversion = 1;
AdcHandle.Init.DMAContinuousRequests = ENABLE;
AdcHandle.Init.EOCSelection = DISABLE;
if (HAL_ADC_Init(&AdcHandle) != HAL_OK)
/* ADC initialization Error */
Error_Handler();
/* Configure ADC Temperature Sensor Channel */
sConfig.Channel = ADC_CHANNEL_TEMPSENSOR;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_56CYCLES;
sConfig.Offset = 0;
基本配置配好了之后开始计算温度值
这几个值在数据手册里
看下结果,有点偏差
STM32F769的温度传感器介绍
看下103的温度传感器介绍
是完全一样的
如果要用内部温度传感器测温,还是要自己应用层在多个点进行校准一下吧最起码,不然温度偏差还是比较大的
