1066|3
【得捷电子Follow me第1期】二:Mu 下的OLED和蜂鸣器 [复制链接]
1.连接
OLED屏幕接在了IIC1口上,应该接0上也行.
蜂鸣器接在了D16上.如图所示
2.程序
PWM驱动蜂鸣器没啥特别的,copy下大佬们的代码就响了
# Example using PWM to fade an BEEP.
import time
from machine import Pin, PWM
# Construct PWM object, with BEEP on Pin(16).
pwm = PWM(Pin(16))
# Set the PWM frequency.
pwm.freq(1000)
# Fade the BEEP in and out a few times.
duty = 0
direction = 1
for _ in range(8 * 256):
    duty += direction
    if duty > 255:
        duty = 255
        direction = -1
    elif duty < 0:
        duty = 0
        direction = 1
    pwm.duty_u16(duty * duty)
    time.sleep(0.001)
OLED发现IIC还得有个与1306屏幕相对应的屏幕,奈何我民风纯朴,绝对只用Mu那个啥 啥 我是不会用的,所以,我没地儿找和安这个驱动包.从论坛找到了驱动的源码,但找来找去我也没有找到如何 把它发送到pico里.驱动代码如下:
# MicroPython SSD1306 OLED driver, I2C and SPI interfaces
from micropython import const
import framebuf
# register definitions
SET_CONTRAST = const(0x81)
SET_ENTIRE_ON = const(0xA4)
SET_NORM_INV = const(0xA6)
SET_DISP = const(0xAE)
SET_MEM_ADDR = const(0x20)
SET_COL_ADDR = const(0x21)
SET_PAGE_ADDR = const(0x22)
SET_DISP_START_LINE = const(0x40)
SET_SEG_REMAP = const(0xA0)
SET_MUX_RATIO = const(0xA8)
SET_COM_OUT_DIR = const(0xC0)
SET_DISP_OFFSET = const(0xD3)
SET_COM_PIN_CFG = const(0xDA)
SET_DISP_CLK_DIV = const(0xD5)
SET_PRECHARGE = const(0xD9)
SET_VCOM_DESEL = const(0xDB)
SET_CHARGE_PUMP = const(0x8D)
# Subclassing FrameBuffer provides support for graphics primitives
# http://docs.micropython.org/en/latest/pyboard/library/framebuf.html
class SSD1306(framebuf.FrameBuffer):
    def __init__(self, width, height, external_vcc):
        self.width = width
        self.height = height
        self.external_vcc = external_vcc
        self.pages = self.height // 8
        self.buffer = bytearray(self.pages * self.width)
        super().__init__(self.buffer, self.width, self.height, framebuf.MONO_VLSB)
        self.init_display()
    def init_display(self):
        for cmd in (
            SET_DISP | 0x00,  # off
            # address setting
            SET_MEM_ADDR,
            0x00,  # horizontal
            # resolution and layout
            SET_DISP_START_LINE | 0x00,
            SET_SEG_REMAP | 0x01,  # column addr 127 mapped to SEG0
            SET_MUX_RATIO,
            self.height - 1,
            SET_COM_OUT_DIR | 0x08,  # scan from COM[N] to COM0
            SET_DISP_OFFSET,
            0x00,
            SET_COM_PIN_CFG,
            0x02 if self.width > 2 * self.height else 0x12,
            # timing and driving scheme
            SET_DISP_CLK_DIV,
            0x80,
            SET_PRECHARGE,
            0x22 if self.external_vcc else 0xF1,
            SET_VCOM_DESEL,
            0x30,  # 0.83*Vcc
            # display
            SET_CONTRAST,
            0xFF,  # maximum
            SET_ENTIRE_ON,  # output follows RAM contents
            SET_NORM_INV,  # not inverted
            # charge pump
            SET_CHARGE_PUMP,
            0x10 if self.external_vcc else 0x14,
            SET_DISP | 0x01,
        ):  # on
            self.write_cmd(cmd)
        self.fill(0)
        self.show()
    def poweroff(self):
        self.write_cmd(SET_DISP | 0x00)
    def poweron(self):
        self.write_cmd(SET_DISP | 0x01)
