893|1
172
【得捷电子Follow me第1期】任务4:使用GPS定位模块以及对协议进行解析 [复制链接]
GPS定位模块使用
本次活动中使用的GPS模块(Air530)是一款高性能、高集成度的多模式卫星定位以及导航模块。支持GPS/Beidou/Glonass/Galileo/QZSS/SBAS等,适用于车载导航、智慧天气和农业等GNSS定位应用。
硬件连接
GPS模块通过串口与MCU通讯,将模块连接到转接板的UART0上,OLED屏幕连接到I2C0上。实物连接的效果如图所示:
模块代码编写
串口接收的到的数据格式如图所示
由于编写代码处在室内,信号遮挡严重,所以长时间无法获取到卫星信号,在靠近窗台或者开阔地带使用时,GPS模块工作一段时间,大约30秒,即可正常连接上卫星并更新位置和时间信息。
接收到串口发送过来的报文后,需要按照协议的格式对其进行解析,在论坛之前的帖子中了解到有现成的轮子micropyGPS。将模块的代码导入到Pico W中,同时编写相关的调用函数,提取其中相关的经纬度、时间等信息,输出到OLED屏幕上显示。
模块代码如下:
# MicropyGPS - a GPS NMEA sentence parser for Micropython/Python 3.X
# Copyright (c) 2017 Michael Calvin McCoy (calvin.mccoy@protonmail.com)
# The MIT License (MIT) - see LICENSE file
# TODO:
# Time Since First Fix
# Distance/Time to Target
# More Helper Functions
# Dynamically limit sentences types to parse
from math import floor, modf
# Import utime or time for fix time handling
try:
    # Assume running on MicroPython
    import utime
except ImportError:
    # Otherwise default to time module for non-embedded implementations
    # Should still support millisecond resolution.
    import time
class MicropyGPS(object):
    """GPS NMEA Sentence Parser. Creates object that stores all relevant GPS data and statistics.
    Parses sentences one character at a time using update(). """
    # Max Number of Characters a valid sentence can be (based on GGA sentence)
    SENTENCE_LIMIT = 90
    __HEMISPHERES = ('N', 'S', 'E', 'W')
    __NO_FIX = 1
    __FIX_2D = 2
    __FIX_3D = 3
    __DIRECTIONS = ('N', 'NNE', 'NE', 'ENE', 'E', 'ESE', 'SE', 'SSE', 'S', 'SSW', 'SW', 'WSW', 'W',
                    'WNW', 'NW', 'NNW')
    __MONTHS = ('January', 'February', 'March', 'April', 'May',
                'June', 'July', 'August', 'September', 'October',
                'November', 'December')
    def __init__(self, local_offset=0, location_formatting='ddm'):
        Setup GPS Object Status Flags, Internal Data Registers, etc
            local_offset (int): Timzone Difference to UTC
            location_formatting (str): Style For Presenting Longitude/Latitude:
                                       Decimal Degree Minute (ddm) - 40° 26.767′ N
                                       Degrees Minutes Seconds (dms) - 40° 26′ 46″ N
                                       Decimal Degrees (dd) - 40.446° N
        # Object Status Flags
        self.sentence_active = False
        self.active_segment = 0
        self.process_crc = False
        self.gps_segments = []
        self.crc_xor = 0
        self.char_count = 0
        self.fix_time = 0
        # Sentence Statistics
        self.crc_fails = 0
        self.clean_sentences = 0
        self.parsed_sentences = 0
        # Logging Related
        self.log_handle = None
        self.log_en = False
        # Data From Sentences
        # Time
        self.timestamp = [0, 0, 0.0]
        self.date = [0, 0, 0]
        self.local_offset = local_offset
        # Position/Motion
        self._latitude = [0, 0.0, 'N']
        self._longitude = [0, 0.0, 'W']
        self.coord_format = location_formatting
        self.speed = [0.0, 0.0, 0.0]
        self.course = 0.0
        self.altitude = 0.0
        self.geoid_height = 0.0
        # GPS Info
        self.satellites_in_view = 0
        self.satellites_in_use = 0
        self.satellites_used = []
        self.last_sv_sentence = 0
        self.total_sv_sentences = 0
        self.satellite_data = dict()
        self.hdop = 0.0
        self.pdop = 0.0
        self.vdop = 0.0
        self.valid = False
        self.fix_stat = 0
        self.fix_type = 1
    # Coordinates Translation Functions
    @property
    def latitude(self):
        """Format Latitude Data Correctly"""
        if self.coord_format == 'dd':
            decimal_degrees = self._latitude[0] + (self._latitude[1] / 60)
            return [decimal_degrees, self._latitude[2]]
        elif self.coord_format == 'dms':
            minute_parts = modf(self._latitude[1])
            seconds = round(minute_parts[0] * 60)
            return [self._latitude[0], int(minute_parts[1]), seconds, self._latitude[2]]
        else:
            return self._latitude
    @property
    def longitude(self):
        """Format Longitude Data Correctly"""
            decimal_degrees = self._longitude[0] + (self._longitude[1] / 60)
            return [decimal_degrees, self._longitude[2]]
            minute_parts = modf(self._longitude[1])
            return [self._longitude[0], int(minute_parts[1]), seconds, self._longitude[2]]
        else:
            return self._longitude
