1215|1
【米尔T113测评】TCP编程 [复制链接]
TCP协议是一种面向连接的、可靠的、基于字节流的传输层通信协议。通讯过程如下:
服务器端先初始化Socket,然后与端口绑定(bind),对端口进行监听(listen),调用accept阻塞,等待客户端连接。在这时如果有个客户端初始化一个Socket,然后连接服务器(connect),如果连接成功,这时客户端与服务器端的连接就建立了。客户端发送数据请求,服务器端接收请求并处理请求,然后把回应数据发送给客户端,客户端读取数据,最后关闭连接,一次交互结束。
服务端代码:
#include <stdio.h>
#include <stdlib.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <netinet/in.h>
#include <sys/socket.h>
#include <string.h>
#include <unistd.h>
#include <signal.h>
#include <sys/ipc.h>
#include <errno.h>
#include <sys/shm.h>
#include <time.h>
#include <pthread.h>
#include <arpa/inet.h>
#define BUFFER_SIZE     1024    // buf size
#define LISTENQ         1       // the max quote
#define SIZE_SHMADD 2048
int main(int argc, char *argv[]) {
    // check the arguments.
    if (argc != 2) {
        printf("Usage:\n");
        printf("    %s <port number>\n", argv[0]);
        return -1;
    struct sockaddr_in server_addr;
    struct sockaddr_in client_addr;
    char recv_buf[BUFFER_SIZE];
    char send_buf[BUFFER_SIZE];
    pid_t pid;
    int sock_fd, conn_fd = -1;
    int optval = 1;
    int port = atoi(argv[1]);
    if ((sock_fd = socket(AF_INET, SOCK_STREAM, 0)) == -1) {
        perror("socket");
        return -1;
    // setting bind port crycled.
    if ((setsockopt(sock_fd, SOL_SOCKET, SO_REUSEADDR,
                                    (void *)&optval, sizeof(int))) < 0) {
        perror("setsockopt");
        goto err;
    // initized address.
    bzero(&server_addr, sizeof(struct sockaddr_in));
    server_addr.sin_family=AF_INET;
    server_addr.sin_addr.s_addr=htonl(INADDR_ANY);
    server_addr.sin_port = htons(port);
    // bind the port.
    if (bind(sock_fd, (struct sockaddr *)(&server_addr),
                                        sizeof(struct sockaddr)) == -1) {
        perror("bind");
        goto err;
    // transform the socket into listen socket.
    if (listen(sock_fd, LISTENQ) == -1) {
        perror("listen");
        goto err;
    printf("Waiting for client connectionn...\n");
    socklen_t cli_len = sizeof(struct sockaddr_in);
    conn_fd = accept(sock_fd, (struct sockaddr *)(&client_addr), &cli_len);
    if (conn_fd == -1) {
        perror("accept");
        close(sock_fd);
        return -1;
    printf("Client accepted : %s:%d \n",
            inet_ntoa(client_addr.sin_addr), ntohs(client_addr.sin_port));
    pid = fork();
    if (pid > 0) {
        // The parent process is responsible for sending messages.
        while (1) {
            bzero(send_buf, sizeof(send_buf));
            char *str = fgets(send_buf, sizeof(send_buf), stdin);
            if (str == NULL) {
                perror("fgets");
                goto err;
            if (send(conn_fd, send_buf, strlen(send_buf) - 1, 0) < 0) {
                perror("send");
                goto err;
    else if (pid == 0) {
        // The child process is responsible for receiving messages.
        while (1) {
            bzero(recv_buf, sizeof(recv_buf));
            if ((recv(conn_fd, recv_buf, BUFFER_SIZE, 0)) <= 0) {
                perror("recv");
                goto err;
            printf("[Recv from client %s:%d] : %s\n",
                    inet_ntoa(server_addr.sin_addr),
                    htons(server_addr.sin_port),
                    recv_buf);
    else {
        perror("fork");
        goto err;
    close(conn_fd);
    close(sock_fd);
    return 0;
err:
    close(conn_fd);
    close(sock_fd);
    return -1;
客户端代码:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <errno.h>
    if (argc != 3) {
        printf("Usage:\n");
        printf("    %s <server addr> <port number>\n", argv[0]);
        return -1;
    char *addr = argv[1];
    short port = atoi(argv[2]);
    int sock_fd;
    int ret;
    char recv_buf[BUFFER_SIZE], send_buf[BUFFER_SIZE];
    // initialize address/
    bzero(&server_addr, sizeof(server_addr));
    server_addr.sin_family = AF_INET;
    server_addr.sin_addr.s_addr = inet_addr(addr);
    // create socket fd.
    sock_fd = socket(AF_INET, SOCK_STREAM, 0);
    if (sock_fd == -1) {
        perror("socket");
        return -1;
    // connect.
    ret = connect(sock_fd, (struct sockaddr *)&server_addr, sizeof(struct sockaddr));
    if (ret == -1) {
        perror("connect");
        goto err;
    printf("connect server(IP:%s Port: %d).\n", addr, port);
    pid_t pid = fork();
    if (pid > 0) {
        while (1) {
            if (str == NULL) {
                perror("fgets");
                goto err;
            if (send(sock_fd, send_buf, strlen(send_buf) - 1, 0) < 0) {
                perror("send");
                goto err;
        while (1) {
            if (sock_fd > 0) {
                if ((recv(sock_fd, recv_buf, BUFFER_SIZE, 0)) <= 0) {
                    perror("recv");
                    goto err;
                printf("[Recv from server %s:%d] : %s\n",
                        recv_buf);
    else {
        perror("fork");
        goto err;
    close(sock_fd);
    return 0;
err:
    close(sock_fd);
    return -1;
编译后运行结果如下:
服务端启起来,等待客户端连接。  启动客户端,发送数据, 服务端接收数据。
经典的的教程呀,感谢分享!想问一下,多个链接进来后如何处理,最多可以开放多少个客户端?  详情 回复 发表于 2023-9-6 11:08
7087