    def contrast(self, contrast):
        self.write_cmd(SET_CONTRAST)
        self.write_cmd(contrast)
    def invert(self, invert):
        self.write_cmd(SET_NORM_INV | (invert & 1))
    def show(self):
        x0 = 0
        x1 = self.width - 1
        if self.width == 64:
            # displays with width of 64 pixels are shifted by 32
            x0 += 32
            x1 += 32
        self.write_cmd(SET_COL_ADDR)
        self.write_cmd(x0)
        self.write_cmd(x1)
        self.write_cmd(SET_PAGE_ADDR)
        self.write_cmd(0)
        self.write_cmd(self.pages - 1)
        self.write_data(self.buffer)
class SSD1306_I2C(SSD1306):
    def __init__(self, width, height, i2c, addr=0x3C, external_vcc=False):
        self.i2c = i2c
        self.addr = addr
        self.temp = bytearray(2)
        self.write_list = [b"\x40", None]  # Co=0, D/C#=1
        super().__init__(width, height, external_vcc)
    def write_cmd(self, cmd):
        self.temp[0] = 0x80  # Co=1, D/C#=0
        self.temp[1] = cmd
        self.i2c.writeto(self.addr, self.temp)
    def write_data(self, buf):
        self.write_list[1] = buf
        self.i2c.writevto(self.addr, self.write_list)
class SSD1306_SPI(SSD1306):
    def __init__(self, width, height, spi, dc, res, cs, external_vcc=False):
        self.rate = 10 * 1024 * 1024
        dc.init(dc.OUT, value=0)
        res.init(res.OUT, value=0)
        cs.init(cs.OUT, value=1)
        self.spi = spi
        self.dc = dc
        self.res = res
        self.cs = cs
        import time
        self.res(1)
        time.sleep_ms(1)
        self.res(0)
        time.sleep_ms(10)
        self.res(1)
        self.spi.init(baudrate=self.rate, polarity=0, phase=0)
        self.cs(1)
        self.dc(0)
        self.cs(0)
        self.spi.write(bytearray([cmd]))
        self.cs(1)
        self.cs(1)
        self.dc(1)
        self.cs(0)
        self.spi.write(buf)
        self.cs(1)
但是,山人自有妙计,把整个文件 内容 拷贝到另一个要写示例的py文件里就行了,抄完如下:
from machine import Pin, I2C
import time
import framebuf
        self.width = width
        self.init_display()
        for cmd in (
            # address setting
            SET_MEM_ADDR,
            0x00,  # horizontal
            SET_MUX_RATIO,
            self.height - 1,
            SET_DISP_OFFSET,
            0x00,
            SET_COM_PIN_CFG,
            SET_DISP_CLK_DIV,
            0x80,
            SET_PRECHARGE,
            SET_VCOM_DESEL,
            0x30,  # 0.83*Vcc
            # display
            SET_CONTRAST,
            0xFF,  # maximum
            # charge pump
            SET_CHARGE_PUMP,
            SET_DISP | 0x01,
        ):  # on
            self.write_cmd(cmd)
        self.fill(0)
        self.show()
    def poweroff(self):
    def poweron(self):
    def show(self):
        x0 = 0
        x1 = self.width - 1
            x0 += 32
            x1 += 32
        self.write_cmd(x0)
        self.write_cmd(x1)
        self.write_cmd(0)
        self.i2c = i2c
        self.addr = addr
        self.temp[1] = cmd
        self.spi = spi
        self.dc = dc
        self.res = res
        self.cs = cs
        import time
        self.res(1)
        time.sleep_ms(1)