    # Logging Related Functions
    def start_logging(self, target_file, mode="append"):
        Create GPS data log object
        # Set Write Mode Overwrite or Append
        mode_code = 'w' if mode == 'new' else 'a'
        try:
            self.log_handle = open(target_file, mode_code)
        except AttributeError:
            print("Invalid FileName")
            return False
        self.log_en = True
        return True
    def stop_logging(self):
        Closes the log file handler and disables further logging
        try:
            self.log_handle.close()
            print("Invalid Handle")
            return False
        self.log_en = False
        return True
    def write_log(self, log_string):
        """Attempts to write the last valid NMEA sentence character to the active file handler
        try:
            self.log_handle.write(log_string)
        except TypeError:
            return False
        return True
    # Sentence Parsers
    def gprmc(self):
        """Parse Recommended Minimum Specific GPS/Transit data (RMC)Sentence.
        Updates UTC timestamp, latitude, longitude, Course, Speed, Date, and fix status
        # UTC Timestamp
        try:
            utc_string = self.gps_segments[1]
            if utc_string:  # Possible timestamp found
                hours = (int(utc_string[0:2]) + self.local_offset) % 24
                minutes = int(utc_string[2:4])
                seconds = float(utc_string[4:])
                self.timestamp = [hours, minutes, seconds]
            else:  # No Time stamp yet
        except ValueError:  # Bad Timestamp value present
            return False
        # Date stamp
        try:
            date_string = self.gps_segments[9]
            # Date string printer function assumes to be year >=2000,
            # date_string() must be supplied with the correct century argument to display correctly
            if date_string:  # Possible date stamp found
                day = int(date_string[0:2])
                month = int(date_string[2:4])
                year = int(date_string[4:6])
                self.date = (day, month, year)
            else:  # No Date stamp yet
                self.date = (0, 0, 0)
        except ValueError:  # Bad Date stamp value present
            return False
        # Check Receiver Data Valid Flag
        if self.gps_segments[2] == 'A':  # Data from Receiver is Valid/Has Fix
            # Longitude / Latitude
            try:
                # Latitude
                l_string = self.gps_segments[3]
                lat_degs = int(l_string[0:2])
                lat_mins = float(l_string[2:])
                lat_hemi = self.gps_segments[4]
                # Longitude
                l_string = self.gps_segments[5]
                lon_degs = int(l_string[0:3])
                lon_mins = float(l_string[3:])
                lon_hemi = self.gps_segments[6]
            except ValueError:
                return False
            if lat_hemi not in self.__HEMISPHERES:
                return False
            if lon_hemi not in self.__HEMISPHERES:
                return False
            # Speed
            try:
                spd_knt = float(self.gps_segments[7])
            except ValueError:
                return False
            # Course
            try:
                if self.gps_segments[8]:
                    course = float(self.gps_segments[8])
                else:
                    course = 0.0
            except ValueError:
                return False
            # TODO - Add Magnetic Variation
            # Update Object Data
            self._latitude = [lat_degs, lat_mins, lat_hemi]
            self._longitude = [lon_degs, lon_mins, lon_hemi]
            # Include mph and hm/h
            self.speed = [spd_knt, spd_knt * 1.151, spd_knt * 1.852]
            self.course = course
            self.valid = True
            # Update Last Fix Time
            self.new_fix_time()
        else:  # Clear Position Data if Sentence is 'Invalid'
            self.course = 0.0
            self.valid = False
        return True
    def gpgll(self):
        """Parse Geographic Latitude and Longitude (GLL)Sentence. Updates UTC timestamp, latitude,
        longitude, and fix status"""
        # UTC Timestamp
        try:
            utc_string = self.gps_segments[5]
            return False
        if self.gps_segments[6] == 'A':  # Data from Receiver is Valid/Has Fix
            try:
                # Latitude
                l_string = self.gps_segments[1]
