2603|0
78
请教:wince ram base 问题 [复制链接]
搞ce 开发遇到个问题,在这里请教大家,帮个忙!!!
我用系统默认的ram base注册表,用viewbin查看在nk.bin中已经有default.fdf文件,用kitl调试,系统加载到filesys.exe就不动了,是不是找不到default.fdf注册表文件?
我的注册表的配置如下:
[HKEY_LOCAL_MACHINE\init\BootVars]
"Flags"=dword:0
"Start DevMgr"=dword:0
"RegistryFlags"=dword:0
[HKEY_LOCAL_MACHINE\System\ObjectStore]
    "RegistryType"=dword:0
是不是我的注册表配置不正确,还是有那里漏
配子了?
下面是调试kitl打印的信息:
The Kernel Debugger is waiting to connect with target.
      2 PID:0 TID:0 KitlTransport requested active mode.
      2 PID:0 TID:0 (PRId 04030201) @ 396MHZ
Kernel debugger connected.
The Kernel Debugger connection has been established (Target CPU is MIPS).
Target name: CE Device
Probe name: KdStub
Binary Image should be loaded at 0x81100000 / Data relocated at 0x82dd0000
Loaded symbols for 'C:\WINCE500\PBWORKSPACES\MYDBAU1200\RELDIR\DB1200_MIPSII_RELEASE\NK.EXE'
Loaded symbols for 'C:\WINCE500\PBWORKSPACES\MYDBAU1200\RELDIR\DB1200_MIPSII_RELEASE\KD.DLL'
Loaded symbols for 'C:\WINCE500\PBWORKSPACES\MYDBAU1200\RELDIR\DB1200_MIPSII_RELEASE\OSAXST1.DLL'
Loaded symbols for 'C:\WINCE500\PBWORKSPACES\MYDBAU1200\RELDIR\DB1200_MIPSII_RELEASE\OSAXST0.DLL'
Loaded symbols for 'C:\WINCE500\PBWORKSPACES\MYDBAU1200\RELDIR\DB1200_MIPSII_RELEASE\HD.DLL'
Loaded symbols for 'C:\WINCE500\PBWORKSPACES\MYDBAU1200\RELDIR\DB1200_MIPSII_RELEASE\CELOG.DLL'
Loaded symbols for 'C:\WINCE500\PBWORKSPACES\MYDBAU1200\RELDIR\DB1200_MIPSII_RELEASE\COREDLL.DLL'
Loaded symbols for 'C:\WINCE500\PBWORKSPACES\MYDBAU1200\RELDIR\DB1200_MIPSII_RELEASE\FILESYS.EXE'