        self.res(0)
        time.sleep_ms(10)
        self.res(1)
        self.cs(1)
        self.dc(0)
        self.cs(0)
        self.cs(1)
        self.cs(1)
        self.dc(1)
        self.cs(0)
        self.spi.write(buf)
        self.cs(1)
led = machine.Pin("LED", machine.Pin.OUT)
i2c = machine.I2C(1, sda=machine.Pin("GP6"), scl=machine.Pin("GP7"), freq=400000)
display = SSD1306_I2C(128, 64, i2c)
display.fill(0)
display.show()
display.text("hello eeworld", 5, 10)
display.show()
time.sleep(1)
strokes_lib = {
    "小": [
        [[0.48, 0.05], [0.48, 0.98]],
        [[0.28, 0.96], [0.51, 0.96]],
        [[0.76, 0.32], [0.99, 0.78]],
        [[0.21, 0.38], [0.02, 0.76]],
    "星": [
        [[0.49, 0.49], [0.49, 1.0]],
        [[0.14, 0.08], [0.87, 0.08], [0.85, 0.45]],
        [[0.14, 0.25], [0.89, 0.25]],
        [[0.14, 0.08], [0.14, 0.435], [0.89, 0.42]],
        [[0.13, 0.62], [0.93, 0.62]],
        [[0.16, 0.77], [0.89, 0.77]],
        [[0.02, 0.97], [1.0, 0.97]],
        [[0.22, 0.54], [0.02, 0.74]],
display.fill(0)
def draw_hz(hz, x0, y0, font_size=16):
    for stroke in strokes_lib[hz]:
        for i in range(1, len(stroke)):
            x1 = x0 + round(stroke[i - 1][0] * font_size)
            y1 = y0 + round(stroke[i - 1][1] * font_size)
            x2 = x0 + round(stroke[0] * font_size)
            y2 = y0 + round(stroke[1] * font_size)
            display.line(x1, y1, x2, y2, 1)
font_size = 40
(x0, y0) = (0, 0)
for hz in "小星星":
    draw_hz(hz, x0, y0, font_size)
    x0 += font_size
display.show()
pwm = PWM(Pin(16))
# 定义音调频率
tones = {"1": 262, "2": 294, "3": 330, "4": 349, "5": 392, "6": 440, "7": 494, "-": 0}
# 定义小星星旋律
melody = "1155665-4433221-5544332-5544332-1155665-4433221"
for tone in melody:
    freq = tones[tone]
    if freq:
        pwm.freq(freq)  # 调整PWM的频率,使其发出指定的音调
        pwm.duty_u16(10000)
        led.on()
    else:
        pwm.duty_u16(0)  # 空拍时一样不上电
        led.off()
    # 停顿一下 (四四拍每秒两个音,每个音节中间稍微停顿一下)
    time.sleep_ms(400)
    pwm.duty_u16(0)  # 设备占空比为0,即不上电
    led.off()
    time.sleep_ms(100)
display.fill(0)
display.show()
效果如下:
感谢:
https://bbs.eeworld.com.cn/thread-1244149-1-1.html
https://bbs.eeworld.com.cn/thread-1243998-1-1.html
def draw_hz(hz, x0, y0, font_size=16):     for stroke in strokes_lib[hz]:         for i in range(1, len(stroke)):             x1 = x0 + round(stroke[i - 1][0] * font_size)             y1 = y0 + round(stroke[i - 1][1] * font_size)             x2 = x0 + round(stroke[0] * font_size)             y2 = y0 + round(stroke[1] * font_size)             display.line(x1, y1, x2, y2, 1) font_size = 40 (x0, y0) = (0, 0) for hz in "小星星":     draw_hz(hz, x0, y0, font_size)     x0 += font_size display.show() 大佬,不知道这个汉字生成的软件是什么。这个挺好玩的呀。   详情 回复 发表于 2023-6-2 06:23
点赞(1) 关注
6968
哇,大佬的汉字怎么实现的呀,是图片还是做了字库呀。
strokes_lib = {     "小": [         [[0.48, 0.05], [0.48, 0.98]],         [[0.28, 0.96], [0.51, 0.96]],         [[0.76, 0.  详情 回复 发表于 2023-6-1 22:44
lugl4313820 发表于 2023-6-1 18:14 哇,大佬的汉字怎么实现的呀,是图片还是做了字库呀。
strokes_lib = {
    "小": [
    "星": [
别的大佬做的字,应该是用线画的,数组里都是线段,有兴趣可以用生字软件生一下点的,这个线的只能说能用
6968
font_size = 40
(x0, y0) = (0, 0)
for hz in "小星星":
    x0 += font_size
display.show()