                lat_hemi = self.gps_segments[2]
                # Longitude
                lon_hemi = self.gps_segments[4]
            except ValueError:
                return False
                return False
                return False
            self.valid = True
            self.new_fix_time()
            self.valid = False
        return True
    def gpvtg(self):
        """Parse Track Made Good and Ground Speed (VTG) Sentence. Updates speed and course"""
        try:
            course = float(self.gps_segments[1]) if self.gps_segments[1] else 0.0
            spd_knt = float(self.gps_segments[5]) if self.gps_segments[5] else 0.0
        except ValueError:
            return False
        # Include mph and km/h
        self.speed = (spd_knt, spd_knt * 1.151, spd_knt * 1.852)
        return True
    def gpgga(self):
        """Parse Global Positioning System Fix Data (GGA) Sentence. Updates UTC timestamp, latitude, longitude,
        fix status, satellites in use, Horizontal Dilution of Precision (HDOP), altitude, geoid height and fix status"""
        try:
            # UTC Timestamp
            # Skip timestamp if receiver doesn't have on yet
            if utc_string:
            else:
                hours = 0
                minutes = 0
                seconds = 0.0
            # Number of Satellites in Use
            satellites_in_use = int(self.gps_segments[7])
            # Get Fix Status
            fix_stat = int(self.gps_segments[6])
        except (ValueError, IndexError):
            return False
        try:
            # Horizontal Dilution of Precision
            hdop = float(self.gps_segments[8])
            hdop = 0.0
        # Process Location and Speed Data if Fix is GOOD
        if fix_stat:
            try:
                # Latitude
                l_string = self.gps_segments[2]
                lat_hemi = self.gps_segments[3]
                # Longitude
                l_string = self.gps_segments[4]
                lon_hemi = self.gps_segments[5]
            except ValueError:
                return False
                return False
                return False
            # Altitude / Height Above Geoid
            try:
                altitude = float(self.gps_segments[9])
                geoid_height = float(self.gps_segments[11])
            except ValueError:
                altitude = 0
                geoid_height = 0
            self.altitude = altitude
            self.geoid_height = geoid_height
        self.satellites_in_use = satellites_in_use
        self.hdop = hdop
        self.fix_stat = fix_stat
        # If Fix is GOOD, update fix timestamp
        if fix_stat:
            self.new_fix_time()
        return True
    def gpgsa(self):
        """Parse GNSS DOP and Active Satellites (GSA) sentence. Updates GPS fix type, list of satellites used in
        fix calculation, Position Dilution of Precision (PDOP), Horizontal Dilution of Precision (HDOP), Vertical
        Dilution of Precision, and fix status"""
        # Fix Type (None,2D or 3D)
        try:
            fix_type = int(self.gps_segments[2])
        except ValueError:
            return False
        # Read All (up to 12) Available PRN Satellite Numbers
        sats_used = []
        for sats in range(12):
            sat_number_str = self.gps_segments[3 + sats]
            if sat_number_str:
                try:
                    sat_number = int(sat_number_str)
                    sats_used.append(sat_number)
                except ValueError:
                    return False
            else:
                break
        # PDOP,HDOP,VDOP
        try:
            pdop = float(self.gps_segments[15])
            hdop = float(self.gps_segments[16])
            vdop = float(self.gps_segments[17])
        except ValueError:
            return False
        self.fix_type = fix_type
        if fix_type > self.__NO_FIX:
            self.new_fix_time()
        self.satellites_used = sats_used
        self.hdop = hdop
        self.vdop = vdop
        self.pdop = pdop
        return True
    def gpgsv(self):
        """Parse Satellites in View (GSV) sentence. Updates number of SV Sentences,the number of the last SV sentence
        parsed, and data on each satellite present in the sentence"""
        try:
            num_sv_sentences = int(self.gps_segments[1])
            current_sv_sentence = int(self.gps_segments[2])
            sats_in_view = int(self.gps_segments[3])
        except ValueError:
            return False
        # Create a blank dict to store all the satellite data from this sentence in:
        # satellite PRN is key, tuple containing telemetry is value
        satellite_dict = dict()
        # Calculate  Number of Satelites to pull data for and thus how many segment positions to read
        if num_sv_sentences == current_sv_sentence:
            # Last sentence may have 1-4 satellites; 5 - 20 positions
            sat_segment_limit = (sats_in_view - ((num_sv_sentences - 1) * 4)) * 5
        else:
            sat_segment_limit = 20  # Non-last sentences have 4 satellites and thus read up to position 20
        # Try to recover data for up to 4 satellites in sentence
        for sats in range(4, sat_segment_limit, 4):
            # If a PRN is present, grab satellite data
            if self.gps_segments[sats]:
                try:
                    sat_id = int(self.gps_segments[sats])
                except (ValueError,IndexError):
                    return False
                try:  # elevation can be null (no value) when not tracking
                    elevation = int(self.gps_segments[sats+1])
                    elevation = None
                try:  # azimuth can be null (no value) when not tracking
                    azimuth = int(self.gps_segments[sats+2])
                    azimuth = None
                try:  # SNR can be null (no value) when not tracking
                    snr = int(self.gps_segments[sats+3])
                    snr = None
            # If no PRN is found, then the sentence has no more satellites to read
            else:
                break
            # Add Satellite Data to Sentence Dict
            satellite_dict[sat_id] = (elevation, azimuth, snr)
        self.total_sv_sentences = num_sv_sentences
        self.last_sv_sentence = current_sv_sentence
        self.satellites_in_view = sats_in_view
        # For a new set of sentences, we either clear out the existing sat data or
        # update it as additional SV sentences are parsed
        if current_sv_sentence == 1:
            self.satellite_data = satellite_dict
        else:
            self.satellite_data.update(satellite_dict)
        return True
    # Data Stream Handler Functions
    def new_sentence(self):
        """Adjust Object Flags in Preparation for a New Sentence"""
        self.gps_segments = ['']
        self.crc_xor = 0
        self.sentence_active = True
        self.process_crc = True
        self.char_count = 0
    def update(self, new_char):
        """Process a new input char and updates GPS object if necessary based on special characters ('$', ',', '*')
        Function builds a list of received string that are validate by CRC prior to parsing by the  appropriate
        sentence function. Returns sentence type on successful parse, None otherwise"""
        valid_sentence = False
        # Validate new_char is a printable char
        ascii_char = ord(new_char)
        if 10 <= ascii_char <= 126:
            self.char_count += 1
            # Write Character to log file if enabled
            if self.log_en:
                self.write_log(new_char)
            # Check if a new string is starting ($)
            if new_char == '$':
                self.new_sentence()
                return None
            elif self.sentence_active:
                # Check if sentence is ending (*)
                if new_char == '*':
                    self.active_segment += 1
                    self.gps_segments.append('')
                    return None
                # Check if a section is ended (,), Create a new substring to feed
                # characters to
                elif new_char == ',':
                # Store All Other printable character and check CRC when ready
                else:
                    self.gps_segments[self.active_segment] += new_char
                    # When CRC input is disabled, sentence is nearly complete
                    if not self.process_crc:
                        if len(self.gps_segments[self.active_segment]) == 2:
                            try:
                                final_crc = int(self.gps_segments[self.active_segment], 16)
                                if self.crc_xor == final_crc:
                                    valid_sentence = True
                                else:
                                    self.crc_fails += 1
                            except ValueError:
                                pass  # CRC Value was deformed and could not have been correct
                # Update CRC
                if self.process_crc:
