1158|4
1239
66
【极海APM32F407 Tiny Board】5、DSP库FFT测试 [复制链接]
官方demo没有开优化,编译后烧录超级慢,开了O3优化后快不少。
#include "main.h"
#include "Board.h"
#include "stdio.h"
#include "apm32f4xx_gpio.h"
#include "apm32f4xx_misc.h"
#include "apm32f4xx_usart.h"
extern void DSPTestDemo(void);
uint32_t delay_init(void)
	uint32_t c;
	/* Enable TRC */
	CoreDebug->DEMCR &= ~0x01000000;
	CoreDebug->DEMCR |=  0x01000000;
	/* Enable counter */
	DWT->CTRL &= ~0x00000001;
	DWT->CTRL |=  0x00000001;
	/* Reset counter */
	DWT->CYCCNT = 0;
	/* Check if DWT has started */
	c = DWT->CYCCNT;
	/* 2 dummys */
	__ASM volatile ("NOP");
	/* Return difference, if result is zero, DWT has not started */
	return (DWT->CYCCNT - c);
void delay_ms(uint32_t ms)
	uint32_t start = DWT->CYCCNT;
	/* Go to number of cycles for system */
	ms *= (SystemCoreClock / 1000);
	/* Delay till end */
	while ((DWT->CYCCNT - start) < ms);
int main(void)
    uint8_t keyType;
    /* Set system interrupt priority grouping */
    NVIC_ConfigPriorityGroup(NVIC_PRIORITY_GROUP_2);
    /* Init delay function */
    Delay_Init();
    /* Init LED */
    APM_MINI_LEDInit(LED2);
    APM_MINI_LEDInit(LED3);
    /* Init USART1 */
    USART1_Init(115200);
    /* Init KEY */
    APM_MINI_PBInit(BUTTON_KEY2, BUTTON_MODE_GPIO);
    APM_MINI_PBInit(BUTTON_KEY1, BUTTON_MODE_GPIO);
		delay_init();
    /* Wait board and module power on */
    delay_ms(200);
		uint32_t t1 = DWT->CYCCNT;
		DSPTestDemo();
		uint32_t t2 = DWT->CYCCNT;
		printf("time=%fus\n",(t2-t1)*1000000.0/SystemCoreClock);
    APM_MINI_LEDOn(LED3);
    while(1)
        delay_ms(10);
没有开启FPU情况下2048点FFT耗时约16.2ms,网友stm32f407的测试对比
尝试加入宏定义开启FPU,但是编译报错了。。
__FPU_PRESENT = 1,__FPU_USED = 1
多之前把APM看成AT了,下的雅特力的例程,刚刚又装了极海的SDK试了下,添加__FPU_PRESENT=1,__FPU_USED=1定义会出现和你一样的错误 这种情况应该是__FPU_USED重复定义了,你看看只加__FPU_PRESENT=1不加__FPU_USED=1行不行 [attach]704230[/attach]     详情 回复 发表于 2023-6-9 20:40
7056
大佬出品果然是高深的测试。学习了!
9798
24
我试着在Firmware Library例程的MDK工程里定义__FPU_PRESENT=1,__FPU_USED=1可以编译通过
编译警告是因为  at32f403a_407.h里定义了__FPU_PRESENT
回头试试  详情 回复 发表于 2023-6-8 21:58
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
1239
66
littleshrimp 发表于 2023-6-5 11:24 我试着在Firmware Library例程的MDK工程里定义__FPU_PRESENT=1,__FPU_USED=1可以编译通过 编译 ...
回头试试
多之前把APM看成AT了,下的雅特力的例程,刚刚又装了极海的SDK试了下,添加__FPU_PRESENT=1,__FPU_USED=1定义会出现和你一样的错误 这种情况应该是__FPU_USED重复定义了,你看看只加__FPU_PRESENT=1不加__FPU_USE  详情 回复 发表于 2023-6-9 20:40
9798
24
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
