1767|1
504
【RTT&英飞凌PSoC6评估板(带触摸)】定时器测试 [复制链接]
前言
这一篇来进行定时器的实现与测试,因为后面很多功能都需要用到定时器。通过定时器中断中翻转IO使用示波器测量来确定时间准确度。
代码
在前面https://bbs.eeworld.com.cn/thread-1247060-1-1.html的基础上进行。
定时器初始化
 void timer_init(void)
    cy_rslt_t result;
    const cyhal_timer_cfg_t led_blink_timer_cfg =
        .compare_value = 0,                 /* Timer compare value, not used */
        .period = LED_BLINK_TIMER_PERIOD,   /* Defines the timer period */
        .direction = CYHAL_TIMER_DIR_UP,    /* Timer counts up */
        .is_compare = false,                /* Don't use compare mode */
        .is_continuous = true,              /* Run timer indefinitely */
        .value = 0                          /* Initial value of counter */
    /* Initialize the timer object. Does not use input pin ('pin' is NC) and
     * does not use a pre-configured clock source ('clk' is NULL). */
    result = cyhal_timer_init(&led_blink_timer, NC, NULL);
    /* timer init failed. Stop program execution */
    if (result != CY_RSLT_SUCCESS)
        CY_ASSERT(0);
    /* Configure timer period and operation mode such as count direction,
       duration */
    cyhal_timer_configure(&led_blink_timer, &led_blink_timer_cfg);
    /* Set the frequency of timer's clock source */
    cyhal_timer_set_frequency(&led_blink_timer, LED_BLINK_TIMER_CLOCK_HZ);
    /* Assign the ISR to execute on timer interrupt */
    cyhal_timer_register_callback(&led_blink_timer, isr_timer, NULL);
    /* Set the event on which timer interrupt occurs and enable it */
    cyhal_timer_enable_event(&led_blink_timer, CYHAL_TIMER_IRQ_TERMINAL_COUNT,
                              7, true);
    /* Start the timer with the configured settings */
    cyhal_timer_start(&led_blink_timer);
其中
#define LED_BLINK_TIMER_CLOCK_HZ          (10000) 定义定时器时钟频率
#define LED_BLINK_TIMER_PERIOD            (99) 定义周期,即多少个时钟产生中断
如果时钟频率为10000则一个时钟1/10000秒, 设置周期99即100个时钟100/10000秒,即1/100秒,10mS。
注册了回调函数isr_timer
中断中翻转IO
static void isr_timer(void *callback_arg, cyhal_timer_event_t event)
    (void) callback_arg;
    (void) event;
    /* Set the interrupt flag and process it from the main while(1) loop */
    timer_interrupt_flag = true;
    cyhal_gpio_toggle(CYBSP_USER_LED);
IO的初始化如下
    result = cyhal_gpio_init(CYBSP_USER_LED, CYHAL_GPIO_DIR_OUTPUT,
                             CYHAL_GPIO_DRIVE_STRONG, CYBSP_LED_STATE_OFF);
其中CYBSP_USER_LED为P11_1
注释掉以下代码
        /* Check if timer elapsed (interrupt fired) and toggle the LED */
        //if (timer_interrupt_flag)
            /* Clear the flag */
        //    timer_interrupt_flag = false;
            /* Invert the USER LED state */
        //    cyhal_gpio_toggle(CYBSP_USER_LED);
时间准确度测试
设置1mS中断
#define LED_BLINK_TIMER_PERIOD            (9)
实测0.99mS
设置10mS中断
实测9.92
考虑到测量误差,上述结果可以看到时间是准确的。
总结
使用官方的库函数,HAL接口进行外设操作比较简单,比如定时器几个接口就完成了操作,非常方便。
此帖出自ARM技术论坛
定时器中断中翻转IO使用示波器测量来确定时间准确度,用官方的库函数,HAL接口进行外设操作确实是比较简单   详情 回复 发表于 2023-6-18 10:57
1705
此帖出自ARM技术论坛