                    self.crc_xor ^= ascii_char
                # If a Valid Sentence Was received and it's a supported sentence, then parse it!!
                if valid_sentence:
                    self.clean_sentences += 1  # Increment clean sentences received
                    self.sentence_active = False  # Clear Active Processing Flag
                    if self.gps_segments[0] in self.supported_sentences:
                        # parse the Sentence Based on the message type, return True if parse is clean
                        if self.supported_sentences[self.gps_segments[0]](self):
                            # Let host know that the GPS object was updated by returning parsed sentence type
                            self.parsed_sentences += 1
                            return self.gps_segments[0]
                # Check that the sentence buffer isn't filling up with Garage waiting for the sentence to complete
                if self.char_count > self.SENTENCE_LIMIT:
        # Tell Host no new sentence was parsed
        return None
    def new_fix_time(self):
        """Updates a high resolution counter with current time when fix is updated. Currently only triggered from
        GGA, GSA and RMC sentences"""
        try:
            self.fix_time = utime.ticks_ms()
        except NameError:
            self.fix_time = time.time()
    # User Helper Functions
    # These functions make working with the GPS object data easier
    def satellite_data_updated(self):
        Checks if the all the GSV sentences in a group have been read, making satellite data complete
        :return: boolean
        if self.total_sv_sentences > 0 and self.total_sv_sentences == self.last_sv_sentence:
            return True
        else:
            return False
    def unset_satellite_data_updated(self):
        Mark GSV sentences as read indicating the data has been used and future updates are fresh
    def satellites_visible(self):
        Returns a list of of the satellite PRNs currently visible to the receiver
        :return: list
        return list(self.satellite_data.keys())
    def time_since_fix(self):
        """Returns number of millisecond since the last sentence with a valid fix was parsed. Returns 0 if
        no fix has been found"""
        # Test if a Fix has been found
        if self.fix_time == 0:
            return -1
        # Try calculating fix time using utime; if not running MicroPython
        # time.time() returns a floating point value in secs
        try:
            current = utime.ticks_diff(utime.ticks_ms(), self.fix_time)
        except NameError:
            current = (time.time() - self.fix_time) * 1000  # ms
        return current
    def compass_direction(self):
        Determine a cardinal or inter-cardinal direction based on current course.
        :return: string
        # Calculate the offset for a rotated compass
        if self.course >= 348.75:
            offset_course = 360 - self.course
        else:
            offset_course = self.course + 11.25
        # Each compass point is separated by 22.5 degrees, divide to find lookup value
        dir_index = floor(offset_course / 22.5)
        final_dir = self.__DIRECTIONS[dir_index]
        return final_dir
    def latitude_string(self):
        Create a readable string of the current latitude data
        :return: string
            formatted_latitude = self.latitude
            lat_string = str(formatted_latitude[0]) + '° ' + str(self._latitude[2])
            lat_string = str(formatted_latitude[0]) + '° ' + str(formatted_latitude[1]) + "' " + str(formatted_latitude[2]) + '" ' + str(formatted_latitude[3])
        else:
            lat_string = str(self._latitude[0]) + '° ' + str(self._latitude[1]) + "' " + str(self._latitude[2])
        return lat_string
    def longitude_string(self):
        Create a readable string of the current longitude data
        :return: string
            formatted_longitude = self.longitude
            lon_string = str(formatted_longitude[0]) + '° ' + str(self._longitude[2])
            lon_string = str(formatted_longitude[0]) + '° ' + str(formatted_longitude[1]) + "' " + str(formatted_longitude[2]) + '" ' + str(formatted_longitude[3])
        else:
            lon_string = str(self._longitude[0]) + '° ' + str(self._longitude[1]) + "' " + str(self._longitude[2])
        return lon_string
    def speed_string(self, unit='kph'):
        Creates a readable string of the current speed data in one of three units
        :param unit: string of 'kph','mph, or 'knot'
        :return:
        if unit == 'mph':
            speed_string = str(self.speed[1]) + ' mph'
        elif unit == 'knot':
            if self.speed[0] == 1:
                unit_str = ' knot'
            else:
                unit_str = ' knots'
            speed_string = str(self.speed[0]) + unit_str
        else:
            speed_string = str(self.speed[2]) + ' km/h'
        return speed_string
    def date_string(self, formatting='s_mdy', century='20'):
        Creates a readable string of the current date.
