8142|3
75
mtd分区和ubi文件系统的问题 [复制链接]
我在kernel里面最后增加了一个分区,在根文件系统需要做什么改变吗。
原来的最后分区0x10800000-0x20000000 nand.userdata
我分成两个,0x10800000-0x18800000 nand.userdata
0x18800000-0x2000000 nand.newadd
结果是启动时ubi出错了,说需要修复,然后mount了一个block 0什么的,然后是所有的init的东西都找不到
init: cannot find '/system/bin/sh'
等等,console就没有了
是不是fs这边也要改代码呢?能给讲讲吗
帮你顶  详情 回复 发表于 2010-6-30 10:01
UBIFS error (pid 1): ubifs_recover_master_node: failed to recover master node
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 1, name "data"
UBIFS: file system size:   129769472 bytes (126728 KiB, 123 MiB, 1022 LEBs)
UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format:       4 (latest is 4)
UBIFS: default compressor: no compression
UBIFS: reserved for root:  0 bytes (0 KiB)
Changed RF State to 0
init: cannot find '/system/bin/sh', disabling 'console'
init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
init: cannot find '/system/bin/vold', disabling 'vold'
init: cannot find '/system/bin/debuggerd', disabling 'debuggerd'
init: cannot find '/system/bin/rild', disabling 'ril-daemon'
init: cannot find '/system/bin/app_process', disabling 'zygote'
init: cannot find '/system/bin/mediaserver', disabling 'media'
init: cannot find '/system/bin/playmp3', disabling 'bootsound'
init: cannot find '/system/bin/dbus-daemon', disabling 'dbus'
init: cannot find '/system/bin/installd', disabling 'installd'
init: cannot find '/system/bin/flash_image', disabling 'flash_recovery'
init: cannot find '/system/bin/logwrapper', disabling 'wifi_conf'
init: cannot find '/system/bin/logwrapper', disabling 'ethstart'
init: cannot find '/system/bin/logwrapper', disabling 'settime'
init: cannot find '/system/bin/logwrapper', disabling 'vehdata'
77
Creating 5 MTD partitions on "NAND 512MiB 3,3V 8-bit":
0x00000000-0x00300000 : "bootloader"
0x00300000-0x00800000 : "nand.kernel"
0x00800000-0x10800000 : "nand.system"
0x10800000-0x16c00000 : "nand.userdata"
0x16c00000-0x40000000 : "nand.reco"
78
帮你顶
