2920|3
81
关于Screen Saver的问题 [复制链接]
下面是自带的WinCE500自带的帮助文件:ms-help://MS.WindowsCE.500/wcetarget5/html/wce50conConfigureScreenSaversInThinClient.htm
If you want the shell to load a screen saver after a specified period of time, you must include the dynamic-link library (DLL) of the screen saver in your image. You must also configure the registry to support the screen saver.
The following registry key shows the required settings for Windows Thin Client.
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power]
    "BattPowerOff"=DWORD:0
    "ExtPowerOff"=DWORD:0
    "ScreenPowerOff"=DWORD:300
The ScreenPowerOff registry entry specifies the amount of time, in seconds, that must elapse with no user input before the shell starts the screen saver.
When the user presses the CTRL+ALT+END key combination, the Windows Thin Client Shell brings the shell UI to the foreground. To configure this key combination, set the following registry entries.
[HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\KEYBD]
    "DriverName"="Kbdmouse.dll"
    "CalVKey"=DWORD:0
    "ContLessVKey"=DWORD:0
    "ContMoreVKey"=DWORD:0
    "TaskManVKey"=DWORD:23
The HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WBT\Shell registry key configures the screen saver for the thin client shell. The following table shows the named values.
Value                Description
ScreenSaver (REG_SZ)            This value specifies the DLL to load when starting the screen saver. This value is entered at build time.
                                The following list shows the three screen savers that are included with the Windows-based Terminal user interface source;
                                you can use one of these as the screen saver:
                                    SSFloat (ssfloat.dll)
                                    SSBlank (ssblank.dll)
                                    SSTile (sstile.dll)
                                To include one of these screen savers, list the name of the desired screen saver in the RDP_MODULES environment variable                                      (%_PROJECTROOT%\Oak\Misc\Cesysgen.bat).
ScreenSaverEnable (REG_DWORD)   This value specifies whether to enable the screen saver.
                                If this value is equal to 0, then the screen saver is not enabled.
                                If it is greater than 0, then the screen saver is enabled and the shell
                                attempts to load the screen saver specified. Because the shell queries this registry
                                every time that it receives a WM_POWERBROADCAST message, this can be changed dynamically.
问题来了:
1. SSFloat (ssfloat.dll) ,SSBlank (ssblank.dll),SSTile (sstile.dll)这3个文件只找到lib没找到dll,怎么办?
2. 自己做屏保dll怎么做?
3. ScreenSaver、ScreenSaverEnable是不是HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WBT\Shell下的键名?
瘦客户端~  详情 回复 发表于 2008-11-19 16:23
79
Thin Client是什么东西?
Thin Client是什么东西?
81
引用 2 楼 comey 的回复:
Thin Client是什么东西?
瘦客户端~