        Can select between long format: Januray 1st, 2014
        or two short formats:
        11/01/2014 (MM/DD/YYYY)
        01/11/2014 (DD/MM/YYYY)
        :param formatting: string 's_mdy', 's_dmy', or 'long'
        :param century: int delineating the century the GPS data is from (19 for 19XX, 20 for 20XX)
        :return: date_string  string with long or short format date
        # Long Format Januray 1st, 2014
        if formatting == 'long':
            # Retrieve Month string from private set
            month = self.__MONTHS[self.date[1] - 1]
            # Determine Date Suffix
            if self.date[0] in (1, 21, 31):
                suffix = 'st'
            elif self.date[0] in (2, 22):
                suffix = 'nd'
            elif self.date[0] == (3, 23):
                suffix = 'rd'
            else:
                suffix = 'th'
            day = str(self.date[0]) + suffix  # Create Day String
            year = century + str(self.date[2])  # Create Year String
            date_string = month + ' ' + day + ', ' + year  # Put it all together
        else:
            # Add leading zeros to day string if necessary
            if self.date[0] < 10:
                day = '0' + str(self.date[0])
            else:
            # Add leading zeros to month string if necessary
            if self.date[1] < 10:
                month = '0' + str(self.date[1])
            else:
                month = str(self.date[1])
            # Add leading zeros to year string if necessary
            if self.date[2] < 10:
                year = '0' + str(self.date[2])
            else:
                year = str(self.date[2])
            # Build final string based on desired formatting
            if formatting == 's_dmy':
                date_string = day + '/' + month + '/' + year
            else:  # Default date format
                date_string = month + '/' + day + '/' + year
        return date_string
    # All the currently supported NMEA sentences
    supported_sentences = {'GPRMC': gprmc, 'GLRMC': gprmc,
                           'GPGGA': gpgga, 'GLGGA': gpgga,
                           'GPVTG': gpvtg, 'GLVTG': gpvtg,
                           'GPGSA': gpgsa, 'GLGSA': gpgsa,
                           'GPGSV': gpgsv, 'GLGSV': gpgsv,
                           'GPGLL': gpgll, 'GLGLL': gpgll,
                           'GNGGA': gpgga, 'GNRMC': gprmc,
                           'GNVTG': gpvtg, 'GNGLL': gpgll,
                           'GNGSA': gpgsa,
if __name__ == "__main__":
    pass
功能函数调用以及信息显示代码如下:
from machine import UART, Pin
import time
import hashlib
from micropyGPS import MicropyGPS
 # Display Image & text on I2C driven ssd1306 OLED display
from ssd1306 import SSD1306_I2C
from machine import Pin, I2C
import framebuf
i2c1 = I2C(0, scl=Pin(9), sda=Pin(8), freq=400000)
oled = SSD1306_I2C(128,64,i2c1)
uart0 = UART(0, baudrate=9600, tx=Pin(0), rx=Pin(1))
time.sleep(0.1)
rxData = bytes()
my_gps = MicropyGPS()
while True:
    if uart0.any():
        stat = my_gps.update(uart0.read(1).decode('ascii')) # Note the conversion to to chr, UART outputs ints normally
        if stat:
            oled.fill(0)
            lat_disp = my_gps.latitude_string()
            oled.text(lat_disp,5,10)
            lon_disp = my_gps.longitude_string()
            oled.text(lon_disp,5,30)
            time_disp = my_gps.date_string('s_dmy')
            oled.text(time_disp,5,50)
            oled.show()
            print('Latitude:', my_gps.latitude_string())
            print('Longitude:', my_gps.longitude_string())
            print('Speed:', my_gps.speed_string('kph'), 'or', my_gps.speed_string('mph'), 'or', my_gps.speed_string('knot'))
            print('Date (Long Format):', my_gps.date_string('long'))
            print('Date (Short D/M/Y Format):', my_gps.date_string('s_dmy'))
            print('timestamp (Short [H,M,S] Format):', my_gps.timestamp)
            stat = None
效果如图所示:
下面是演示视频:
04-GPS运行
总结
这个GPS模块是全部模块中最复杂的,其功能同时也是生活中经常用到的,通过本次活动,了解到了一种GPS模块的使用方法和通讯方式,同时也知道了串口是作为GPS模块通讯的一种接口。而且使用micropython的生态库,在对GPS模块处于了解程度时,就可以实现相应的功能,体会到micropython作为新手入门嵌入式的好处,帮助初学者避开了繁杂的底层代码,直接学习器件的使用。
谢谢楼主的分享 模块工大约30秒,即可正常连接上卫星并更新位置和时间信息。 这30秒还算快的,有的需要一分多钟   详情 回复 发表于 2023-6-18 16:17
1704
谢谢楼主的分享
这30秒还算快的,有的需要一分多钟
