815|0
365
AG32VF407 AGRV2K 串口printf调试输出 [复制链接]
原理图
测试代码
新建一个platformio工程,复制如下文件到测试工程目录下
E:\tech\AGM-AG32VF\sdk-release\AgRV_pio\platforms\AgRV\boards\agrv2k_407\board.asf
E:\tech\AGM-AG32VF\sdk-release\AgRV_pio\platforms\AgRV\boards\agrv2k_407\board.ve
E:\tech\AGM-AG32VF\sdk-release\AgRV_pio\platforms\AgRV\examples\example\platformio.ini
platformio.ini中增加如下配置,uart调试端口可以查看设备管理器,COM多少,其中速率默认sdk为500000
新建src目录,创建uart.c文件,代码如下:
#include "board.h"
int main(void)
    board_init();
    int cnt=0;
    #define LED_D3_GPIO GPIO4
    #define LED_D3_GPIO_BITS (1 << 3)
    SYS_EnableAPBClock(APB_MASK_GPIO4);
    GPIO_SetOutput(LED_D3_GPIO, LED_D3_GPIO_BITS);
    GPIO_SetHigh(LED_D3_GPIO, LED_D3_GPIO_BITS);
    int counter = 0;
    while (1) {
        UTIL_IdleMs(500);
        GPIO_Toggle(LED_D3_GPIO, LED_D3_GPIO_BITS);
        printf("test %d\r\n", cnt++);
build,upload,然后再点击Serial Monitor,输出如下图
printf实现
E:\tech\AGM-AG32VF\sdk-release\AgRV_pio\packages\framework-agrv_sdk\misc\syscalls.c
    int printf(const char* fmt, ...)
          int ret = vprintfmt((void*)putchar, 0, fmt, ap, 0);
E:\tech\AGM-AG32VF\sdk-release\AgRV_pio\packages\framework-agrv_sdk\src\util.c
    int putchar(int ch)
        UART_SendCh(UARTx(LOGGER_UART), ch);
E:\tech\AGM-AG32VF\sdk-release\AgRV_pio\platforms\AgRV\boards\agrv2k_407\board.c
    void board_init(void)
        MSG_UART = UARTx(LOGGER_UART);
视频讲解
